Eradicator
New issue now. When I switch to 8mm from Super 8mm, the screen corrupts and will not show anything in the capture section of the menu in the preview mode or in capture mode. If I back out of capture mode, the screen returns to normal and all menu options work as they should. Have flashed back to the stock D firmware, but no change. I flashed back to the WIP D firmware mod with no change.
I have done the lens replacement and even scanned a regular 8mm film with no issues. I started a new reel of regular 8mm and the screen froze with the image on of the frame on it and would not change.
The frame image from the flim stayed even after removing the film in capture mode. Once I backed out of capture mode, the menu showed up and worked as it should. Back in capture mode, the frame image shows up again. I powered down and then backup, and that is when the corupt screen image shows in any part of capture mode. That is when I tried flashing the stock firmware back.
So currently I can scan Super 8mm, but not regular 8mm. Any ideas?
Has anyone experienced this issue before?
Eradicator
This is what my model D records now on regular 8mm. It does Super 8mm just fine.
Any ideas? I have already done the lens mod, but it was working about a week before this happened.
It shows this, or some other type of corruption even if there is no SD card in the scanner.
  • Movie0001.MP4
Hook Line and Tinker
12
6
Could you have unknowingly caused some minor damage while the unit was opened up for the mod that got worse after some use? I'd open it back up and inspect for loose wires, cracked solder joints, missing components, etc. I doubt this is related to firmware if it's behaving the same way with stock firmware.
Beyond that, how invasive is the lens mod and can it be reverted back to stock? Could be a latent defect from the factory and if so, try reaching out to Amazon for a refund since it's less than a month old.
Eradicator
I did not open up the unit for the lens mod. I removed the old lens and sercured the ribbon cable out of the way. Then used a hobby knife to very carefully score the plastic until I could work it back and forth to "snap" the plastic I needed to remove. The knife never went all the way through the plastic. The ribbon cable we never hit by the knife. I did reseat the calble on the sensor side, but no change.
I might see if I can order a new ribbon cable to see if that resolves the issue.
I can assure you, the cable was not touched by the knife.
The screen will corrupt, or hold a image if it manages to see the image briefly. Just barely moving the switch from Super 8 to regular 8 messes up the screen, long before any of the other parts move.
For now, I will convert all my Super 8, then see what I can do on the regular 8 side. This way I can at least capture all my super 8.
I can switch back to super 8 and the screen and caputre is just fine without turning the unit off. I can slide the switch back and forth, screen always corupts on regular 8 and returns to normal on super.
I can't do a refund through since I cut the plastic for the lens mod. Although I guess I could order a new one and swapt the guts of it and return the old parts. I'll try checking all the wires on the inside first though. Maybe something came lose during the mod.
As for the lens swap iteself, it was not hard. I first got the parts in the lens swap guide. I ended up with a ton of extra screws, the case of them was like $9. The different lens holders as like 10 different sizes, but it was like $12. I did have a friend 3D print the spacer from the file in the guide. It works perfect.
I had to play around with the threaded holder in different sizes to get it to focus correctly but I had all the parts to make it work.
The only bummer is the D model mod does not have all the features of the earlier mods do to different hardware. But it does scan better, and the new firmware has the frame rate at 18fps instead of 20fps like the stock version.
Boojakascha
First of all:
Big thanks to 0dan0, Mac84 and videodoctor!
I write a suggestion:
I think it would be of help to newcomers to state in the first post that the Letter in the serial number doesn't do much and that the first three numbers are more important. Also I would argue to stop linking to the Firmware suggest tool, as it spits out B too frequently.
Finally, I would suggest to link 0dan0 edit of videodoctor' D dump to the list of original firmware. Also maybe to the repository the serial number check tool is linking too.
There is currently no real stock D, right? Just the stock D 0dan0 did minor changes on during boot screen?
For the records: my K2225148BK00947 units wants Firmware D.
Eradicator
First of all:
I believe the stock "D" firmware is downloadable in post 143.
Reactions: Boojakascha
Boojakascha
Thanks a ton Sir! :"
I did not find it, because when skimming through the 30 pages, I thought 143 is just about a Version 7.7 release post.
I think though the importance of pinning such a post and Mac84 updating the instructions on his page (https://mac84.net/8mmlookup/#installfirmwareinstructions) is raising as time passes, because the Reels Scanners are still being produced and are all going to be D (or later lower letters maybe?)
Reactions: Eradicator
JayAech
Still curious if anyone else has a 100% confirmation on this stock number firmware version to use: J2925148BK00696
The J prefix seems extremely rare at this point, I havent seen anyone else mention having one with that prefix.
Boojakascha
From my limited insight you toss the letter. You go for the first three digits instead.
There are dumps of all four stock firmwares anyways. You can't screw up.
12
6
I think the concern here is that it was suggested that since this is an unknown serial number, there is a possibility that it could be a 5th variant and if he flashes to "D" and it's really "E" (assuming that exists), he would brick his unit. If you go back to post 215 and prior posts, you can read about how some of the experts are using hardware and soldering skills to grab the stock firmware. Without knowing for sure, if I had the J2925 unit, I probably wouldn't risk flashing to the modified "D" firmware not knowing whether I could go back to stock but that's me.
melw
Hello all! New to the forum and tinkering.
I recently purchased a Kodak Reels (type D) device, started capturing and was immediately disappointed by the quality of the video - very grainy, ton of compression artifacts, low bitrate. Then I found this forum and thread, read through all the posts - so much info, my brain hurts! :D Started patching existing firmwares and testing what works, what doesn't work, and in what way. Then set up the toolchain and started reverse-engineering and modifying the firmware myself. Now after a few days, I think I'm getting somewhere with all the tinkering.
First, credit where it's due: none of this would exist without 0dan0's repo and reverse-engineering groundwork (the build/pack toolchain, the A/B/C hooks, the histogram/OSD approach, and the original D WIP) and videodoctor's working D firmware (1600×1200 / ~18 fps base, plus his notes on D's display/frame-buffer differences). All of the below is on videodoctor's D build as the base; the changes are single-instruction static patches on the decompressed image (no new toolchain needed).
1. Image quality — bitrate control
Compression quality (or lack of it) was my biggest gripe, and it turns out the record bitrate is a soft target, not a hard buffer cap. The active bits/sec for the record encoder = config[24] << 3, set by one instruction:
  • 0x80240588: sll v1,v1,3 (×8, word 0x000318c0). Patch to sll v1,v1,4 (0x00031900) → ×2 (~16 Mbps); sll v1,v1,5 (0x00031940) → ×4 (~31 Mbps).
  • The rate-control limits are proportional to the target (RC+156 = 0.8×budget, RC+148 = 6×budget), so raising the target raises the overflow threshold too — the encoder simply picks a lower QP instead. Tested 8 → 16 → 32 Mbps, all stable, visibly less blocky.
2. On-screen HUD on D
I was able to hook up rendering through previously existing hook: The stock white-balance function fires already every frame in capture. Redirect the call at 0x2b7c90 to custom routine and call the original (0x802b7b7c) so WB still runs.
  • Drawing into the V1 video buffer (0xA3CF65B0, pitch 656) shows immediately but flickers
  • The steady surface is the IDE O1 OSD layer: handle = *(u32*)0x80e08df0 (a handle ID, not a pointer), base = resolve(handle) via 0x80006500, pixels at base + 0x65400 (864×480, 8-bit palette). Drawing here is steady in non-capture mode.
  • In capture the firmware recomposes the whole O1 layer on its UI updates (record-icon blink etc.), so draw blinks as well. I traced the GUI present path (OSD_Compose @ 0x8010bc38: the canvas→O1 blit 0x8010c164 @ 0x8010bc70, src canvas ptr *0x80e09aa8, flush 0x8010b0e8 @ 0x8010bd14) and tried hooking it three ways (draw O1 after the blit; draw O1 before the flush; draw the source canvas before the blit) — all run but never appear on screen. The capture compositor shows a buffer I can't pin down by static RE alone, and I have no live observability (no serial console / RAM dump) to find it.
    This is where I'd love input: which buffer the capture path actually scans out, the correct per-recompose draw point during capture, or simply a RAM dump from a D unit so the live pointers can be read.
3. Why 0dan0's D build locks up on device startup
Inline hooks at motor-timing entries (0x2b6a3c, 0x2b7c98, crop cluster) stall motor init; plus a WB register bug (the inserted jal select_wb doesn't reload caller-saved a1 → WB gains written to garbage).
Will share more progress as I go. Bit busy right now but should have time to continue tinkering over the weekend. Thanks again to 0dan0 and videodoctor — this wouldn't be possible without you!
Boojakascha
very nice! excited to see your progress.
melw
Type D Progress update: Got the font rendering working and that has been already helpful in many ways!
4. Font rendering
I pulled 0dan0's 8×12 bitmap font and now I'm able to render text on the O1 OSD layer — texts are stable in preview, flickery in capture. Now exposed on the lower right corner:
  • WB gains, resolution, exposure (µs), gain — (0x80f82594 / 0x80f82598 / WB 0x80F9075C/60/64 / res 0x80ddc718/71c).
  • Frame counter
  • Live QP, current/floor*(*0x80e974dc + 0x94) and +0x98.
Font renderer/glyphs: 8×12, 12 bytes/glyph, 8bpp (at 0x8033A800).
Nice side effect: with text working, the HUD doubles as a poor-man's RAM viewer — I can print now arbitrary addresses/values on screen. That's how I found the QP floor: dumped the encoder context words live while recording and read them straight off the panel. No serial needed for checks like these.
5. Trying to dump RAM in software (no luck so far)
So, I tried writing dump to the SD from the firmware. Summary for anyone who's tempted to try the same:
  • The FileSys API is reachable from the per-frame hook in preview (SD mounted, idle): open/write/flush/close all map (open 0x80212720, write 0x802137b8, flush 0x80212294, close 0x8021263c; handles are pointers, check != 0).
  • Creating a file fails, BUT if I pre-create the file on the PC — open then returns a valid handle and writes report success.
  • …but even then the data never hits the card. Sub-sector writes (≤512 B) just sit in the FS RAM buffer and never commit; anything big enough to force a physical sector write (≥1 KB) freezes the device.
It's possible that file write is only working in recording mode, or then I'm still missing something else in the file access loop.
Still after the same thing as last time: if anyone has a D unit with serial/UART access, a RAM dump (or even just the live O1 layer pointers during capture) that would be very helpful!
More to follow.
melw
For anyone with a Type D Reels who wants to try what I've been tinkering with, here's a flashable build. It's built on top of videodoctor's D firmware (1600×1200 / ~18 fps base).
What it does
  • Better image quality — recording bitrate bumped ~4× (~31 Mbps), less blocky.
  • On-screen HUD (lower-right corner) — live WB gains, resolution, exposure, gain, and QP (current/floor). Steady in preview, flickers while recording.
Before you flash — please read
  • Type D ONLY. Check your reel type first. Do not flash this on A/B/C!
  • Experimental, tested on a single unit (mine). No guarantees on other D units.
  • Keep a recovery image available (official D stock recovery) so you can roll back. Don't flash without it.
  • Never cut power during the ~30 s flash (black screen = flashing).
How to flash
  1. Copy FWDV280.BIN to the SD card root.
  2. Create an empty folder named NVTDELFW in the root.
  3. Insert the card and power on — it flashes automatically (~30 s black screen), then boots.
If you try it, I'd love to hear how it works — stability, quality, and whether the HUD shows up the same. Thanks!
  • FWDV280.BIN
12
6
What it does
How to flash
Wow, thank you for picking this back up! My serial number is H2825 and I've been using videodoctor's firmware so I have a confirmed D unit. The flash to the melw release in post 594 worked as expected and I ran a 50ft reel through which seemed to run as expected. At the end of the reel, I clicked OK to end, and the close or playback menu popped up and I clicked play. The unit only played 8 seconds so I thought it was just the unit as I don't normally play back on it. I opened the SD card with my PC and I only had the same 8 second clip. I plan to run the reel back through but wanted to post this quick update in case others have the same results. Is there a processing time at the end before you should click any buttons?
Again, operation seemed normal during the capture and the HUD worked as described. The only glitch is the incomplete clip but I want to retry to make sure it's not something I did.
I'll report back when I get time to run the second attempt.
