Where to get a TDA1170 chip?
MacOfAllTrades
257
261
TLDR: I need a replacement TDA1170 chip — where do you all recommend getting one?
I see some on eBay ($15-$20 if I include shipping…) and I see one on Amazon ($15 or so)… I’ll pay said prices if needed but wanted to ask here first.
I see both the STMicro branded ones and an SGS brand on ebay. Anyone ever try the SGS?
FULL STORY:
I recapped the logic AND analog boards on my compact macs (SE, SE/30, and Plus) one to two years ago.
Randomly this week, my SE/30’s screen shrunk to a horizontal line. 😭
I swapped the analog boards between the SE and my SE/30 (same board so wtf let’s see if it’s a logic board or analog board problem) — Result: Something wrong on the SE/30’s analog board! ((i.e. it worked fine with the SE’s analog board swapped in)...
OK — since the SE/30’s analogue board has been recapped and was working fine for over a year, I figured it prob. wasn’t a cap issue, and since the problem followed the analog board — this leaves only the TDA1170N chip (PCB chip label U2).
SO I FIGURED: What the heck! Let’s swap TDA1170 chips from the working analog board to the non-working (and vice versa) and see if the problem follows the chip. Sure enough, the problem was solved on my ‘bad’ board when I put the ‘good’ board’s TDA1170 chip onto the bad board. (And vice versa).
Pro-Tips / Learnings:
  1. TDA1170 Datasheet for reference
  2. Macintosh SE (same as SE/30) analog board wiring schematic for reference — note that Pin 6 on the TDA1170 chip is unused
  3. TDA1170 removal tips:
    1. De-solder all of the 12 pins using you fav. method (I used a wick and a hot iron)
    2. For the big tabs on the IC, wick up what you can, then use a soldering hot air gun to, one-at-a-time, heat up the tab while sturdily pulling on the big metal “U” shaped tab on the other side of the board (use a small screwdriver or other tool or you’ll burn your fingers
    3. Repeat for the 2nd tab, and have a plan for when that sucker comes out as you’ll have a heavy burning-hot metal U-shaped tab to deal with. I ust used the same pick I used to apply pressure in step 3.2 to hold it
  4. TDA1170 re-placement tips:
    1. Clean up those big fat tabs after you’ve removed it so that they’re nice and clean and can again sit flush on the board,
    2. Before you start soldering, make sure you have at least a little bit of each of the 12 pins poking through, if not, you can gently push/bend the pin(s) to ensure they poke through nicely.
  5. The chip itself is actually marked TDA1170N. Noting that “N” on the end. I haven’t looked up the other variants, but fyi that both my SE and SE/30 boards had the ’N’ on the IC’s part number stamp.
Reactions: iantm
MacOfAllTrades
257
261
Ehh I sucked it up and bought two off the bay for 17 bucks or so. i’ll have two in case my other machine’s goes sometime.
Reactions: GreenBar0n
GreenBar0n
119
76
East Bay Area, CA
The only way you could go wrong there is if the chips are fakes - but if you checked out the sellers feedback and he has no history of it, that's a solid purchase.
MacOfAllTrades
257
261
Minor update - the replacement was a success! Back in biz with my computer. I ended up buying an STmicro one. Resoldering was pretty easy as expected. I noticed the big metal “|_|” shaped bracket easily desolders from the chip’s heat-sink wings, as expected.
Reactions: Paralel
iantm
190
88
Great Lakes
My se/30 just started doing this out of the blue. going to try a different analog board first, then see if I can source a chip from somewhere.
wondering if there’s a significant difference between a TDA1170n, sh, s… I’m guessing there is. I found at least TDA1170N in France.
Reactions: MacOfAllTrades
615
I got a couple off eBay: https://www.ebay.com/itm/156313799163
Reactions: iantm
