What the SIT?!
2,267
Tired of dealing with the onion of Vintage Mac archived files?
Struggling to extract game.img.cpt.sit.bin.hqx files with emulators & 20 different programs each with their quirks?
Checkout What The SIT! v2 (all in browser)
https://www.patreon.com/nulleric/posts/what-sit-167390197
Full list of file formats
Inputs
- StuffIt 1.5
- StuffIt 1.6-4.5 (SIT!)
- StuffIt 5.x - store / LZ77+Huffman / Deflate / Arsenic-BWT
- Self-extracting .sea - StuffIt or Compact Pro
- Compact Pro (.cpt)
- MacZip (.zip) - STORED + DEFLATE
- LHA / LZH (.lzh)
- MacBinary (.bin)
- BinHex 4.0 (.hqx)
- AppleSingle / AppleDouble (.as, ._name)
- uuencode (.uu)
- gzip (.gz, .tgz)
- .tar/.mar
- DiskCopy 4.2 (.dc42, .image)
- Raw HFS (.dsk, .img, .hda), bare or inside an Apple Partition Map
- DiskDup+ (DDim/DDp+) .dsk
- MFS 400K
- DiskCopy 6 / NDIF (.img) - including ADC-compressed, with resource-fork-less chunk reconstruction
- UDIF .dmg - koly trailer, zlib/bzip2/ADC/raw blocks
- HFS+ volumes
- ISO9660 (.iso, .toast, .cdr) - raw 2352-byte sectors, Rock Ridge names, Apple resource forks; APM/HFS hybrids too
Outputs
- StuffIt 1.5.1 (.sit)
- PCE .mar
- DiskCopy 4.2 (.dc42) - 400K/800K/1.44MB
- BlueSCSI hard disk (.hda)
- Zip (.zip)
Not possible without these fine Open Source projects and specifications:
Code
- resource_dasm Martin Michelsen / "Fuzziqer", MIT https://github.com/fuzziqersoftware/resource_dasm
- machfs Elliot Nunn MIT https://github.com/elliotnunn/machfs
- Fix-a-Fork file_ext.c, Eric Helgeson & jcs
- stuffit stuffit-rs, MIT OR Apache-2.0, https://github.com/benletchford/stuffit-rs
- compact-pro - cpt-rs, Apache-2.0, https://codeberg.org/cyco/cpt-rs
Reference specifications
- Apple TN1150 (HFS Plus); Inside Macintosh: Files (HFS MDB, B-trees, resource-fork format); Inside Macintosh: More Macintosh Toolbox(resource map layout); QuickDraw/PICT opcode reference
- ISO 9660 / ECMA-119, Rock Ridge & SUSP, Joliet
- Apple UDIF (koly), NDIF, DiskCopy 4.2, Apple Partition Map
Web front-end
- @sakun/system.css Sakun Panditharatne, MIT - classic Mac OS theme https://github.com/sakofchit/system.css/
AlpineRaven
35
10
What I have been doing for a while now - I get what's been happening above - but this App called "FileType.app" is a game changer - if you know the resource codes for it and its so easy - drag and drop then convert. ie. *.sit files which would be stuffit - Create: SIT! and type; SIT5 etc
It has worked very well for me and I have not had any issues afterwards.
Cheers
AP
2,267
Fixing type/creator is handy, and I do do that in this app when I can detect the actual formats - that is a small part of what it does! Things like bad sit files that can be recovered, bad images that are labeled wrong (so many bad iso's that are actually just hfs volumes ripped in toast!) and 100 other "gotcha's" when dealing with mac archives.
2,267
You can now directly preview text files, sound and many image files
Instead of just extracting to a new image you can now convert containers (eg dc6 to dc4.2, bad toast to iso, etc etc)
Some other goodies, check em out!
Froggy814
141
39
Squaw Valley, CA
I have an idea request if it's feasible. Could you make it so that you can load a whole bunch of files that need to be unpacked and it puts them all in an .hda? That would be awesome! I don't know if it's possible though...
2,267
good idea - though counter to the "single" input -> onion unwrap -> output - mabye i could do like infinite mac does and create a ~1gb tmp local storage drive that you can keep adding stuff too, then export? No promises, but would be cool!
Reactions: Froggy814
345
134
The Infinite Mac HD is built from a list of URLs using a python script. I think it uses XADMaster to unarchive all the sit and hqx and whatever files. Stuffit archives include meta data such as folder window size and file icon position. mihaip's fork of XADMaster handles parsing that.
