Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
482
Good eye — that continuous line is real. Zooming into just the photo (no overlay), you can see the trace itself runs right through the ink stamp without interruption — the ink is sitting on top of the solder mask, so seeing copper trace geometry "through" it just confirms it's genuinely part of the board surface at that spot, not a stamp artifact.
But before jumping to a 4-layer buried-plane explanation, I'd want to rule out a much simpler one: U25 and U26 are unimplemented footprints — nothing ever gets soldered there. If Radius's layout software saw those two pad rings as dead space (no populated pins to keep clear of), running an ordinary 2-layer trace straight through the middle of that footprint costs nothing and avoids needing a jog around it. That would fully explain a trace visually "connecting" U25 and U26 without needing anything exotic — it's not really connecting the footprints at all, just happening to physically transit the space between their pads on its way somewhere else on the net.
A true 4-layer power/ground-plane implementation would be a bigger claim, and worth being skeptical of by default: 4-layer boards were meaningfully more expensive to fab in 1986-88, and would be an unusual choice for what's otherwise a fairly conventional double-sided accessory card — though the trace density you've been finding isn't nothing, so I wouldn't rule it out purely on cost grounds either.
A few ways to actually settle it rather than guess:
  1. Check where that line's endpoints actually go. Does it terminate at real component pins elsewhere (i.e., it's just one ordinary net passing through the dead footprint en route from A to B), or does it appear to dead-end at U25/U26 pads specifically with no other explanation for continuity between them? The former supports "ordinary trace through empty space"; the latter is more interesting.
  2. Cross-check against your component-side trace/thruhole layers at the same XY. If there's also a component-side trace at that same location forming part of the same apparent net, that's double-sided routing, not a buried layer — no exotic explanation needed.
  3. Physical test for real layer count, if you want to settle it conclusively: look at a via barrel or the raw board edge (if any is exposed/unmasked) under strong magnification and backlighting. A 2-layer board's via cross-section shows plating only at top and bottom; a 4-layer board shows an additional annular ring or copper reveal partway through the barrel. This is the only truly non-destructive way to confirm internal layers without buzzing things out blind.
If after tracing the endpoints it really does look like an isolated net that only makes sense through a plane, that'd be a genuinely notable find for a card of this vintage — just worth ruling out the boring explanation first given how well it fits (unimplemented footprint = free real estate to route through).
Graphics workstation, now a Mirror Drive Door G4 setup upgrade, is Neolithic 2004 tech along with my software. Like my hardware, I live in the Neolithic when it comes to this kind of thing as well. Taking a file to the edge of the board at a low angle exposes layers like a spectrum. I can determine the number of layers without fooling around with less radical, error prone conventional approaches. ;-)
Fair enough — that's a genuinely better answer than either of mine. A low-angle bevel file exposes the whole stackup at once as a visible cross-section, no probing, no blind buzzing, no hoping a via barrel happens to be visible at the right spot. Metallurgical prep labs call it a "bevel section" and it's exactly the technique used for real PCB failure analysis when someone needs to count layers with certainty — you're not roughing it, you're just skipping the expensive lab equipment version.
One small technique note in case it's useful: keep the bevel angle shallow and consistent (something like 5-10°) rather than steep — it stretches out the layer spacing so thin internal planes don't get lost in file-scratches, and a drop of oil or water on the exposed face while you inspect it under light will make the copper-vs-substrate contrast pop a lot better than looking at it dry.
Good luck with the U25/U26 net — genuinely curious whether it turns out to be the dead-footprint explanation or an actual plane. Either way you'll have a real answer instead of a guess.
Very shallow angle and liquid emulsion are my methods!
Good — that tracks with knowing exactly what you're doing rather than winging it. Let me know what the bevel turns up on the U25/U26 net once you've had a look; genuinely curious which way it goes.
Reactions: Froggy814
482
Here's the first pass, built on the confirmed J1/clamp-network subsystem — "half the data" as promised:
What it shows: the J1 header and its clamp network overlaid directly on the true-scale component-side photo (labels are legible there, unlike bare copper on the solder side), with a pinout sidebar breaking down what's confirmed for pins 2/3/6/7/9, plus notes on the Zener clamp network.
How I handled confirmed vs. unconfirmed, per what we agreed:
  • Green boxes/text = things you've actually buzzed out (J1 pin functions, the clamp network's populated parts).
  • Red dashed line = CR3, called out specifically as untraced.
  • Red text = the Zener common node's destination (a GAL pin 13, designator still TBD).
  • I deliberately left out any long lines running clear across the board to U22 or U2 — I don't have verified pixel coordinates for those ICs' exact locations, and drawing a line I haven't actually confirmed against the image felt like the wrong kind of "confident." Instead those two nets are just stated in the sidebar text (pin 7→U22 pin 7, pin 9→U22 pin 8, pin 3→U2 pin 7) as confirmed facts without a hand-drawn path backing them visually.
Once you've got the component-side buzz-out done, the natural next version would extend this same treatment out to U22 and U2 with real traced paths instead of sidebar text — happy to build that when you're there.
Got it! Thanks for giving me the little available. Understood that the vertical traces on the solder side offer little, if any, clues as to the web of connections between ICs on the board. Horizontal connections buzzed and annotated should tell the tale? Lots of work to do before getting close to there.
That tracks with what we've been seeing. If the solder side is running mostly vertical bus-style traces — signal comes down from an IC, travels a long straight run, and doesn't reveal on its own who it's actually talking to — then it's functioning more like a highway than an intersection. The real "who talks to whom" information lives at the horizontal jogs, which is exactly where a trace is doing the work of steering a signal from one column/IC to another.
Two things worth watching for as you buzz the horizontal runs:
  • Vias are the tell. Anywhere a vertical solder-side run ends and a horizontal component-side run picks up (or vice versa) is a layer change, and that's precisely the junction that decides connectivity. If you can spot and log via locations as you go, that gives you a skeleton of "decision points" even before every horizontal segment is fully buzzed.
  • Watch for false continuity at crossovers. Since the layers are perpendicular by convention, a vertical trace and horizontal trace crossing in the photo aren't connected unless there's a via right at that intersection — worth flagging in your notes explicitly (confirmed via vs. incidental crossing) so future-you doesn't second-guess it later.
Given that, the horizontal/component-side buzz-out is genuinely the higher-value half of the remaining work — the solder-side vertical traces you've already got mostly tell you that a net exists and roughly where it runs, not which IC pins it ultimately ties together. Real slog, but it's the part that actually builds the netlist.
Cool beans! Though not a programmer of note, I’ve heard of vibe coding, I’m thinking of this as vibe diving!
"Vibe diving" is a great name for it — no compiler to catch your mistakes, just a multimeter, a magnifying glass, and faith that the next trace goes where you think it does. Bad continuity reading is basically vibe coding's runtime error.
Enjoy the dive — ping me when you surface with more nets.
Will do. I've found your time stamped operations reports fascinating, could you provide a tight txt file of your processes as displayed while I wait for results. I think others will find it interesting.
Glad it was useful — good luck with the buzz-out, and enjoy the dive. Ping me whenever you want to pick this back up.
482
This one sort of stopped where I'd hoped it would begin, but still interesting I think?
_____________________________________________________________________________________________________________
RADIUS FPD (SE) CLONE PROJECT — CLAUDE PROCESSING LOG
Session date: 2026-08-30/31 (image pipeline) + 2026-09-10 (diagram build)
Tools: Python 3 / OpenCV / PIL / scikit-image / reportlab / poppler-utils
PHASE 1 — PHOTO STRAIGHTENING & TRUE-SCALE CALIBRATION
23:38:50 Rasterized FPD-Schematic-012.PDF (150dpi) to inspect vector
board-outline reference; confirmed it covers J1/crystal/
U2-U7/ROM area only, not full board.
23:39:50 Cropped silkscreen text regions on all 3 uploaded photos
(Solder-V, Component-V, Component-VM) to determine true
orientation by reading text forward/backward.
Result: Component-V and Component-VM both required 180
deg rotation; Solder-V was already correctly oriented.
23:40:32 Rendered 180-degree-corrected previews for visual QC.
23:42:12 Applied gross 180-deg flip + fine auto-detected skew
correction (OpenCV minAreaRect on board contour vs.
background mask) to all 3 photos. Residual skew found:
Solder-V +0.211 deg, Component-V +0.143 deg,
Component-VM -0.141 deg.
23:42:22 Cropped all 3 straightened images tight to board contour
bounding box (20px margin). Board bbox width consistent
across all three: 2732px -- confirms same camera distance
for all shots.
23:46:03 Saved final straightened/cropped outputs, generated
downscaled previews for visual verification.
PHASE 2 — LIFE-SIZE CALIBRATION
User-supplied reference measurement: PCB width = 123mm (calipers).
Calculation: 2732px / (123mm / 25.4) = 564.17 px/inch native.
Derived DPI tags: 1x = 564.2, 2x = 282.1, 4x = 141.0 dpi.
Applied as embedded JPEG DPI metadata (no pixel resampling) so
files print/place at correct real-world scale in any DPI-aware
app. Later regenerated as 8-bit (256-level) grayscale JPEGs at
same three DPI tiers to cut file size ~3x for period-correct
Illustrator 8 hardware (originally a 2004/5 PowerBook, later a
Mirror Drive Door Power Mac G4).
PHASE 3 — AUTO-VECTORIZATION (TRACE + PAD EXTRACTION)
23:57:00 HSV color-threshold segmentation of copper traces
(hue ~55-105, i.e. the teal exposed-copper color) and
through-hole pads (low-saturation/high-value, circular
blobs) on the solder-side image. Masked to board interior
to avoid background contamination.
23:58:07 Extracted 2,420 trace contours + 821 pad circles (solder
side); pickled intermediate geometry.
23:58:25 Built true-scale vector PDF (reportlab): board outline
(stroked), traces (filled teal polygons), pads (filled
gray circles). Page size set from the 123mm calibration.
23:58:30 Rasterized result at 300dpi for visual QC.
23:59:11 Repeated full pipeline for component-side image: 2,358
trace contours, 715 pads. Noted lower reliability here —
less color contrast around IC/ROM footprint silkscreen
boxes causes some non-trace fill artifacts.
00:00:22 Converted both vector PDFs to Level 2 EPS (poppler
pdftops -eps -level2) for native Illustrator 8
compatibility (AI8 predates Adobe's PDF-based file
format, introduced in Illustrator 9).
PHASE 4 — ANNOTATED DIAGRAM (J1 / CLAMP NETWORK)
01:38:14 Cropped candidate regions of the component-side photo
searching for the J1 header and clamp network by e
Reactions: JDW and Froggy814
2,217
@Trash80toG4
I apologize for not having followed your thread until today.
Since you and I do not fear LLMs as some do, I used Gemini to highlight the main points of your two-page thread and compile a progress report. I did that for the sake of newcomers to this thread who otherwise may be overwhelmed by the level of detail posted thus far. But if any of the content below is incorrect, let me know and I will edit it.
📋 Project Overview & Specs​
  • Goal: Replicating the 1986 Radius Full Page Display (FPD) card. This vintage hardware allows a Macintosh SE to output to a portrait monitor.
  • Specs: It runs a 640 × 864 monochrome (1-bit) video signal.
  • Modern Twist: Because original monitors are rare, @Trash80toG4 is designing an FPGA-based addition to rotate the portrait image 90 degrees clockwise so it can display right-side-up on a modern 1024×768 landscape monitor.
🚦 Current Progress Report: How Close Is It?​
Short answer: Early-to-mid phases.
While a massive amount of foundational engineering and data gathering is complete, @Trash80toG4 is still far from an actual working physical clone.
Here is how the project breaks down across its major milestones:
1. Video Rotation Math & Logic — 🟩 95% Complete​
  • The mathematical formula to rotate and center the pixels on a modern screen has been completely solved and verified using small-scale tests.
2. PCB Reverse-Engineering (The Netlist) — 🟨 60% Complete​
  • Completed: @Trash80toG4 has successfully calibrated life-sized photos of the original board and hand-vectorized the entire solder-side (bottom) copper traces. Crucial components like the video header (J1), power filters, and input-protection diode networks have been mapped out.
  • Stuck On: @Trash80toG4 is currently shifting focus to the component-side (top) traces. They must manually "buzz out" (test continuity using a multimeter) the horizontal connections to see exactly which chip pins link together. They also found mystery "hidden traces" and are using a file to shave a spare board down at an angle to see if it is secretly a complex 4 or 6-layer board.
3. Sourcing the Missing Sychronization Clocks — 🟥 10% Complete​
  • The Blocker: To make an FPGA work, it needs a "Pixel Clock" signal. This signal doesn't exist on the external video connector. @Trash80toG4 is currently trying to trace backward through the timing chips to find exactly where on the board they can tap this clock.
4. Hardware Cloning, GAL Decryption, & FPGA Design — 🟥 0% Complete​
  • What's Left: Once the schematic is finished, the custom programmable chips (GALs) on the original board must have their logic formulas extracted. Finally, @Trash80toG4 has to design a brand-new expansion circuit board layout in KiCAD, solder a prototype, and write the custom code for a companion FPGA chip.
💡 Summary for Newcomers​
The thread is a goldmine of data because @Trash80toG4 is sharing an "AI-assisted engineering notebook". He's leveraging AI tool to clean up photography, auto-calculate scaling, write engineering specs, and double-check manual trace layouts.
Right now, the project is a deep, slow-burning detective mission using a multimeter, magnifying glass, and old-school design software to map a 40-year-old circuit trace-by-trace.
Reactions: Trash80toG4
482
Thanks, that summary is very much appreciated! Looks great.
- I won't be doing the schematic capture, Claude will do that from my Solder and Component side "coloring books."
- I imagine the PCB design will be done for me as well. ;)
Hoping the long form play by play might have others wondering how to leverage AI in their own enjoyment of the hobby.
edit: forgot to mention that AI can do all the coding to set up the FPGA side of things! We'll be doing that on a project board as soon as I can locate a wedge to pick up the pixel clock before heading into reverse engineering the balance of the board.
2,217
Well, I wish to humbly thank you for your contributions to this forum!
I'm now looking forward to seeing how your project unfolds over time.
Best wishes,
James
482
This one's pretty cool, while Claude was having trouble nailing down a pinout I did an end run and did it visually before he reported back. Great stuff, it's like dueling abilities and dueling limitations all at once.. Sweet music to my eyes! :)
continue the PCB reverse engineering project
I’ve rotated the Component side of the project so ICs appear upright.
Pinout Verification-2.pdf
Did I get the pinout inputs done correctly?
ISTR you saying that GALs U10 and U9 dffer internally, but are the pinouts the same?
I need a text file for that if different and also for GAL20V8-25LP as I can’t locate that one in the last batch of pinouts?
FPD-Comp-Buzz-Verify-005.pdf
Solid purple VIAS represent connections to the solder side and visible trace segments on the component side. I’ll be running down those first. Then I’ll buzz and connect traces for the IC covered VIAs. After that I’ll buzz the rest of the visible traces for the IC to IC connections. I’ll report each addition when complete for feedback. Would you suggest a revised order of processes to gain an earlier take on schematic capture progress?
FPD-Component-Buzz-005.ai
Can you read the layered AI8 file directly or should I continue breaking layers out to dedicated single layer .PDF files?
The AI8 file is very helpful with the Solder Side trace overlay. I can run the cursor “across the strings” of the solder side traces to play the VIA/Pad overlaps like a visual version of a string instrument. If I were to do manual input schematic capture this would be a great help. Of course you’ll be doing the capture, but it really helps in my visualization process mode.
Last I have on file, we'd left off preparing a clean annotated diagram of confirmed J1/signal-trace connections for a forum post (solid lines for buzz-tested connections, dashed for photo-inferred ones). This is a fresh session, so I don't have any of your board photos, schematics, or AI8/PDF files loaded yet. How do you want to pick this up?Continue the hand-tracing/continuity work
Here's where we left the hand-tracing/continuity work, per my notes:
Open threads on the solder-side/component-side trace-out:
  • What CR3 connects to — traced partway but couldn't pin down where it lands; set aside unresolved.
  • Component-side buzz-testing was still partial when we last talked (solder side was fully hand-traced, component side in progress).
  • You'd traced the red-drawn connection between the Zener diodes to pin 13 on one of the GALs, but hadn't confirmed which GAL designator that is.
  • The board's layer count was going to be determined by filing the edge at a low angle to expose the copper in cross-section — don't think that happened yet.
Since this is a fresh session I don't have any of your board photos, the AI8/PDF schematics, or the Pinout-CHECK files loaded — I can't see anything until you either attach files here, connect your computer/folder so I can read them directly, or just tell me what you found and I'll log it and help reason through next steps.
Whichever's easiest — what would you like to tackle: nail down CR3, confirm that GAL designator at pin 13, sort out the layer-count filing, or something new you've found since we last talked?
GALs — U9/U10 pinouts and the LNC/LP question
Rendered your export at 400dpi to actually read it. U9, U22, U17, U13, U8 are all GAL20V8 (either -25LNC or -25LP), and U10 is a different part, GAL16V8-25LP — worth noting since those aren't pin-compatible with each other.
Good news on U10: its pinout is already filled in on the board and it matches the standard GAL16V8 pinout exactly, pin for pin. Nothing to fix there.
On your -LNC vs -LP question: no, they don't differ — the -25LNC and -25LP suffixes are speed/power/process grade only (propagation delay, power draw), not pinout. Same 24-pin package, same pin-to-signal mapping for all five GAL20V8 parts. That's also why you couldn't find a separate "GAL20V8-25LP" pinout in your last batch — you'd only entered U10 (the GAL16V8) so far; none of the GAL20V8 slots have pin data yet. I put together a text file with both pinouts, cross-checked against the archived Lattice datasheet and a second independent reference — sent above.
One thing to flag on that same export: the DRAM chips (U16/U15/U12/U11) have correct, upright pin-number badges, but the function-name text next to them (SDT/OE, 9RAS, 6W0/I0B, etc.) is mirrored and looks like it's overlapping with a second copy of similar text — genuinely not legible as exported. I traced this to the AI8 file itself: it has two separate pinout-text layers (TXT-Pinouts-SS and New Pinouts), and it looks like both are visible in that export with one still carrying its old solder-side mirror transform. Worth isolating one text layer before your next export so it renders clean.
On the AI8 file — can I read it directly?
Yes, partially. I opened FPD-Component-Buzz-005.ai as raw PostScript text (it's not PDF-compatible, but the AI8 format is human/machine-parseable) and pulled out all 15 layers directly:
Solder Side Traces - FROZEN · TEMP · Component Template · Chip Outlines · Component IDs · TRACES - COMPONENT SIDE________ · CAPS/RESISTORS · VIAs · Layer 15 · Layer 14 · Thruholes · SS-Traces-Adapted for clearance · TXT-Pinouts-SS · New Pinouts · COMPONENT - ALPHA
I can pull raw vector coordinates, text-object placement, and layer contents/counts from that file without an export — useful for structural questions ("does this layer have anything on it," "how many objects," etc.). What I can't do here is visually rasterize/render the AI8 the way I can a PDF — this sandbox doesn't have Ghostscript and I couldn't install it (package fetch was blocked). So: keep sending single-layer PDF exports whenever you want me to actually eyeball something (pinouts, trace routing) — that's still the reliable path. The raw AI8 is a nice supplement for structural checks, not a replacement for visual QC. (Two unnamed layers, "Layer 15"/"Layer 14," might be worth naming or cleaning up when convenient — not urgent.)
On revising the buzz-testing order (FPD-Comp-Buzz-Verify-005.pdf)
Your plan — VIAs with visible solder-side trace matches first, then IC-covered VIAs, then remaining IC-to-IC traces — is a sound sequence. To get an earlier readable take on schematic-capture progress specifically, I'd suggest one adjustment: once you're into the IC-to-IC phase, work it chip-by-chip rather than trace-by-trace across the whole board — fully resolve every pin on one high-fan-out IC (a GAL is a good candidate, since it's the "hub" of custom logic) before moving to the next. A single chip's net list, complete, is something we can can reason about and cross-check against the pinout tables above right away; a board-wide sweep that's 30% done everywhere doesn't get you a checkable unit until much later. Your VIA-first step is already the right instinct for the same reason — it reuses confirmed info instead of blind buzzing, so I'd keep that first.
Send the next addition whenever you've got it and I'll fold it in.
I now have AI9 and AI10 installed on the MDD, but not AI8. Working files I plan to keep in the baseline AI8 format. However, If I save the AI8 file in AI9 or AI10 format to upload, will you be able to read the entire file?
Illustrator 9 10 native ai file format PDF compatible file save layers OCG
8 results
https://www.datalogics.com/adobe-illustrator-and-pdf-compatibility
www.datalogics.com
https://helpx.adobe.com/uk/illustrator/kb/optimize-native-pdf-file-sizes.html
helpx.adobe.com
Short answer: yes, and probably better than the AI8 file has been.
The reason the AI8 file I have now is stuck as text-only for me is that AI8's native format is pure PostScript (the file literally opens with %!PS-Adobe-3.0) — there's no PDF underneath it for a renderer to grab. Illustrator's native format changed at version 9: starting with AI9, the "native" .ai file is actually a real, valid PDF with Illustrator-specific private data tacked on for round-tripping, controlled by a "Create PDF Compatible File" checkbox that's on by default when saving. So if you open your AI8 artwork in AI9 or AI10 and save it out with that box left checked, the resulting file should open for me exactly like the PDFs you've been exporting — I can render it, zoom into pin labels, the works — no manual single-layer export needed on your end for me to just look at something.
Two things worth flagging before you build a workflow around it:
The checkbox matters. If "Create PDF Compatible File" gets unchecked (people do that to shrink file size, which might tempt you given the MDD's constraints), the file reverts to a non-PDF native format and I'm back to square one — same as the current AI8 files.
Layers are the untested part. I'm confident the visual render will work — that's well-documented. What I haven't confirmed is whether your named layers (VIAs, Thruholes, Chip Outlines, etc.) survive as separate, identifiable objects the way I was able to pull them out of the raw AI8 PostScript text, or whether I'll just see one flattened composite image the way I do with a normal exported PDF. Illustrator's PDF-compatible files typically preserve layers as PDF "layers" (Optional Content Groups) when reopened in Illustrator, so there's a good chance that structure comes through for me too — but I'd rather confirm it against a real file than promise it.
Easiest way to find out: next time you're saving something anyway, save one copy that way and send it over. I'll tell you exactly what comes through — render and layers both — before you commit to it as the regular handoff format.
I couldn't nail this one down to my own satisfaction, so I want to be straight with you rather than hand you something I'm not confident in.
I tried a handful of routes — direct downloads of the NEC 1986 memory data book and a couple of other archived uPD41264 datasheets, plus several VRAM pinout references (bitsavers, console5's TechWiki, a couple of datasheet aggregators). Most of those domains are blocked outright by this session's network policy (straight 403s on the connection), and the couple I could reach through the web-fetch tool only returned summarized excerpts of very large scanned PDFs that didn't happen to include the actual pin-configuration diagram — so I've got the chip's family and general signal set confirmed (it's a dual-port VRAM — RAS, CAS, W, DT/OE, SC, SE, DSF, address lines, a random-access DQ port, and a serial SAM port), but not a pin-by-pin 1–24 table I'd trust enough to hand you as ground truth for a chip this central to the design.
Given that, I'd rather not have you delete your existing solder-side-legible pinout on the strength of something unverified from me — that's real, hard-won data. Two ways to close this out cleanly:
If you've got the actual NEC datasheet (or even just a decent photo of its pin-configuration page) sitting on the MDD or wherever, send it over — I can read a PDF or image directly far more reliably than I can fetch one through this session's network right now.
Otherwise, tell me what your existing solder-side pinout currently says for U16/U15/U12/U11, and I'll check it against what I do know of the standard VRAM signal set (and against the RAS/WE/DT-OE-shaped fragments I could already partly make out in your garbled export) rather than generating a fresh one from scratch.
Either way, hang onto that old layer until we've actually cross-checked it — worst case it turns out to be exactly right and you've lost nothing by keeping it a little longer.
While you were doing your thing, I copied a link you were looking at and did it my way. :)
Nicely done — that's a clean, fully legible pinout, and it happens to answer the exact question I was stuck on. Read it at 4x zoom to be sure of every digit:
HM53461P (Hitachi) — 24-pin dual-port VRAM, pin-for-pin equivalent to your D41264C
Pin 1 SC · Pin 2 SI/O1 · Pin 3 SI/O2 · Pin 4 D̄T/ŌE · Pin 5 I/O1 · Pin 6 I/O2 · Pin 7 W̄E · Pin 8 R̄AS · Pin 9 A6 · Pin 10 A5 · Pin 11 A4 · Pin 12 VCC · Pin 13 A7 · Pin 14 A3 · Pin 15 A2 · Pin 16 A1 · Pin 17 A0 · Pin 18 C̄AS · Pin 19 I/O3 · Pin 20 I/O4 · Pin 21 S̄OE · Pin 22 SI/O3 · Pin 23 SI/O4 · Pin 24 VSS
Note the address pins aren't in numeric order around the package — A6/A5/A4 go down the left side, then VCC, then A7/A3/A2/A1/A0 come back up the right side. Worth double-checking against your board when you enter it, since it's easy to transpose those.
The HM53461P isn't literally the D41264C — Hitachi vs. NEC — but this is the same first-generation 256Kb dual-port VRAM family, and those were built to be drop-in pin-compatible across vendors (NEC uPD41264, Hitachi HM53461, TI TMS4161, Fujitsu MB81461 all share this pinout — that's the entire point of "second-source" parts from that era). It also lines up with the fragments I could partly make out in your earlier garbled export — DT/OE and what looked like RAS/WE remnants — so this checks out as consistent with what's actually on your board, not just a same-family guess.
Sent the file above — same format as the GAL pinout sheet, ready to drop into your notes once you've spot-checked a pin or two against the board. Good find on that image; saved me from having to hand you something less certain.
AI & Me = Ebony and Ivory - visual thinker adaptation.
Ebony and ivory, indeed — you look at the board and see it, I look at it and parse it, and somewhere in between we get a net list. Different keys, same keyboard.
Whenever the next round of buzz-testing or a new export is ready, send it over.
  • Pinout Verification-2.pdf
482
Pinout Verification
VRAM Pinout Discrepency – real or did I induce it in reformatting your files?
AI9 file import test:
– layers work?
– does the attached template image come thru or do I need to upload it with AI file?
The pinout files you’ve been providing come thru all messed up and need major work to get into LibreOffice and then after several steps I need to again rework in AppleWorks 6 in order to paste the columns cleanly into Illustrator.
For VRAM update and ROMs, could you try a few new approaches?
- Tab Delimited RTF file to open in AppleWorks spreadsheet to copy columns?
- LibreOffice Spreadsheet format for same.
- Straight AppleWorks spreadsheet file?
- RTF file with a double-spaced column ready to copy into Illustrator? Might be easiest?
Good — all three files check out. Now let me deliver them and cover the rest of your questions.
VRAM pinout discrepancy — not your reformatting, and not really a discrepancy. I flipped the old (solder-side-legible) block right-side up and checked it pin-by-pin against what I gave you. All 24 pin positions match exactly — RAS, CAS, WE, DT/OE, every address line, VCC, GND all land on the identical pin number in both versions. The only difference is naming convention on the two multiplexed buses: your older labels use 0-indexed names (IO0–IO3, SO0–SO3), while the Hitachi sheet I transcribed prints them 1-indexed (I/O1–I/O4, SI/O1–SI/O4) — same four physical pins, same order, just whichever datasheet's own subscript convention. Nothing got scrambled in the LibreOffice/AppleWorks round-trip. Since your old numbers likely trace back to NEC's own documentation for the actual part on your board, I'd lean toward keeping that 0-indexed naming and just use my sheet to confirm pin positions — but it's a style choice, not a correctness one.
AI9 test — layers and the template image. Good news and a caveat. I opened the .ai9 directly (it's a genuine PDF, exactly as expected) and it does carry your layer structure — I pulled out all nine layers by name (Component IDs, Component Template, Chip Outlines, TRACES - COMPONENT SIDE, VIAs, Thruholes, SS-Traces-Adapted for clearance, PINOUTS, COMPONENT - ALPHA) along with each one's visibility flag. The catch: Illustrator stores this as its own private extension, not the public PDF "layers" spec, so a plain PDF render only shows whichever layers were toggled visible when you saved — in this file that was just "SS-Traces-Adapted for clearance" and "PINOUTS," and that's exactly what showed up when I rendered it. That's actually a nice workflow upgrade over the AI8 days: you don't need separate single-layer exports anymore, just toggle visibility on whatever you want me to see and save as AI9 — I get the visual render and the full layer structure (including hidden layers) in one file.
The template image did not come through — zero embedded images in the file. Two independent reasons: that layer is currently hidden, and looking back at the original AI8, "Component Template" only ever held a file-path reference to a JPG on your Mac's drive, not embedded pixel data — so it was never actually inside the vector file to begin with. If you want me to see it, either embed it in Illustrator (not just link it) before saving, or upload the image alongside the .ai file.
On the AppleWorks native file — I'll be straight with you: I can't safely fabricate a genuine AppleWorks 6 (.cwk) binary file. It's an old proprietary format with no accessible library to write it correctly, and a hand-rolled attempt risks a file that won't open at all — worse than not sending one. The tab-delimited .txt I sent should actually get you there in one step: AppleWorks 6's File > Open has a text-import path that reads tab-delimited files straight into its spreadsheet with columns already split, no LibreOffice detour needed. Worth trying that directly and seeing if it shortcuts your whole current chain.
Send the next round whenever it's ready.
Not quite, for a 10 pin IC, the data needs to be formatted as
Looks like that got cut off before the format spec came through — what does the layout need to be for a 10-pin part? (If it's the same idea as the DIP diagrams you've sent — left column pins 1 down to 5, right column 10 down to 6, side by side — say so and I'll match that instead of the flat numbered list I've been using.)
Sorry, I hit return . . .
No worries — go ahead whenever you're ready with the rest of that.
_____________
10
6
Got it — that's the physical DIP layout: left column top-to-bottom for the low pin numbers, a divider representing the package body, then the right column top-to-bottom in descending order so pin 1 and pin 10 end up across from each other at the top, matching how the pins actually sit on the chip. That's the same convention as the datasheet diagrams you've been sending (like the HM53461P image), just without the outline box — makes sense, especially given how you think visually.
Two things before I redo anything:
Which chip is the 10-pin part, and do you have signal names for each pin, or do you need me to identify them? And do you want me to reformat the GAL, VRAM, and ROM pinouts I already sent into this same two-column layout (rather than the flat numbered lists), so everything going forward is consistent?
Ten pin example’s not an IC, just a representation of the double spaced data format easily copy/pasted into Illustrator. To do even better, a two space separation between Pin# and Signal is perfect for centering the pin number in the pad and the signal just outside its outline.
Current AI8 file pinouts are double spaced as I find that format more conducive to getting the text aligned with the life size pin pitch pads.
GAL, VRAM & ROM can be in a single file as described.
Sent — one file, all four chips (GAL20V8, GAL16V8, VRAM, ROM), each split into left/right columns matching the physical pin layout, two literal spaces between pin number and signal, blank line between every entry. Let me know if the ROM's pin-13/pin-14 split or any of the others need adjusting once you've got it lined up against a pad grid.
FPD_Pinouts_Combined
Looks fabulous, just what I requested. Nice work. Wish I’d thought about this particular problem a while back!
Glad it landed right — that format should save you the whole LibreOffice/AppleWorks relay going forward. Now that it's dialed in, any future pinout goes straight into that same layout, so send them whenever you've got new chips to add.
Great, thanks!
Anytime — good luck with the buzz-testing, and ping me when the next round's ready.
  • FPD_Pinouts_Combined.txt
482
FPD-Comp-Pinout-015.ai9
Pinout Verification – FINAL! Am I good to go?
- layer visibility check of file?
- thinking no template to be seen again in this one?
FPD-Comp-Template-015.ai9
- saved with all layers visible
- found the “Include Attached Files” checkbox!
Both files came through clean — this is looking very good, with one real fix needed.
FPD-Comp-Pinout-015.ai9 — layer check:
Only two layers are visible: Thruholes and PINOUTS. Everything else, including Component Template, is hidden — so yes, exactly as you expected, no board photo in this one. That's the correct state for a pure pinout-reference export.
FPD-Comp-Template-015.ai9 — the embed worked. Real progress: this file now carries an actual embedded raster (1386×1683px, properly compressed) instead of a dangling file-path link — the "Include Attached Files" checkbox was exactly the fix needed. I rendered it and can see the real board photo underneath your pinout overlay, pin holes lined up on the actual pads. One small note: this file has only 3 of 9 layers flagged visible (Component Template, Thruholes, PINOUTS), not all of them — probably didn't matter for what you were testing, but flagging it in case "all layers visible" was the intent for some other reason.
Pinout verification — went through every populated chip against real datasheets. Confirmed correct: all four VRAMs (U16/U15/U12/U11), both ROMs (Ux, U19), all five GAL20V8s (U9/U22/U17/U13/U8), the GAL16V8 (U10), both SN74LS393N counters (U6/U7), the SN74F161N (U5), and the SN74F109N (U2) — every pin on every one of those matches the standard part pinout exactly.
One real discrepancy: U3 and U4 (SN74F166N) have pins 13 and 14 swapped. Your file has 13=H, 14=QH — it should be 13=QH (serial out), 14=H (parallel input). I checked this against two independent sources (TI's own datasheet and a components101 pinout) plus my own knowledge of the part, all three agreeing, so I'm confident this one needs fixing on both chips before you call it final.
Two caveats on my own confidence, in the interest of being straight with you: the LS393 and F161 checks didn't get a clean corroborating source this round — several datasheet-site fetches came back garbled or mutually contradictory (I threw those out rather than trust them), so those two rest mainly on my own solid recollection of very standard, well-worn parts rather than a fresh independent citation. Worth a gut-check against a real datasheet yourself if you want belt-and-suspenders before publishing.
Also, cosmetic only: several active-low signal labels are rendering with a stray "AÑ" where the overline character should be — CLRAÑ, SH/LDAÑ, CLK INHAÑ, 1QAÑ, 2QAÑ, LOADAÑ. That's a font/encoding substitution in how the overline glyph exports, not a data error, but worth a look before this goes out anywhere public since it reads oddly.
So: fix the U3/U4 pin 13/14 swap, glance at the overline rendering, and you're good to go.
Sources: SN74LS166 Pinout – components101 · SN74HC166 datasheet – TI · 74LS109 Pinout – components101
Got it, remember asking about those “invisible characters” and left them in. I’ll try copy/pasting the glyph characters into the AI files. Deleted them and them put them back in . . . oopsie!
Ha — mystery solved. Good chance those are literally invisible in the AI font's default encoding but present as a combining overline character, so any font swap along the copy/paste chain drops the glyph and something else fills the gap. If it keeps fighting you, the plain-text fallback (just typing the bar as _L or # after the signal name, like WE_L or CLR#) sidesteps the whole font/glyph problem entirely and reads unambiguously either way — no pressure to switch conventions, just there if the copy/paste route gives you more grief than it's worth.
Good luck getting it sorted — let me know how the next pass turns out.
482
Finish up pinout check from last session.
Hopefully I got the corrections taken care of.
Sourced pinouts for unverified ICs.
Lets see if it all comes together in an AI9 file?
It's coming together well — one fix confirmed landed, one new thing to flag.
The U3/U4 (SN74F166N) fix is in.
Pin 13 is now QH (serial out) and pin 14 is H (parallel in) — matches the correct standard pinout. That was the one real error from last round, and it's resolved. Everything else I re-checked (all four VRAMs, both ROMs, all five GAL20V8s, the GAL16V8, and U2/U5's earlier data) is unchanged and still correct.
The reference pictures are a smart idea — mostly. Pasting in actual datasheet-diagram screenshots as sourcing evidence for U5 and U6/U7 is a good instinct, and the SN74F161N one you added matches the real part exactly, pin for pin. But the picture labeled "SN74LS393" is showing the wrong chip's pinout — it's a 16-pin diagram (1CKA/1CLR/1QA/1CKB.../2CKA...VCC at pin 16), while the real SN74LS393 is a 14-pin part (confirmed — TI's own part listing and several parts distributors all agree on 14-pin PDIP). Whatever page that screenshot came from mislabeled it. The good news: it didn't touch anything — the actual pin table you've got typed in for U6/U7 is still the correct 14-pin version I verified last round. But I'd swap that picture out or pull it before this file goes anywhere public, since as-is it contradicts the correct data sitting right next to it.
The RTF-vs-XLS overline comparison is useful diagnostic work — looks like Rich Text is holding up closer to the real character than Excel does on your end (CLRA- vs CLRAÑ). Still shows up as AÑ on the actual board pinout text in this file, so that part's evidently still mid-fix — no rush, you already know about it.
So: fix the mislabeled reference picture (or drop it), and the pinout data itself is solid. Nice work chasing all this down.
I'll switch to the RTF nomenclature for a final verification. That TI page had almost a dozen chips referenced. I deleted that mess and pasted the only applicable IC identification over the screencap.
That explains it — easy mistake to make pulling a single diagram off a busy multi-part page. Good fix.
RTF as the standard for the overline character sounds like the right call given what that comparison table showed. Send over the next file whenever it's ready and I'll do the final pass.
It was one pinout with a dozen part numbers above it. I'd post a shot of the whole page or maybe upload the PDF next time.
That'll help — if a header lists a dozen part numbers over one diagram, seeing the actual list tells me whether they're all genuinely pin-compatible siblings (same package, same pins) or whether the scan bundled together parts from different families that just happen to share a page. Whole page or the PDF both work fine; either way I'll have the context to tell which pinout actually applies to your board's part.
482
Somewhat disjointed session, wound up mixing and matching two AI streams. :rolleyes:
______________________________________________________________________________________________________________________
260915 Session 2 – pinout check
Appended confusing TI datasheet. Second DIP package would have been the correct image, no?
Final pass, freeze pinout layer? I’ve been adding the pinouts so I can try to make heads or tails of the “topology” of the system. Now wondering if having the pinout layer will help you pull thing together as we get farther along in the cloning process. Specifically, wondering if nailing the functions down before uploading the GAL formulas will be the next step after achieving schematic capture?
__________________
Snapshots of command stream, relates to Claude discussion downthread.
Compacting our conversation so we can keep chatting…
Working through a complex response... ·
__________________
Confirmed — walked through both the datasheet and the "final pass" file.
SN74LS393 diagram: you called it right. On page 1 of the TI sheet, the first DIP diagram (top) is the SN54390/SN74LS390 family — 16-pin, 1CKA/1CLR/1QA/1CKB/1QB/1QC/1QD/GND on the left. That's the one that got mis-pasted into the reference layer earlier. The second DIP diagram on that same page is the genuine SN54393/SN74LS393 family — 14-pin, and it's the correct one for U6/U7.
I rendered FPD-Component-Buzz-036.PDF at 300dpi and pulled the U6/U7 pad data directly to check it against that second diagram, pin for pin:
Board (U6/U7): 1=1CP(clock A), 2=1CLR(clear A), 3=1QA, 4=1QB, 5=1QC, 6=1QD, 7=GND, 8=2QD, 9=2QC, 10=2QB, 11=2QA, 12=2CLR(clear B), 13=2CP(clock B), 14=VCC
TI datasheet (correct diagram): 1=1A, 2=1CLR, 3=1QA, 4=1QB, 5=1QC, 6=1QD, 7=GND, 8=2QD, 9=2QC, 10=2QB, 11=2QA, 12=2CLR, 13=2A, 14=VCC
Every pin position matches exactly. The only difference is that TI's own diagram labels pins 1 and 13 with the bare letter "1A"/"2A," while your board says "1CP (clock A)"/"2CP (clock B)." That's not a discrepancy — "CP" (clock pulse) is the standard alternate designator other vendors of this same part (Philips/Signetics, Fairchild) used on their equivalent datasheets for that identical pin, and your added "(clock A)/(clock B)" annotation is arguably clearer than TI's bare letter. Nothing to change there.
Whole-file pass on -036: rendered the full page and spot-checked every populated footprint (GAL20V8 ×5, GAL16V8, all four VRAM D41264C-15s, both ROM sockets, F161/F166/F109) against the previously-verified data — everything's consistent, no regressions, and there's no leftover reference photo cluttering the page this time, so that loose end is closed. Small bonus: the active-low signals (CLRA, SH/LDA, CLK INHA, etc.) are now rendering as a clean dash in this export instead of the "AÑ" glyph substitution — looks like whatever you changed in your copy source helped, worth confirming it holds once you're back in AI8 native.
Freeze the pinout layer? Yes, but lock rather than delete. It's now your ground truth — every trace you buzz from here on should terminate at a named pin, not an anonymous pad, so you want it visible and immutable, not gone. In Illustrator that's the padlock icon on the layer, not deletion: keep it selectable/visible for reference, disabled for editing. If you want a belt-and-suspenders version, duplicate it first and rename the duplicate "Pinout — ARCHIVE 036" before locking the working one, so you always have a dated fallback if a later layer shuffle ever corrupts it.
Does the pinout layer help pull the topology together — yes, directly. Right now your buzz-test results are a list of "pad A touches pad B." Once every pad has a real signal name pinned to it, that same list becomes a netlist: "U16 pin 8 (RAS) ties to U9 pin 13 (I11/OE)" is something you and I can reason about, group into address/data/control buses, and start drawing as a schematic block. Without the names, it's just wire continuity with no meaning. So the pinout layer isn't a side reference anymore at this point — it's the translation table that turns your physical buzz-testing into an actual schematic.
IC functions before GAL formulas — yes, in that order, and here's why it matters: a GAL's fuse map only becomes a sensible boolean equation once you know what its inputs and outputs mean. If you try to read out U9's equations cold, you get abstract terms like "I2 AND NOT I5 → I/O3" with no context. But if you've already traced that I2 is a horizontal counter bit from one of the F161s, I5 is pixel clock, and I/O3 feeds the CAS line on the VRAMs, that same equation instantly reads as "this is part of the video timing/blanking logic." So the practical sequence is: finish schematic capture (nets) → use the fixed-function chips' actual behavior (F161 = sync 4-bit counter, F166 = 8-bit shift register, F109 = dual J-K flop) to label what each signal group is doing — clock chain, address counters, shift/load timing, sync generation — and only then decode/upload the GAL contents, once you know what functional role is sitting on each of their pins. Doing it in the other order means reverse-engineering boolean logic in a vacuum, which is a much harder problem than it needs to be. This also sets you up well for the eventual FPGA target, since "what does this block do" is exactly the information you'll need to re-implement it rather than just image-copy it.
Inadvertent detour into GPT-5.6 Luna AI via Duckduckgo search assist - responses color coded in blue:
No worries about losing track of any layer in any current file. I've done incremental saves of working files since I started back in 87/88. Began doing the -xxxx year, month, day as a suffix early in the 90s. For files I might want to search at a later date, date becomes a prefix so search results come up newest to oldest. Works for me.
“Frozen” layer is padlocked in current working file, akin to a movie editing “picture lock.”
A polished term would be:
“Picture-locked layer” — a layer that has been finalized and padlocked in the current working file to prevent further edits.
You could also write:
The layer is frozen—effectively picture-locked—and padlocked in the current working file.
If emphasizing that it is complete but still being used for later work:
The layer is locked for editorial changes but remains available for further post-production.
“picture locked layer” seems short and sweet term for us to use?
Yes—picture-locked layer is concise and understandable, especially if your team already knows the film-editing analogy.
Use the hyphen because picture-locked modifies layer:
For a UI label or status, you could shorten it to:
Picture Locked
If the layer itself is literally padlocked, Picture-locked layer clearly communicates “finalized against content changes, but still available for downstream work.”
I’m liking this methodology: compose a complex, multi-part initial question for you to develop a complex, more comprehensive single answer. Would this be the the most efficient course of interaction? Is there a better approach?
Iterative question/answer in real time seems a total waste of time to me. Word processor development gives me the time to arrange my thoughts.
Good, this is the way to go forward. Thanks for the breakdown of processes.Yes—developing your thoughts in a word processor and sending one well-structured prompt is often the most efficient approach for complex work. It gives me the context, goals, constraints, and preferred output format at once, which reduces clarification loops and inconsistent answers.
Good, giving your reply breakdown a lot of thought. Generally, what I’ve been doing seems like the way to go forward. Thanks for the breakdown of processes.
You’re welcome. Your approach—thinking through the problem first, then providing a consolidated prompt—is a strong way to get more coherent and useful results. A focused revision pass afterward can refine the answer without the inefficiency of many small exchanges.
Back to Claude:
"Picture-locked layer" — good term, adopted. It's exactly the concept I was reaching for with "padlock the layer," and the film-editing analogy fits how you already think about layer states (frozen but still referenceable downstream), so let's use it going forward for that AI8 layer state.
On the batched-prompt-in-a-word-processor question: yes, that's genuinely the more efficient mode for this kind of work, and not just as a consolation — here's the actual reasoning, not just agreement. This project has a lot of state (a dozen-plus ICs, a layer-naming convention, a pinout-format convention, an in-progress glossary of clarified terms) that I have to hold in context on every reply. A single well-structured message that bundles several related questions lets me answer them against the same context pull and cross-check them against each other in one pass — which is exactly what happened with the -036 file today: one message got you a datasheet confirmation, a full-file consistency check, a layer-freeze recommendation, and the GAL-sequencing strategy question, all reasoned together instead of four separate threads that might drift out of sync with each other. Live back-and-forth trades that coherence for speed on any single sub-question, which isn't a trade you need here since none of this is time-critical.
Where I'd refine it, not replace it: keep the screenshot/image habit inside those batched messages rather than trying to name things in prose first. Today's detour happened because you went looking for the word for something you could see on your screen. You don't need to — a screenshot of the Layers palette with "what's this called / how do I do X" is often faster and more reliable for me to work from than a description, because I can read the actual icon/state directly rather than guess from your description of it. So the shape I'd suggest: draft your multi-part question in the word processor as you've been doing, and wherever a question is really "what is this / how do I do this to this," drop in a screenshot at that point rather than trying to word it — you get the batching benefit without the terminology-lookup friction that sent you to another tool this time.
One more offer, given how much project-specific vocabulary we're accumulating ("picture-locked layer," the two-space pinout convention, "Neolithic" workflow, etc.): I can keep a running short glossary of these as part of the project file, so if a term slips your mind mid-draft you can just check it rather than going hunting — happy to spin that off as its own quick-reference text file alongside the pinout deliverables if that'd help, just say the word.
Yes indeed, let's have it!
Searched for “picture-locked layer” using Duckduckgo’s GPT-5.6 Luna AI assist and it seemed to know the context of our discussion, so I thought I was here. ::)
FPD Field Glossary​
Working terms and conventions for the Radius Full Page Display reverse-engineering project — the vocabulary we've settled on, so it doesn't need re-deriving mid-draft.
13 terms
Illustrator & LayersPinout DraftingBoard & TestingChip Family Notes
01
Illustrator & Layer Conventions​
A layer padlocked in the working AI8 file to mark it finalized. Stays visible and selectable for reference; closed to further edits. Borrowed from the film-editing term "picture lock" — a cut that's done, but still there for everything built on top of it.
Component-side viewpoint
Standing rule for every future export: drawn from one consistent component-side view. Solder-side content is mirrored at export time to match, so no per-file mirroring confusion carries downstream.
AI8 / AI9–AI10 round-trip
Working files stay in native AI8 (pure PostScript) on principle. AI9/AI10 — Illustrator's PDF-compatible format — is used only for upload and review, with Include Attached Files checked on export so embedded reference images survive the trip intact.
Ux placeholder designator
Stand-in reference designator for the "Lo" ROM chip, whose own silkscreen marking is worn illegible. Holds its place until the real designator can be confirmed some other way.
02
Pinout Drafting Format​
Two-space pin format
"pin_number" + two literal spaces + "signal_name" — no tab character. Centers the pin number over the pad graphic and sets the signal name just outside its outline when pasted into Illustrator.
Double-spaced entries
A blank line between every pin entry, so pasted text lines up with the board's true, life-size pin pitch rather than Illustrator's default line spacing.
Mirrored DIP columns
Left column ascending top-to-bottom, right column descending top-to-bottom — matching the physical footprint as seen from the component side, not a plain 1-to-N pin list.
03
Board & Testing Conventions​
Buzz-testing
Manual continuity testing with a multimeter to find which pads and traces are electrically connected. The primary method driving schematic capture on this project — no logic analyzer or oscilloscope in use.
Solid-purple via
Marks a via with a confirmed connection through to the solder side, plus a visible trace segment on the component side. First priority in the buzz-testing order, ahead of IC-covered vias and IC-to-IC traces.
Sense line
J1 pin 6. Pulled to ground by the FPD display itself when connected. The card's video drivers check this at startup and shut down if it isn't pulled low — no display detected, no output.
04
Chip Family Notes​
SN74LS393 vs. SN74LS390
Easy to mis-cite — both sit on the same TI datasheet page. The LS390 is 16-pin (dual decade counter); the LS393 is 14-pin (dual 4-bit binary counter) — the one actually on this board, at U6/U7.
CP vs. A (clock pin label)
TI's SN74LS393 diagram labels the clock inputs plainly as 1A / 2A. This project's pin data uses 1CP (clock A) / 2CP (clock B) instead — same physical pins, clearer label, not a discrepancy.
GAL20V8 vs. GAL16V8
U9, U22, U17, U13, U8 are 24-pin GAL20V8s (-25LNC / -25LP speed grades — pin-compatible, same pinout). U10 is a 20-pin GAL16V8, a genuinely different pinout, not just a smaller GAL20V8.
FPD reverse-engineering project — living reference, grows as new terms get settledupdated 2026-09-15
That's the glossary, live. It's got a filter box up top so you can jump straight to a term instead of scrolling, and four sections so far: Illustrator & Layer Conventions (picture-locked layer's in there now), Pinout Drafting Format, Board & Testing Conventions, and Chip Family Notes (including the LS393-vs-LS390 mix-up and the CP-vs-A labeling note from today). It's a page I can reopen and add to in place as new terms come up — no need to rebuild it each time.
On the DuckDuckGo/Luna coincidence — that's Duckduckgo's AI assist reading its own search results for "picture-locked layer" (the film-editing term is genuinely well-documented), not any connection to this conversation. Separate assistant, separate context, no way for it to know what we'd been discussing. Good instinct to flag it and check rather than assume, though.
Great! It's on to buzzing the Component Side now that the .035 file has been confirmed and incremental .036 version tracing will be coming up fairly soon.
Good place to be — pinouts are locked in, so every pad you buzz out on the component side now resolves straight to a named signal instead of a bare number. Send the .036 tracing whenever it's ready; I'll cross-check the new connections against what's already confirmed and flag anything that doesn't square with the pinout layer.
482
New file config check:
New AI9 file created for buzzing Component Side connections from Solder Side View, giving access to all signals and the VIAs obscured by ICs topside.
- at .036 revision level, component side file is Picture-Layer Locked
- at .037 and consecutive revision levels, traces buzzed and annotated on solder side file will be reflected vertically and added to then current working file of component side.
I’m thinking that uploading both files per session will let you see what I’ve accomplished and check for anomalies between files?
Does the Solder side view align correctly with the component side view in these files?
Saved AI9 files with attachments and all layers unlocked. Are you now able to see the full set or again only a subset of the layers? Last time I tried this only three layers were available to you.
Alignment: close, but measurably off — worth a nudge before you build on it. I overlaid both mounting holes (a reliable, unambiguous landmark) after mirroring the SS file back to the CS orientation. Both holes show the same offset: the SS content sits about 2.8mm to the left of the CS content, with negligible vertical drift (~0.1mm, within measurement noise). I confirmed the scale first — the board's rendered width in these files works out to 123.7mm against your known 123mm, so the mm figures above are real, not a rendering artifact. It's a consistent shift in one direction at both landmarks, not a rotation or scale mismatch, so it's almost certainly a placement offset from however the SS content got positioned/mirrored (flipped about the wrong reference point, or nudged by eye rather than snapped to a shared guide). Worth correcting now, before .037 starts layering new traces on top of it — a 2.8mm creep is small pad-to-pad but will make solder-side and component-side annotations increasingly hard to eyeball against each other as you add data. I sent the crop above so you can see exactly what I'm seeing — the green ring is the CS hole, red is the SS hole, mirrored.
Layer visibility — full set this time, but not for the reason you'd want. I can see everything that's actually visible when the file renders: the CS file this pass shows the full pinout layer and the new purple buzz-trace connections and the pad color-coding, which is more than the plain PDF I checked last session — so nothing looks suppressed or missing. But here's the catch: I checked the file's internal structure, and neither .ai9 has Illustrator's "Preserve Editing Capabilities" layer data embedded — only one small marked-content region shows up in each file (a single hidden auxiliary image, not a real per-layer breakdown). That's almost certainly what "only three layers" meant last time too: without that data, most of your named layers (Pinout, Address & WTF?, Nancy's, etc.) get flattened into one anonymous content stream on export, and only a couple of special elements get their own marked-content tag. Practically, this doesn't cost us anything for what we're doing — I read positions, colors, and text straight off the rendered page either way — but it does mean I can't isolate or cite content by layer name from these particular files, only by what's visibly there. If you ever want that ability restored, it's the "Preserve Illustrator Editing Capabilities" checkbox at export (unrelated to "Include Attached Files," which is working fine — that's why the embedded image came through).
Two-file-per-session is a good call, for what it's worth — cross-checking CS against SS each time is exactly what would have caught that 2.8mm drift before it became a bigger problem.
Didn’t see that drift, don’t think it was there at first. I tried to upload the SS file with both SS and CS templates attached. No go as it was over 30MB(?) so went back to the MAC to “save as” AI9 version for the upload. Likely got joggled in the process? That’s a very large error, not something I often do.
I’ll look for "Preserve Editing Capabilities." Haven’t seen that in AI8 dialog for an AI9 version. That’s a checkbox in the “save as PDF” dialog in AI8.
That makes sense, and it explains the size jump too (both your uploads came in around 15MB each once the photo template was re-attached, versus 6.5MB for last session's plain PDF export). Good instinct connecting it to the resave — a couple of technical notes, one correction on my part:
On "Preserve Editing Capabilities" — I need to walk that back. I checked the file more carefully after your question, and I was wrong to say the layer data wasn't preserved. It is — there's a large embedded block in there (Illustrator stores it as roughly 150 small private data chunks tucked inside the PDF) that holds the complete native document, layers and all, for reopening in Illustrator. What threw me off originally was checking the public PDF layer mechanism (the one Acrobat/generic PDF tools use), which is nearly empty in this file — but that's not the same thing as your document's actual editing data being gone. Illustrator's own private format is proprietary and effectively unreadable by anything outside Illustrator itself, which is why I can't pull layer names out of it — but nothing was lost on your end, and there isn't a missing checkbox in your AI8/AI9 dialog you need to go hunting for. That was my mistake mapping newer Illustrator/Acrobat terminology onto your version's dialog — sorry for the wild goose chase there.
On the drift — a plain "Save As" shouldn't move anything, but removing the CS template probably did. The shift is too clean to be a stray nudge: it's the same ~2.8mm in the same direction at both mounting holes, with no rotation and no scale change — that's the signature of a coordinate-origin shift, not a hand slip. The likely mechanism: Illustrator computes where the PDF page origin sits relative to your artwork based on the overall bounding box of everything in the file. When you pulled the CS template back out to get under the 30MB limit, the file's total bounding box changed shape, and Illustrator re-anchored the page origin to match — which shows up as every coordinate in the export sliding by a fixed amount, even though nothing in the drawing itself moved relative to anything else in that file. So: not something you did by hand, and not a habit to worry about — it's a side effect of how AI fits the page to content on export.
The practical fix is to stop letting Illustrator auto-fit the page to content between saves: pick one physical landmark — the left mounting hole is a good one, since it's unambiguous and present in every file — and set it as a fixed ruler zero-point in both the CS and SS documents' Artboard setup, rather than "fit to artwork." As long as both files' artboards are pinned to that same physical reference, adding or dropping the template layer won't move the export origin, because the origin is locked to the ruler, not recalculated from content bounds each time.
I’ve been considering a different approach. I can keep the AI9 files clean, no templates in uploads. I’ll upload the JPEG files you cleaned up that I’m using as templates alongside the new AI9 files. You can the use whichever JPEG matches your need. I’ve scaled them by 50% to fit the artwork and it’s working out very well.
How does that sound? Try these, you'll need to reflect the CS pic for the SS viewpoint, that's what I've done for the working file.
That sounds right, and it directly kills both problems from last message at once: no more 30MB uploads, and — more importantly — no more embedded template bouncing the file's bounding box around between saves, which was the actual mechanism behind that 2.8mm drift. Clean AI9 files plus separate reference photos is a more stable setup than what you had, not just a smaller one.
Got both images and sorted out which is which: 2aca7907 (1386×1697) is the Solder Side — bare vias and traces, connector edge visible, no ICs. df3b0683 (1386×1683) is the Component Side — matches the size of the template image that was embedded in last session's file almost exactly, so it's consistent with what you've been using.
One thing worth flagging on the "reflect the CS pic" point: I checked the Component Side photo as uploaded, and it's currently rotated 180° from reading orientation, not mirrored — I rotated it back and the board text ("RADIUS FULL PAGE DISPLAY TM," etc.) comes up perfectly legible, not backward. That's just how it was oriented when saved, and it's a different operation from the mirror you're describing: a 180° rotation flips both axes at once, while what you actually need for the SS viewpoint is a single-axis mirror (left-right flip), which produces backward text — a genuinely different-looking result. So there are two separate steps buried in "reflect the CS pic": right the rotation, then mirror it. I'll do both myself on my working copy each time you send the plain photo, so you don't need to hand-prep a pre-flipped version for my sake — send it however it comes out of your camera/scan workflow and I'll orient it to whatever I need for the comparison at hand.
That’s my bad, When I started doing the component side I rotated all artwork so that the IC outlines were consistent with pinout convention to make things a bit easier for you. I can work any which way, wetware has no problem using backward pinout data, rotated or not in my case. ;-)
Sounds good — send the next pair whenever they're ready and I'll check the mounting holes again as a matter of course, so we'll know for sure either way.
I'm not slavishly following the template. Camera was centered, so that section is good. Top and Bottom of pic are off, stretched a bit from single point distortion.
Good context — that lines up with what I'd expect from a single-shot photo rather than a flatbed scan: distortion grows radially away from the lens's optical center, so the middle of the frame stays geometrically honest while the top and bottom edges stretch outward. Both mounting holes I checked sit fairly close to the vertical center of the board, which is likely why that particular measurement held up cleanly — but it's a useful flag for anything I ever try to measure or register near the top or bottom edge of that photo specifically; I'll weight those regions as approximate rather than precise, and lean on your hand-traced judgment there rather than the raw photo geometry.
Sounds good, we’re on the same distorted page!
Ha — good pun. Send over the next batch whenever it's ready.
Reactions: Froggy814
482
Mini update:
- I've annotated the pinouts for every IC with Claude's guidance
- Completed the Solder Side tracework
- Reoriented the original point of view from PDS on bottom Solder Side to ICs upright either view.
- Hairline Solder Side traces ovelay views showing connections/VIAs between layers
- Input much of the visible Component Side traces
- GAL/TTL/Connector Net is the target, VRAM's a long way off
This file is set up for buzzing the Component Side from the solder side connections.
In Illustrator I can run my fingers across those solder side strings to see connections light up.
It's on to buzzing away!
  • FPD-SS-Component-Buzz-036.PDF
482
Buzzed most of U22, the VIAs within its footprint and some long runs toward the top I wanted to get in the works. Interesting mess. Does anything come together at this very early point?
A few real threads are already visible, even this early — nothing like a system yet, but three things worth flagging (I read these off the actual embedded text, not the mirrored pixels, so pin numbers below are solid):
U22's low inputs tie into the resistor pack, and two of those lines also land on the VRAM. The 4-resistor pack up top feeds down into U22 pins 1–4 (I0/CLK, I1, I2, I3), and along the way, two of those runs are firm-connected at U15's pins 5 and 6 — I/O1 and I/O2, on the VRAM's random-access (parallel) port. That's worth keeping an eye on: if it holds up as more of U22 and the VRAMs get buzzed, it'd mean U22 is reading or gating part of the VRAM's data path rather than just routing past it physically. Could also turn out to be incidental crossing rather than a real shared node — too early to tell which, but it's exactly the kind of junction worth tracking now before more traces pile on top of it.
U9 feeds U10's clock. A clean, independent firm connection: U9 pin 9 (I8) runs straight to U10 pin 1 (I0/CLK). One GAL apparently driving another GAL's synchronous clock input — plausible if U9 is generating some derived strobe or gated clock that U10's logic runs on. Small, but a real GAL-to-GAL link, which is the kind of thing that starts making the "topology" argument from a couple sessions ago concrete.
The WTF one is probably a red herring, in a specific way. On U5 (SN74F161N), the four parallel-load data inputs plus ENP — pins 3 through 7 (A, B, C, D, ENP) — all show continuity down to pin 9 (LOAD‑bar). Tying data inputs directly to the load-control pin isn't a sensible logic net, so before chasing it as a real signal, I'd check whether there's a resistor pack sitting electrically between those pins and a bias rail (VCC or GND) — this board already has at least two other resistor packs doing exactly that kind of multi-pin pull elsewhere (the one feeding U22 above is one). If those five pins are all just riding the same pull-up/pull-down pack rather than talking to each other, that'd explain the continuity without it meaning anything about U5's actual function. Worth a quick continuity check against a known VCC or GND pin to settle it either way.
Nothing here contradicts any of the pinout data already verified, and that's really the right bar for "does it come together" at this stage — U22's thread (into the VRAM) is the one I'd keep pulling on next, since it's the closest thing to an actual functional link so far.
This is very tedious, thinking I might just desolder everything but the VRAM, U9 and maybe the ROM Sockets. So much easier and I can install wire wrap sockets for anything removed if I need to bodge a trace.
I get the appeal — pulling a chip turns "probe the mirrored solder-side view and hope the registration held" into "look straight down at bare pads from the top." That's not a marginal improvement, it removes the whole obscured-via problem for anything you socket. A couple of things I'd want settled before doing it wholesale, though, not to talk you out of it, just so it doesn't cost you something you can't get back.
The GALs are the one category where this isn't a "worst case, buy a replacement" situation. The 74-series logic (F161, F166, F109, LS393) is generic and cheap — if a leg snaps pulling one, you drop in a new one and you're not out anything but a part. The GAL20V8s and the GAL16V8 are different: they're programmed with Radius's actual logic equations, and that program only exists on this board. If one of those gets damaged coming off — a lifted pad, a cracked pin — whatever equations it held are gone for good, not "hard to find," just gone. So if "everything but VRAM/U9/ROM" includes the other four GALs (U22, U17, U13, U8, U10), I'd flip the order on those specifically: read each one's fuse map with a GAL programmer before it comes off the board, not after. That's not just risk mitigation either — pulling a GAL is the only way to read it in the first place, since that has to happen out-of-circuit in a programmer's socket. So there's a real upside hiding in the same step: if you've got access to a GAL programmer, desoldering the GALs is your one chance to archive their logic digitally, and once that's done the physical chip stops being irreplaceable — worst case after that, you've lost a socket, not the design.
Second thing, smaller: you were planning to find this board's layer count by filing the edge, and I don't think that's happened yet. Worth doing before a mass desolder session rather than after — a 2-layer board tolerates repeated reheating a lot better than a 4-layer one, where a buried via can get damaged without you ever seeing it happen. Cheap to check first, expensive to find out the hard way mid-desolder.
If it were me, I'd sequence it: pull the 74-series chips first — good practice for heat control on 40-year-old pads, using parts you can replace without a second thought — then decide on the GALs once you've got a feel for how the pads on this specific board behave, and only after their fuse maps are safely read out. VRAM and ROM staying put sounds right regardless; nothing to gain there and the VRAM pinout's already fully nailed down.
No big deal for removal as all GALs and ROMs are socketed on the board. The security fuses are blown, but “glitching” a readout of the formulas isn’t a big deal these days.
The TTL I’ll just lop off at the legs and desolder each pin individually, same with the socket legs. Afterward, wire wrap sockets installed and new TTL components installed.
That resolves the part I was actually worried about — sockets mean pulling the GALs and ROMs costs nothing, there's no pad or pin at risk either way, so "everything but VRAM/U9/ROM" is a much lower-stakes plan than I was picturing. And the security-fuse glitch readout is a legitimate, well-trodden technique at this point for exactly this situation (blown security bit on an old GAL/PAL), so that's not a real obstacle either — good to know it's already accounted for.
Lopping the legs at the body before desoldering pins individually is the right call on the TTL, too — that's the technique that avoids the actual failure mode (rocking a whole package under heat and lifting a pad), so I've got nothing to add there.
One small upside worth noting now that the GALs are risk-free to pull: there's no reason to wait on reading their fuse maps. Since unplugging them costs you nothing, you could dump all five GAL equations whenever it's convenient — before, during, or after the TTL rework — rather than treating it as a step that has to happen at a particular point in the sequence.
Haven’t got the equipment or know-how for the glitch approach to the things myself. I’ve got a friend who did that with the GALs of my Performer Accelerator. That’s been cloned 1:1 and reproduced for the SE. Something like three simplified variations have been developed by others. I’ll lean on him or another boffin for that end of things.
Good setup to have — someone with hands-on glitching experience on real hardware beats working from documentation alone, and it means that step isn't gated on your own timeline at all. You can keep moving on the desolder/socket work and the buzz-testing in parallel, and hand the GALs off whenever it's convenient for him rather than needing to sequence around it.
Yep, been planning that division of labor all along.
I may see if I can get a third card if I can find one? I need to get the SE set up to test both cards before doing any desoldering. That’ll require running the card’s outputs to the “RGB” inputs of my Extron Scaler to get its little image centered up on a 1080p HDMI panel.
Smart sequencing — confirming both cards actually work before anything gets desoldered means you'll know for certain any later problem is something you did, not something that was already wrong going in.
One thing worth checking before you wire it up: the FPD's output isn't RGB, it's monochrome TTL — a single video line plus separate H/V sync off J1 (pins 3, 7, 9 in your pinout), not three color channels. Most "RGB" inputs on scalers like the Extron are built for either analog RGBHV or genuine TTL digital RGB (the latter's common on scalers meant for CGA/EGA-era gear), so getting a picture usually means tying that one video line to all three color inputs rather than finding three signals that don't exist — worth confirming which mode your specific unit's RGB input actually expects before you build the cable. The other thing I'd check is the scaler's supported sync range: ~68.8kHz horizontal paired with ~67Hz vertical is an unusual combination (high line rate, non-standard low field rate), so auto-detect on some scalers can balk at it even when the electrical levels are otherwise fine — if the Extron has a manual timing entry mode, that's worth knowing about ahead of time rather than discovering it's needed after the picture won't lock.
On the third card — happy to poke around vintage-Mac channels beyond eBay (68kMLA, collector Discords/Facebook groups, etc.) if you want a hand watching for one; just say the
Tying the co-axial single bit output from my Radius Two Page Display card to RG&B inputs was the way I got it up and running on a modern LCD. That’s why I put RGB in quotes. It didn’t sync up correctly, but I took a shot at it with the Extron RGB-HDMI 300.
Dunno if you can get thru, they’ve set up a system to keep bots out as best they can.
https://68kmla.org/bb/threads/good-reasonable-hdmi-scaler-extron-rgb-hdmi-300-a.35750/
Couldn't get through to 68kMLA — you called it, their bot-blocking (Anubis) shuts out fetch tools same as it does most bots. Went to Extron's own spec sheet for the RGB-HDMI 300 A instead, which turned up something worth knowing before you try this again on the FPD card.
Documented specs: horizontal sync 30kHz–100kHz, vertical 24Hz–120Hz, sync input level 2.75–5.0Vpp, and it wants RGBHV, RGBS, or RGsB — analog video modes. The TPD/FPD's known sync rates (~68.8kHz H, ~67Hz V) sit comfortably inside that frequency window, so whatever kept it from locking on the TPD probably wasn't a frequency-range problem — the scaler is rated for faster and slower than what this card puts out.
Two more likely culprits, given that: sync polarity, and signal type on the color channels. TTL-level sync (Mac video sync is usually active-low, i.e. inverted from what some gear expects by default) trips up a lot of scalers that don't auto-detect polarity correctly — if the Extron has a sync-polarity setting or DIP switch, that's worth checking before anything else. Separately, "RGBHV" specifically means separate H and V sync lines feeding their own inputs, distinct from RGBS or RGsB where sync rides on the green channel or a combined line — if the coax video line went to R/G/B while H and V went to their own pins, that's the right mode in principle, but worth double-checking the scaler didn't default to expecting sync-on-green instead and just never found it on green (since green in your setup is carrying video, not sync). And separately from the sync question: that coax line is presumably a full 0–5V TTL swing, not the ~0.7Vpp an analog RGB input expects for video — that alone wouldn't stop sync from locking, but it would explain a blown-out or clipped image even once it does lock, so a simple resistor divider to knock the amplitude down before it hits R/G/B might be worth having on hand regardless.
Sources: RGB-DVI 300 / RGB-HDMI 300 A Specifications
Didn’t do more than this first run at it w/o reading the documentation. It worked, I think that’s called a beat pattern? That was it for TPD playtime, not all that interested in it, unlike the FPD, it can’t be cloned.
Went on to getting the far superior SuperMac Spec/8 SI card up and running and got it almost perfectly dialed in. It’s for the Color Quickdraw capable Iisi and SE/30 030 PDS.
That striping is a good sign, oddly enough — it's exactly what you'd expect from a pixel-clock mismatch rather than a broken connection or a bad sync polarity guess. "Beat pattern" is a fair name for it: the scaler's ADC doesn't have a real pixel clock to lock to on a source like this, so it derives a sample clock by multiplying your H-sync frequency by an assumed pixel count per line. When that assumed count is off from what the TPD is actually putting out, the sampling grid slowly drifts against the real image and you get that repeating vertical interference — same underlying mechanism as a scan-rate converter beating against an odd source, just showing up as static bars instead of a rolling one since nothing's actually moving relative to itself.
The SuperMac card locking up clean on the same scaler is a nice confirmation, actually: it tells you the scaler and your wiring approach are both fine in general, and the TPD's stripes are specifically about it being a non-standard, no-pixel-clock-reference source rather than something wrong with the setup. Good thing to have banked before you get to the FPD, since it's the same era and same general TTL-mono heritage as the TPD — I'd expect the same striping on a first pass there too, for the same reason, not a sign anything's wired backward.
If you ever want a clean picture rather than just a synced one — on the FPD once you get there, since the TPD's not worth the effort — the usual fix for this exact symptom is a scaler with a manual clock/phase adjustment (sometimes called "dot clock" or just "clock" in the OSD), which lets you hand-tune the assumed pixels-per-line until the beating disappears. Worth checking whether the RGB-HDMI 300 A exposes that anywhere in its menu; not all of the fixed-function ones do, but it's the right thing to look for if it's there.
Getting FPD to show up ugly like that is all I need to do. No dialing in, just test them for function. FPD card’s output will be run through the FPGA Project Board for rotation transform and then sent out the card’s HDMI port.
That simplifies it a lot, then — the striping is irrelevant to what you actually need out of this step. If the picture shows up at all, ugly or not, that's sync locking and pixels moving, which is all a function test needs to prove: the card's alive, the crystal's running, and it's putting out valid video and sync. No reason to touch the scaler's tuning for that.
Good to have the endpoint confirmed too — the FPGA board doing the rotation transform and driving its own HDMI out means the Extron path is really just a bring-up tool, not anything that needs to survive into the final pipeline. Once you're tapping the TTL video/sync for real, it's headed to the FPGA board's input, not through a consumer scaler at all, so none of today's scaler quirks need to follow you there.
Yeah, no hobbyist level scaler or RGB-to-VGA thingie can do the image rotation, so heading into FPGA for basically everything was the plan.
For future consideration: the two FPGA Boffins on the forums had green lit my original VRAM capture approach which was insane in hind sight. Going at it this way is so much more direct. They were telling me I should really put the GALs/TTL in the FPGA. So wondering if the FPD card can be cut down to just the bits I’m not planning to desolder and let a more capable FPGA project board do the rest?
____
editing in a missed step in blue here:
Yeah, this makes sense as the next step, not a departure from the plan — it's really just extending "FPGA does the rotation transform and HDMI out" one layer further back to "FPGA does the rotation transform, HDMI out, and impersonates all the glue logic." Once you've got the GAL fuse maps read out and the TTL functions nailed down via schematic capture, there's no functional reason those chips need to stay in the physical signal path — the FPGA can generate the exact same waveforms at the exact same board positions, just synthesized instead of hard-baked into silicon.
The natural split is the one you've already landed on empirically: VRAM, U9, and the ROM sockets stay real, everything else becomes FPGA. VRAM has to stay physical because the Mac's own slot-manager driver is writing framebuffer bytes directly into it through the card's declared address space — that's a hard dependency on real address/data/control pins living where the Mac's bus expects them, not something you'd want to proxy through an FPGA unless you were also emulating the whole bus interface. Same logic for the ROM — it's what makes the FPD card enumerate correctly as a Slot Manager device at boot, and Declaration ROM contents plus the physical ROM-select/OE timing are exactly the kind of thing you don't want to add uncertainty to while you're also swapping the logic layer.
Mechanically, the cutover is pretty clean given how you're already planning to do the rework: every net that used to run from a chip you're pulling to VRAM, U9, ROM, or the J1 connector gets, instead of going to that chip's old pin, wired out to a matching FPGA I/O pin — using the wire-wrap sockets you're installing anyway, or flying leads where there's no socket. The FPGA then reconstructs each of those signals in real time from the logic you've extracted, and drives it onto the same via/pad the original chip used to. Nothing about the VRAM's or ROM's own footprint needs to change; you're just changing what's driving their control/address lines upstream.
Three things worth flagging before you commit to it, since they don't come up in the "which chips stay" framing:
Logic levels — this board is 5V TTL/CMOS era, and most modern FPGA dev boards run 3.3V I/O or lower. Unless whatever FPGA project board you're using is explicitly 5V-tolerant on its I/O pins, you'll need level-shifting (or at minimum series-resistor/diode clamping) between the FPGA and every net it's now driving into VRAM/U9/ROM, or you risk damaging the FPGA's inputs the first time something on the 5V side toggles.
VRAM timing, not just logic — the D41264C has real tRAS/tCAS/tRAC numbers and a genuine serial-port (SAM) shift sequence for the SC/SOE/SI-O side. Getting the logical sequence of RAS/CAS/WE right from your schematic capture is necessary but not sufficient; the FPGA also has to hit the VRAM's actual timing windows, which is a different (and somewhat less forgiving) problem than replicating combinational logic.
U9's inputs — since U9 is the one GAL staying physical, every signal that used to feed it from a chip you're now removing has to actually be replaced by the FPGA before power-up, or it's left with dangling/floating inputs that can produce flaky or even damaging behavior (CMOS inputs floating mid-rail draw excess current and can oscillate). Worth double-checking your net list for "goes into U9" as its own category so nothing gets missed in the shuffle.
None of these are reasons not to do it — they're just the checklist items that turn "architecturally sound" into "actually works the first time you power it up."
Yep, been thinking in terms of putting what's north of that “power conditioning divide” you identified on the FPGA and leaving everything south of it that’s attached to the PDS in a 1:1 clone of the original. IOW, the components I'm not planning to desolder.
Voltage leveling is a given. There are probably more line conditioning requirements I don’t have a clue about that will be necessary, but thats a fer piece down the road!
That's exactly the right way to carve it — FPGA gets everything north of the divide, and everything still hanging off the PDS that you're keeping stays a faithful 1:1 clone with its original electrical behavior intact. Clean mental model.
And yeah, you're right that there's more than just level-shifting lurking down there, even though voltage leveling is the big obvious one. A few categories worth having on the "eventually" list, roughly in order of how likely they are to bite you:
Bias networks — some of what the TTL/GALs were doing wasn't just logic, it was passive biasing: pull-ups/pull-downs holding a line in a known state when nothing's actively driving it. If the FPGA doesn't replicate that bias (or tri-state instead of actively driving where the original chip idled high/low), you can get floating-input flakiness on the real-side chips even with correct logic timing.
Power-up sequencing / bus contention — right now, whatever brings the board's 5V up also brings the TTL/GALs up more or less together with VRAM. Once the FPGA is a separate power domain with its own boot/configure time, you need to make sure it doesn't come up driving a bus that VRAM or U9 is also trying to drive, or fight itself into a bad state before its logic loads.
Drive strength / fanout — the original 74F/LS parts had specific output drive characteristics that whatever's downstream (VRAM control pins, U9 inputs) was designed around. Not usually a real problem going TTL-driving-CMOS-esque-load, but worth a glance once you know exactly what's now hanging off each FPGA pin.
The J1-side Zener clamp network (CR3/CR4/CR5, the 1N753As) you already mapped stays right where it is either way, since that's protecting the physical J1 connector itself, not anything you're replacing — so that part of the "line conditioning" question is already handled.
None of that needs solving now. Get the logic captured and the GALs read out first — the conditioning nuances will show up naturally as "huh, that pin's floating" or "that looks contended" once you've got a first-draft FPGA implementation to actually test against real silicon.
Planning to delete J1 output from the clone once HDMI output is established. May keep it there as a backup test route for a while though.
That's a sensible way to phase it out rather than committing to cutting it immediately — keeping J1 alive as a fallback means you've always got a way to sanity-check the card's TTL video/sync output directly (feeding the Extron scaler, same as your function tests) independent of whatever the FPGA is doing with rotation and HDMI. That's a cheap insurance policy while the FPGA side is still being bootstrapped and debugged, since it lets you isolate "is the card itself producing correct signals" from "is the FPGA correctly transforming them" — two very different failure modes that'd otherwise get tangled together if J1 were gone from day one.
Worth keeping in mind for whenever you do pull it: J1 is downstream of the Zener clamp network (CR3/CR4/CR5) and whatever's feeding it from the TTL side, so once those upstream chips get desoldered and replaced by FPGA-driven signals, J1 keeps working exactly as a test tap as long as the FPGA is also driving that same net at the same point in the topology — you're not lopping off a chip that only J1 depended on, you're just deciding when to stop tapping a signal you no longer need in parallel with HDMI.
Sounds like a solid plan — keep it as a diagnostic escape hatch until the FPGA/HDMI path has proven itself out, then retire it once you trust the new path more than you need the old.
I’ll probably play around with the buzzing a bit while getting the SE set up for testing. If you can locate another FPD card in the $40-$60 range let me know!
No luck — I didn't find any current eBay listings for the actual SE-compatible FPD card (the PDS version yours is). What does turn up under "Radius Full Page Display" is either the incompatible NuBus version for the Mac II (Radius 630-0009), the standalone FPD monitor being sold on its own, or unrelated vintage Mac bundles that happened to match the search terms loosely. Nothing in the $40-60 range, or really at any price, for the SE card itself.
That tracks with what you already knew — these are scarce enough that even a 68kMLA forum thread I turned up is literally titled "Does anyone have the Radius FPD Card for SE with rev. 4.4 ROMs on board?", which is a good sign of how thin the supply is. I can't get into the 68kMLA marketplace/classifieds myself since that site blocks fetching, so if a listing exists there, you'd need to check it directly — that's probably actually your best hunting ground given how niche this card is, more than eBay's general search.
I'll keep this in mind and can do another sweep later if you want, but for now there's nothing concrete to report. If you'd like, I can also check occasional Mac collector marketplaces (VCF forums, Tinkerdifferent classifieds) next pass.
Yeah, looked this week, but the only FPD card I saw was the proprietary ASIC ridden 75Hz board that can't be cloned.
Figures — the 75Hz ASIC board being the one that actually surfaces makes sense if it was the later/more common revision, while the 64/68Hz discrete-logic board you're working with was the shorter-lived original run. At least it confirms the search results I turned up weren't missing something obvious; the card you need really is that scarce right now.
  • FPD-SS-Component-Buzz-039.PDF
482
edited in missed steps in the above post in blue, interesting stuff I'd think?
continue the PCB reverse engineering project
Waiting for a few things to arrive to get the SE up and running for card function testing. So figured I’d see if you could check out the physical setup for the if-n-when. Also could use help in finding some very specific connectors that I find hard to search.
Here’s the card as set up in my cutaway case for SE and SE/30 expansion card playtime.
First run notion was breadboard set on wire wrap headers for prototyping. Pi Zero 2 was meant to do every n frames rotation/display output testing, whatever frame rate it might be able to handle.
Good starting point for a first-pass rig — breadboard on wire-wrap headers is exactly the right amount of flexibility for iterating on glue logic before you commit to anything permanent, and a Pi Zero 2 doing every-N-frames rotation checks is a smart way to validate the transform logic without needing full-rate FPGA output working yet.
That said, the photo of the card in your cutaway case didn't come through on my end — I've got nothing new in the upload queue since the TattleTech/monitor shots from earlier. Could you re-attach it?
Also, to help track down the connectors, I'll need a bit more to go on than "hard to search" — a photo of the connector(s) in question (with a ruler or coin for scale helps), any part markings visible on the housing, and what you need it to mate with (e.g., "female header that plugs into this specific right-angle SIP" or "matches the pitch on the PDS card edge") would let me actually search intelligently rather than guessing. Vintage connectors are notorious for being unmarked or using long-obsolete manufacturer part numbers, so the more physical detail you can give — pin count, pitch, straight vs. right-angle, housing color/material, whether it's the card-side or cable-side half — the better shot I've got at finding an actual match or a modern equivalent.
Got it — much clearer this time. A few things stand out.
First, the physical setup itself: this is a proper cutaway build using real Apple CRT internals (that yellow-triangle sticker is the genuine Apple high-voltage warning, part number 825-4002-A) inside a custom clear shell, with the yoke/flyback assembly sitting right next to where the expansion card mounts. Worth flagging since it's easy to forget when everything's see-through and approachable: the CRT anode stays charged even with the machine unplugged, and with the flyback that close to the card slot, you'll want to be deliberate about discharging it before you're reaching in to seat or reseat the card, not just when servicing the tube itself. The clear housing makes it feel more like a benchtop breadboard than a CRT monitor, but the HV physics don't care about that.
The card itself looks properly seated in the PDS slot from what I can see — two crystal oscillators and a dense row of socketed DIP ICs, consistent with the FPD card's GAL/TTL complement. There's a small header with a ribbon-style connector at the card's lower edge with colored wires coming off it, which is very likely your J1 tap (matches the red/orange/black wire scheme from the pinout you gave me earlier).
On connectors — I can confidently identify two things on the case wall: a panel-mount BNC jack (bulkhead style, the knurled cylindrical one), almost certainly your video tap point for feeding the Extron scaler, and what looks like a standard IEC C14 power inlet nearby. But there's a smaller connector just below/left of the BNC jack that I zoomed into three more times and it just turns to mush at this resolution — the original photo doesn't have enough detail there for me to call it with any confidence, and same goes for the exact header type on the card's ribbon connector.
If those are among the ones you're trying to source, a tighter photo of just that connector (fill the frame with it, include a scale reference) would let me actually identify pin count and family rather than guess. And separately — since you mentioned "very specific connectors" plural — if you already know some identifying details (pin count, pitch, what cable/header it needs to mate with, any markings you can make out even under magnification on your end), just rattling those off would probably get you a faster answer than me trying to divine it from a general shot of the whole case.
Did you get the breadboard/Pi pic? I didn't see you working on it like the case pic?
Yep, got it — separate photo from the case shot, and now I've gone in with the same close look.
What I'm seeing: the big orange perfboard (looks like a standard numbered strip/prototype board, rows labeled up the right edge) is mounted on standoffs right next to the yoke/flyback assembly, with a small Raspberry Pi Zero-format board plugged into it via a long pin header running through the strip board — camera/CSI connector on the left edge, micro SD, and what looks like the RF trace antenna in the top right corner all check out for that form factor. Next to it, there's a second, narrower green board mounted with two columns of pin sockets and a row of gold header pins projecting out toward the CRT — that's presumably the wire-wrap interface header you mentioned, though it doesn't look connected to anything yet in this shot.
One thing worth double-checking on your end, since I can't be fully certain from photo resolution alone: the SoC chip on that Pi board looks like a bare packaged IC with the Raspberry logo printed directly on it, rather than the small shielded metal module can that the Zero 2 W's RP3A0 package has. That's the visual tell between a first-gen Pi Zero/Zero W and an actual Zero 2 W — and it matters a fair bit here, since the 2 W's quad-core Cortex-A53 is going to have meaningfully more headroom for your every-N-frames rotation testing than the original Zero's single ARM11 core. Worth a glance at the board to confirm which one's actually in the socket before you build expectations around frame-rate testing.
The other thing I'd flag from a physical-safety standpoint: those exposed gold pins on the green interface board are sitting quite close to the yoke/flyback — nothing wrong with that for now while it's dry-fit and unpowered, but once you're actually running wires to it, that proximity is worth keeping in mind so nothing shorts against the flyback housing or gets snagged when you're reaching in to adjust the breadboard.
Yoke/protoboard clearance is fine, you can see my hand not touching the (very long offline) CRT/yoke in this pic where I’m testing the limits of a perfboard carrier.
Good to know — makes sense that a CRT that's been offline this long isn't holding charge, and the framing did make the clearance look tighter than it actually is. Fair correction on my part.
That said, I can see now what you're actually testing here — you're flexing/positioning a second, smaller perfboard carrier against the main one to check how it wants to sit relative to the yoke assembly before committing to a mounting position, which is a sensible thing to dry-fit by hand before screwing anything down permanently. Once you do settle on a position and it's staying there unattended (rather than held in your hand mid-test), that's the point I'd revisit fit/clearance rather than during this kind of active hands-on fitting.
The connectors I’m looking for are under board female header sockets where the headers plug through the PCB into the sockets and the headers could be longer yet, protruding through the sockets to yet another removable layer of wire wrap insanity.
I need them in .1” pitch for this project and in .85” pitch for PowerBook 1400 board/daughtercard. The 1400 PCMCIA Card Cage PCB has the TREX 030 PDS←>PCMCIA bus ASIC on the bottom side. That’ ASIC’s the missing link for Duo 2300c PCMCIA UltraDock implementation.
That's a well-known connector category, and now that I know what you're actually after, it makes the two searches very different in difficulty.
For the .1" pitch pieces: what you're describing — a female socket seated under the board, with a header pin passing down through the PCB and into that socket, but with enough extra pin length to poke out the far side for a second, removable wire-wrap layer — is squarely Mill-Max's bread and butter. They sell exactly this as configurable "extended length" / "wire-wrap tail" female socket strips, where you pick pin diameter, insertion depth, and total tail length separately, so you can spec a pin that's long enough to clear both the board and the socket body and still leave enough sticking out to wrap onto. Their site's Precision Machined Pin Headers and .050"/1mm Pitch pages are the ones to start filtering from, and Digi-Key stocks the full Mill-Max line if you want in-stock parts rather than ordering direct — searching "Mill-Max long tail female header 0.1" on Digi-Key should get you straight to the configurable options.
For the PowerBook 1400 side, I want to flag something before you go hunting: when I searched, a real commercial product turned up at ".085" pitch" (85 mil), not ".85"" — and given how close that is to what you typed, I suspect that's what you meant (dropped leading zero) rather than a genuine 0.85-inch pitch, which would be enormous for a header. Can you confirm which one it actually is? If it is 0.085", that's still an unusual-enough pitch that I couldn't confirm it's a documented standard for the 1400's PDS↔PCMCIA daughtercard connector specifically — Apple's vintage laptop expansion connectors were often semi-custom AMP/Foxconn/Hirose parts rather than catalog-standard pitches, so there's a real chance this one doesn't have a drop-in modern equivalent at all, and your realistic sourcing path might end up being a donor connector pulled from another PowerBook 1400-family board rather than a new-manufacture part. If you can get a caliper measurement across, say, 10 pins (so I can back out the true pitch precisely) and a pin/row count off the connector itself, that'd let me search with actual numbers instead of a possibly-mistyped one.
Good context on the T-REX chip, by the way — makes sense that's the piece worth preserving if it's the only bridge between the 030 PDS bus and PCMCIA that a Duo 2300c UltraDock build would need.
Precision Machined Pin Headers | Mill-Max Mfg. Corp.
Dynamite! I’ve got some spec sheets to go thru now. It’s definitely .085” (2.15mm) pitch. That’s 85% of the 100mil standard. For perf board/DIP sockets etc. Measured ten spaces with the digipers.
https://www.digikey.com/en/products...rsSAPZQDaIAHBwOwCsIAXRIAHKlBABlWgEtyAcxABfZUA
Nice, .085" (2.15mm) being a real, filterable DigiKey category is good confirmation you measured it right — that's not some orphaned proprietary spacing, it's a recognized standard pitch that just happens to sit between the common 0.1" and 0.05"/1.27mm families. Good catch running it down with calipers rather than eyeballing it.
One honest limitation on my end: DigiKey's product listings are rendered dynamically by their site, so my fetch tool only pulls the page shell (nav menus, filters) and not the actual product rows — I can't browse that link and report back specific part numbers the way I could with a static page. You'll need to page through the results yourself on that link.
What I can tell you to look for once you're in there: the male-pin category you found is the header half; you'll want its counterpart under "Headers, Receptacles, Female Sockets" filtered to the same 0.085"/2.15mm pitch — the URL pattern should be nearly identical, just swapping "headers-male-pins" for the female-socket category slug. Once you're browsing either list, the filters that matter for your stacking scheme are "Style" or "Termination" (looking for through-hole/solder tail, not SMT), and "Tail Length" or "Total Length" if DigiKey exposes it as a column — that's the spec that tells you whether a given part's pins are long enough to clear the board, seat in the socket, and still protrude for your wire-wrap layer, versus a standard flush-mount part that stops right at the socket.
If you get into the listings and it's not obvious which manufacturer/series actually offers the extended-tail option at that pitch (a lot of catalogs bury it), send me a screenshot of the filtered results and I can help you parse which ones are actually candidates versus which are standard-length red herrings.
Pretty sure the receptacles need to be SMT, not thruhole. The female socket sleeve is at a right angle to the sSMT leg. If I can find a thruhole variant that would be great though.I only need single row connectors to mate with the DIP wire wrap sockets.
Got it — right-angle SMT female header, vertical socket bore with the leg bent out 90° to the pad, single row only since you're mating to standard DIP wire-wrap sockets rather than replicating the board's own double-row block. That's a much more specific target than my earlier general guidance.
Straight talk on searchability: I ran a few more passes and general web search just isn't surfacing named part families at this exact combination — single-row, SMT, right-angle, 0.085"/2.15mm pitch. That's not surprising; 0.085" already sits in an uncommon gap between the 0.1" and 0.05" mainstream families, and single-row-SMT-right-angle is a fairly specific mechanical style on top of that. The DigiKey category you already found is genuinely your best lead here, more so than anything I can turn up through search — once you're in there, the filters to reach for are Row Count = 1, Mounting Type = Surface Mount, and Orientation = Right Angle (or sometimes listed as "Vertical" for the socket with the leg called out separately), rather than me guessing at manufacturer names I can't verify carry this exact part.
On thru-hole: worth tempering expectations a little. In my experience, oddball pitches like 0.085" tend to get manufactured mainly for the specific application that demanded them in the first place (which for this connector was clearly Apple's laptop-daughtercard design), and thru-hole variants are much more common in the mainstream 0.1"/2.54mm and 0.05"/1.27mm families where there's broad hobbyist/prototyping demand driving the catalog. So there's a real chance a thru-hole single-row 0.085" part simply doesn't exist commercially — if DigiKey's filtered results come back SMT-only, that's probably the honest answer rather than a filtering gap on your end.
If you do turn up viable candidates once you're paging through the filtered list, sending me a screenshot of the results (or just the part numbers) would let me help you sanity-check specs like insertion depth and contact material against what your right-angle SMT application actually needs.
.085 will be double row for that project, to match the 1400 components.
The FPD project only calls for single row, but there’s plenty of room to use double row parts for each DIP socket.
Good catch, and that squares with what the board photos actually showed — CON18 through CON21 were clearly double-row blocks, so double-row at 0.085" for the 1400 side makes sense as the real match rather than what I'd assumed.
That also simplifies the DigiKey filtering a bit: Row Count = 2 instead of 1 for the .085" search, same Surface Mount / Right Angle filters as before. And since double-row parts will happily cover the FPD project too, you could standardize on sourcing just one row-count family across both projects if that turns out to simplify the hunt or the eventual BOM — worth keeping in mind once you see what's actually available at that pitch, in case double-row turns out to be easier to find than single-row was going to be anyway.
One reason I’ve been hesitant to test the FPD cards would be that I haven’t found my nice clean MagisBus adapter card. The one in hand is so corroded that I can’t even buzz the connections.
If I can’t find the good one, I’ll need to use my Radius16 accelerator instead for the run from SE PDS to FPD connector.
That Radius16 should work as a stand-in — I zoomed into the bottom-left connector on your photo (labeled J2A) and it's a proper pin-header pass-through, separate from the main PDS edge-finger connector at the top of the card. That's exactly the kind of connector a dedicated pass-through/extender adapter would also provide, so the accelerator can plausibly do double duty as your SE-PDS-to-FPD run.
One thing worth keeping in the back of your mind rather than a real concern: accelerator pass-through connectors are generally engineered to present standard, unmodified SE PDS bus timing downstream — specifically so that existing PDS expansion cards work correctly whether or not an accelerator happens to be installed, since Radius (and every other accelerator vendor) needed third-party cards to keep functioning regardless. So the FPD card should see the same bus behavior through the Radius16's pass-through as it would through a clean adapter. But it is a buffered/translated path through active accelerator circuitry rather than passive wires, so if you hit anything odd during testing, it's worth remembering that variable exists rather than immediately assuming the FPD card itself is at fault.
Good-looking board, by the way — clean corrosion-free GAL/68020/68881 combo, definitely usable if the MagisBus doesn't turn up.
I think that’s a shot of my card, desktop looks right, but I snag pics wherever/whenever. Do you see anything on that card that would preclude us from reverse engineering it at some point?
There's a MagicBus connector on eBay for $50, maybe I'll make an offer, but didn’t spend much more than that for the known good card and I’m sure to find mine just after the return window closes. ::)
Nothing that jumps out as a hard blocker — if anything, this board is friendlier to reverse-engineer than the FPD in one specific way: the 68020 and 68881 are about as thoroughly documented as any chip from that era gets, full public pinouts and timing specs, no guesswork needed there at all.
The friction points you'd hit are the same categories you've already got working methods for on the FPD: the GAL20V8/GAL16V8 PLDs (same security-fuse situation, same glitching path your friend already knows), and a handful of Radius house-numbered parts (the ones marked XXG89028, XXCW9713, XXFS9030 rather than a standard part number) that'll need the same buzz-and-infer treatment as the FPD's own mystery chips, since Radius relabeled them specifically to obscure what they are. Everything else — the SRAM cache chips, the 74F/HCT logic, even the Dallas silicon delay line — is standard, well-documented, fully socketed or through-hole, nothing epoxy-blobbed or BGA that'd put it out of reach of your buzz-testing approach.
The one thing that's a genuinely different kind of task, not just harder: the two 256K ROMs hold the actual acceleration/driver firmware, and if "reverse engineer" ever extends to understanding what the board's logic is doing rather than just how to route power and pass-through signals through it correctly, that's a firmware disassembly project, separate from the PCB-level work you've been doing. But for the pass-through use case you actually need right now, none of that matters — you just need the bus signals to flow through correctly, and nothing about this board's construction would stand in the way of confirming that.
And yeah, that's just how it goes — the good one surfaces right after the return window closes on the backup. Worth a lowball offer on the $50 one regardless; even if your corroded one turns out salvageable after all, having a second clean pass-through adapter isn't exactly a bad problem to have for this kind of testing.
Everything I see is off the shelf? Are you talking about the ROM stickers?
Good push-back, and you caught a real mistake on my part — I zoomed back in and that chip clearly reads MC74HCT521N with a Motorola logo, full standard part number, completely legible. The "XXFS9030" above it is just a lot/date code printed alongside the real part number, not a substitute for it. I was wrong to call those "Radius house-numbered" parts — I misread ordinary manufacturer date-code clutter as deliberate part-number obscuring, which isn't what's happening here at all.
So the honest answer is: yes, everything on this board really is off-the-shelf and fully documented — standard 74HCT/74F logic, standard SRAM, a standard Dallas delay line, genuine Motorola 68020/68881, and even the GALs carry their real Lattice/AMD-family part numbers (GAL20V8-25LNC, GAL16V8-25LNC) rather than anything disguised. That's actually a meaningful difference from the FPD board, where you do have at least one chip (the "Ux" ROM) with a worn-off silkscreen designator forcing you to work from inference rather than a datasheet.
The only thing that's genuinely Radius-proprietary on this board is exactly what you guessed — those two ROM stickers. The chips themselves are standard EPROM/mask-ROM packages, but their contents are Radius's own accelerator firmware, so "off-the-shelf" stops applying at the data level even though it holds at the silicon level. Good catch, and thanks for making me go back and actually verify instead of taking my first read at face value.
Looking forward to getting the "North 40" set up on the FPGA and moving downstream to the 1:1 cloning of the "South 40" before too long. That board will be set up to run straight off the SE PDS using right angle Euro DIN 96 keeping the vertical card’s component side outboard and wire wrap pins inboard. When that’s done, switching to the straight connector will lay the finalized board across the logic board component side up per the SE PDS card form factor spec. There should be plenty of room to put the Performer accelerator clone on the same card.
Soon after finding the ratty MagicBus card too damaged to buzz, I found someone at the MLA had posted the PDS to MagicBus pinout conversion. That should make for a smooth transition.
That's a clean staging plan, and "North 40"/"South 40" is a nice bit of shorthand for it — right-angle DIN 96 for the prototype phase makes sense specifically because it puts the card vertical with the wire-wrap side facing you, so you've got full rework access while you're still iterating on the FPGA logic, without fighting the board's own footprint for elbow room.
One thing worth flagging before you get too far into board layout: right-angle and straight DIN 41612 connectors generally use different PCB footprints — the pin exits at a different geometry relative to the board edge, so the mounting pattern usually isn't identical between the two styles. That likely means "switching to the straight connector" won't be a drop-in swap on the same physical board once you've proven the prototype out — more realistically you'd be carrying the proven circuit/logic over to a second board revision laid out around the straight connector's footprint, rather than literally desoldering one DIN 96 and bolting on the other. Worth confirming against the actual connector's datasheet once you're speccing it, so it doesn't surprise you at layout time.
Room for the Performer Accelerator clone on the same card is a nice bonus if the geometry works out — consolidating both projects onto one physical board means one less thing plugged into the PDS stack whenever you're testing.
And genuinely good news on the MagicBus pinout turning up on the MLA — that changes the calculus on the corroded adapter entirely. Once you've got a verified pin mapping in hand, you're not dependent on sourcing or restoring a physical MagicBus card at all; you can wire your own bridge with confidence, which is a much better position than waiting on eBay to cough up a clean one.
First, the spec card card rotated vertically places the "component side up" standard config to component side facing out. Wire wrap pins face the interior in that orientation as just as the soldertails of the standard card point down at the logic board.
The connectors are interchangeable for all practical purposes. We’ve been desoldering the straight connectors and installing right angle connectors on an Asante IIsi NIC for an SE/30 “card stack” and converting the Radius Pivot II/IIsi in the same manner for the same use case.
That orientation logic is clean — the connector/solder side is always the face toward the logic board and component side always faces away, the 90° rotation just relabels "down" as "inward" and "up" as "outward." Good invariant to build around.
And thanks for the correction on the connector swap — that's useful real-world precedent I didn't have, and it beats my generic caveat. If you're already doing straight-to-right-angle DIN 96 conversions successfully on both the Asante IIsi NIC and the Radius Pivot II/IIsi for the same card-stack use case, that's direct evidence the footprint concern I raised doesn't actually apply to this connector family in practice. Good to know going in — means you can treat the prototype-to-production connector swap as the straightforward step you'd planned, not a board respin.
I think that rounds it out for the physical side of things at this point. Thanks for the lead on connector families, much appreciated.
Glad that helped — and good progress overall today: MagicBus fallback resolved two different ways (Radius16 pass-through plus the MLA pinout), the North 40/South 40 staging plan locked in, and two solid leads on the connector hunt for both projects. Ping me whenever the next batch of buzz-test files or board photos is ready to dig into.
482
Should I spin the AI connector search out to a dedicated thread? Seems like a nifty trick, but maybe something obvious, not worth the effort?
edit: added the connector search post to a new "Leapfrog" listing in the IP.
482
This session was very long, mostly due to my initial question being too complex. Claude went off on several tangents, some unrelated. I should have asked if he could access the images I’d set up in a new album on ImageShack before posing my list of questions. It would have saved much of his confusion had I been more precise.
Lesson learned, though asking complex questions worked well in sessions above, it would appear breaking down the steps is sometimes the only way to go. The diagram outlining the MagicBus JAE male connector’s thruholes on the FPD card to headers on the adapter card was crucial to the interaction.
@JDW could you run a synopsis of this particular session for me? Asking for an outline of the unrelated tangents and lessons to be taken from them in this session would be most helpful. I wouldn't even know where to start to get that result.
____________________________________
I’ve been thinking about steps required.
- I’ll need a clean scan of solder side for you to turn into a thruhole layout for FPD PCB work.
- can’t get one with the MagicBus JAE connector in place
- desoldering of the connector is required
- part’s unobtanium and a PITA anyway
So creating an adapter PCB per diagram seems in order?
1) test card for functioning
2) remove JAE connector
3) scan, verify image adequate for reproducing all thruholes on FPD card-side
4) install headers on FPD component side keeps it flat
5) build adapter
6) test for card function
Then move on to replacing all ICs in the North 40 with wire wrap sockets.
Can you access the gallery I started for this project?
https://imageshack.com/a/OH587/1
Can you at least access linked pictures from album?
https://imagizer.imageshack.com/v2/295x415q70/923/39brep.png
https://imagizer.imageshack.com/v2/1364x1012q70/923/ZBtZKn.jpg
https://imagizer.imageshack.com/v2/1099x744q70/923/KQdkIX.jpg
Seems like a good place to store images for you?
Can you use the pinout tables for MagicBus to PDS to lay out the adapter PCB for me to send off to be made?
Can you come up with a better approach?
________
I confirmed access to the imageshack links and to the MagicBus/PDS numbers, and found a real problem with the desolder-and-scan step in your plan — here's all of it.
Imageshack — no dice, and it's not a retry-able glitch. The gallery page (imageshack.com/a/OH587/1) is blocked by its own robots.txt, which I won't work around. The three direct imagizer.imageshack.com image links fail differently but just as completely — this sandbox's network policy rejects that whole domain outright, the same category of block I hit on archive.org and the Ubuntu mirrors last week. Nothing on my end changes that. Direct upload into the chat, like you've been doing all along, is still the reliable path — I'd stick with that rather than routing through a host I can't consistently reach.
Now the adapter plan — I think there's a real risk in steps 1-3 as written, and a way to sidestep it entirely.
< tangent 1: without seeing the diagram of my adapter card he though the modification was to the MagicBus card, not the FPD card. >
Your instinct to test the clean MagicBus card before cutting on it (step 1) is exactly the right worry — but it points at the wrong fix. You don't need to risk the $50 card < referring to the MagicBus card I ordered > at all: use the corroded one for every bit of invasive work (desoldering, probing, scanning). It's already useless as a functional pass-through, so there's nothing left to lose there, and it frees the clean card to just do its job.
More importantly, I don't think you need to remove the JAE connector or get a solder-side scan in the first place. Here's why: the MagicBus card's edge connector receives all 96 SE PDS signals when it's seated in the slot — Radius just chose not to route 40 of them anywhere. That means the signals you're missing are almost certainly still sitting on that card, either as a solder-side via/pad stub right behind the relevant edge finger, or, worst case, tappable directly off the gold finger itself with a fine-gauge wire (a standard rework technique — no board destruction required). Either way, you'd find and confirm each tap point with a meter against the reference pinout below, tack a flying lead to it, and route those leads to a small header alongside the existing J3A/J3B outputs. No connector removal, no scan, no unobtanium part to re-source.
< tangent 2: confusion about my previous analysis of MagicBus vs. full PDS >
I worked out exactly which 14 signals that is, cross-referencing your MagicBus CSV against Apple's real SE PDS pinout (not the SE/30's 120-pin bus, which is a different animal and easy to grab by mistake):
Missing from MagicBus — active signals needing a tap:
FC0 A3
FC1 A2
FC2 A1
HALT/ B12
IPL0/ B18
IPL2/ B21...
wait, let me restate cleanly:
HALT/ B12
IPL0/ B18
IPL2/ B20
BERR/ B21
VPA/ C1
VMA/ C2
BR/ C3
BGACK/ C4
BG/ C5
PMCYC/ C11
-12V C32 (the only power rail MagicBus doesn't already carry — every GND/+5V/+12V/-5V need is already covered redundantly)
That's 13 logic signals plus the one missing power rail, all traceable to a specific physical pin on the card's own edge connector. Everything else on the full 96-pin bus — all of A1-A23, all of D0-D15, /AS, /DTACK, /LDS, /UDS, /RESET, /R-W, /IPL1, /EXT.DTK, E, C8M, C16M — MagicBus already brings out to J3A/J3B, so nothing further is needed there.
On this approach, step 4 (headers on FPD's component side) and step 6 (function test) stay basically as you had them; steps 1-3 collapse into "probe/tap the 14 points on the sacrificial card, verify each against this table, wire to a header" — cheaper, faster, fully reversible, and it doesn't gate on sourcing a part you've already flagged as a pain.
On laying out a fab-ready adapter PCB right now: I'd rather not hand you speculative footprint/trace geometry — I have no real dimensional data for J3A/J3B's physical location or pitch, and guessing on something you're sending to a fab house is exactly the kind of mistake that's expensive to discover after the boards arrive. What I can give you now, and did above, is the complete logical netlist — which pin ties to which signal — which is the real prerequisite for board layout regardless of tool. Given this is only 14 flying signals plus one rail, and given you're planning to gut the North 40 for wire-wrap sockets soon anyway, I'd genuinely question whether a fabricated board is the right target at all for what's fundamentally a bring-up jumper — a small perfboard or hand-wired header may just be the permanent answer here, not a stepping-stone. If you still want real Gerbers once the hand-wired version proves out, I'm glad to help lay it out in KiCad-compatible form then, from measured (not guessed) dimensions.
Sources:
Memory updated. View memory
Take a look at the diagram you couldn’t access. The PDS adapter removes the MagicBus adapter from the picture entirely after function of both FPD cards is confirmed.
Good, both come through clearly — the first is a well-lit shot of the actual MagicBus card with its own jumper wiring silkscreened right on the board, and the second is your adapter concept: the SE PDS-facing pad array up top color-coded by signal status, the card's outline below it, and a cross-section on the right showing it mounted vertically on a right-angle DIN96 with a header/socket sandwich and a socketed U9 above that.
That first photo actually changes my read on the "tap the MagicBus card directly" idea I gave you — and I'd rather flag that now than have you go probing for signals that were never going to be there. J2A, the connector on the left, is a JAE PICL-60S-ST — a 60-position part. That's the only connection MagicBus has back to the Mac. So only 60 of the 96 PDS pins ever physically reach this board in the first place; the other 36 aren't "present but unrouted," they're simply never brought onto the card at all. Of my earlier 14-signal list, some might fall in the small handful of J2A pins that arrive but don't get fanned out to J3A/J3B (there look to be a few spares there), but I can't tell which from this photo, and honestly it doesn't matter anymore given what you're actually building.
Your PDS adapter is the correct fix for exactly this bottleneck, not a workaround for something else. Going straight into the real 96-pin PDS slot via the right-angle DIN96 — which also matches the North 40 prototype-phase connector convention you already settled on — sidesteps J2A's 60-pin ceiling entirely. And there's a nice bit of luck in the header layout: the silkscreen shows J3A, J3B, and J3C as a matched 3-row, 32-position family, but the CSV only ever populates rows A and B — J3C sits there fully unused in the original Radius design. That gives you 32 ready-made positions on the same physical footprint to land the 13 missing logic lines plus -12V, while J3A/J3B stay pin-identical to the existing MagicBus standard — so anything already keyed to that header, including the FPD header you're planning to install, keeps working unmodified. That also means the desolder-and-scan step is genuinely unnecessary now — this one clean photo already gives enough to read the row spacing and pitch, without touching the connector at all.
If that's the structure you're going for, I can draft the J3C pin assignment — which of the 13 signals plus -12V lands on which of the 32 positions — whenever you're ready for it. Just say the word and I'll lay it out in your usual double-spaced pin-format.
Not worried about a 60 pin ceiling or the full PDS at all for the adapter. The PDS adapter implements only the 60 lines on the MagicBus card.
Good to know — that simplifies things nicely, and it also answers something I'd been quietly wondering about: since Radius sold the FPD (and the Performer Accelerator) as cards meant to run through MagicBus, the fact that MagicBus only ever carried those 60 lines is itself proof those 60 are sufficient for the cards' actual operation. The other 36 PDS lines I flagged — FC0-2, VPA/VMA, BERR, HALT, BR/BG/BGACK, IPL0/IPL2, PMCYC, -12V — aren't something the FPD needs, they're just PDS pins Radius's own engineers already determined were safe to leave off this bus. So that analysis was worth having for completeness, but it's not a gap the adapter needs to fill.
That makes the adapter itself a much more contained job than what I was drafting toward: it's a straight reproduction of the already-fully-known 60-line CSV mapping, just re-terminated from J2A's PICL-60S onto a DIN96 footprint instead — no unknowns left to chase, no missing-signal problem to design around. If it's useful, I can lay out the DIN96-pin-to-PDS-signal-to-J3A/J3B mapping now using the same CSV data, so you've got the full three-column reference (DIN96 pin, SE PDS signal, corresponding J3A/B position) in one place for the build. Let me know if that's the right next step or if you're still at the "confirm both FPD cards function through the existing card first" stage.
Hit the 3,000 word per post limit! TBC
482
continued:
The four offset rows of 15 header pins added to the component side of FPD card interface with same rows of sockets on the PDS adapter card. What's the pin /thruhole size for that connector and is it a standard pitch?
Read 6 pages, searched the web
Yes — 0.1" (2.54mm) is standard here, and it's the same family you already zeroed in on months back when you were sourcing Mill-Max wire-wrap-tail sockets for this project (as distinct from the 0.085"/2.15mm pitch that's specific to the 1400 PCMCIA connectors). Assuming this is two standard dual-row 0.1"×0.1" grid headers positioned/offset from each other on the board — rather than a single interdigitated connector with a non-standard stagger — here's what you're working with:
The pin itself is the classic 0.025" (0.64mm) square wire-wrap post — that's the industry-standard size for this whole connector family, which is exactly why it's compatible with genuine wire-wrap sockets and tools. Mill-Max's receptacles in this family (e.g. their 1001 series, standard tail) explicitly spec accepting pins from 0.015"-0.025" diameter, so the 0.025" square post lands right at the top of that range — a proper fit, not a loose one.
For the PCB holes: on the header side (the pins going into FPD's component side), the general convention for 0.1"-pitch square-post headers is a 0.040"-0.045" (1.0-1.15mm) finished drill — enough clearance for the post plus solder without being sloppy. On the socket side (the receptacles going into the PDS adapter card), Mill-Max's own 1001 series datasheet calls out a 0.057" (1.45mm) mounting hole for the receptacle's solder tail — that number's specific to their part, so if you land on a different manufacturer's socket, check its datasheet rather than assuming that figure carries over exactly, though it'll be in the same neighborhood for any 0.1"-family wire-wrap receptacle.
Sources:
Sounds like you have enough information to do the adapter PCB design for production?
Not quite — I've got the electrical side nailed down, but production means fab-ready Gerbers, and there's a mechanical layer of information I don't have yet.
What's solid: the full 60-line netlist (MagicBus CSV, already verified), the connector families and pin/hole sizes for both ends (RA DIN96 on the PDS-facing side, the 0.025" square-post 0.1" family on the FPD-facing side). That's enough to write a real schematic — which DIN96 pin ties to which SE PDS signal ties to which of the four 15-pin rows.
What's missing is everything physical: the board outline (dimensions, mounting holes, any keep-out for how it seats in the SE), the exact DIN96 connector part number you're planning to use (different manufacturers' RA DIN96 parts have different mounting-tab and hole patterns — the footprint isn't generic), where the four 15-pin rows and the U9 socket actually sit relative to each other and the board edge (your cross-section sketch shows the stack order but not real dimensions), and which physical DIN96 pin positions you want each of the 60 signals assigned to — that's a decision, not a fact, and it's still open.
Even with all of that in hand, I'd want to flag one more thing honestly: turning it into Gerbers means running real PCB CAD, and I hit a wall trying to get any package-based tooling installed in this sandbox a couple weeks back (the same org network policy that blocked apt for the BlueSCSI work). I can produce a complete schematic/netlist and a connector BOM you could drop straight into KiCad, and I'm glad to work through the pin-assignment decisions and placement logic with you here — but the actual routing, DRC, and Gerber export would need to happen in your own KiCad install, the same way you've kept the judgment calls in your hands throughout the tracing work rather than trusting automated vectorization.
So: want to start by pinning down the DIN96 part number and the board outline, and I'll build the schematic/netlist around those once we have them?
Sounds like a plan.
Lets get back to my initial steps list. Am I correct in figuring a clean scan of the solder side done AFTER the JAE connector is removed will suffice? Will you then be able to do a "drill map/list" for all the thruholes on the FPD card for use in designing carrier cards, starting with an interface setup for the North 40 daughtercard?
Actually, I don't think the removal is necessary at all — and it's worth skipping given what turned up when I looked into that specific connector.
The JAE PICL-60P-LT is a documented, if discontinued, part: 1.27mm (0.050") pitch, 2-row, 60-position, through-hole right-angle. It shows up specifically as a "Sharp-PC connector" in a writeup by someone who tracked down a modern pin-compatible replacement (Hirose's HIF6A-60PA-1.27DS) after Digi-Key discontinued the JAE part — which lines up exactly with your "unobtanium" read on it. The point that matters for your question: because it's a standard, identifiable connector family with a known, fixed pin grid, its footprint doesn't need to be physically exposed or scanned at all. I can place its exact 60 pin positions on the drill map by reference to that datasheet grid, calibrated against the connector body's visible outline in an ordinary scan — with it left fully in place. That also means it stays intact and re-populatable if you ever want the card running standalone in the SE again, rather than committing you to re-sourcing or re-qualifying that Hirose replacement down the line. And since it turns out to be 1.27mm pitch rather than something in the 0.1" family, it was never going to be a convenient hand-tap point anyway — another reason to just leave it alone and work around it.
So: scan the solder side as-is, connector and all, same true-scale calibration convention you've been using (the 123mm width reference). Once I have that clean scan and you confirm the silkscreen designator matches PICL-60P-LT, I can build the complete drill map — every IC pad, via, mounting hole, and passive footprint, with the connector's 60 positions dropped in from the datasheet rather than the photo — as the base reference for the North 40 daughtercard interface and whatever carrier cards follow. Since nothing's being desoldered, testing card function first is now more "nice to have" than a hard prerequisite for this particular step, though obviously still worth doing before you commit to anything downstream of it.
Sources:
Forget about the connector for now.
We don’t have a good image of the solder side of the board at this point. You mapped my photos to the physical, measured outline of the board. They still suffer from single point perspective drift at top and bottom. For you to map every thruhole accurately enough for a daughtercard to slide down the wire wrap pins coming up through the passthru sockets you identified, we’ll need a very clean scan of the board done with it as flat as possible, no?
Yes, and it's a real distinction, not just extra caution. The perspective drift in the camera photos is a projective effect — it's non-uniform across the frame, worse toward the top and bottom, and by nature not something a single calibration factor fully removes. That was tolerable for the buzz-testing and schematic capture, because all that mattered there was whether two points connected, not their exact coordinates. A daughtercard sliding onto wire-wrap pins is a different problem entirely: every hole has to land within a fairly tight mechanical tolerance of a rigid grid, and that error compounds across a 120mm+ board with dozens of holes. A flatbed scan uses a parallel optical path referenced to a fixed, known DPI — there's no equivalent projective distortion to correct for, and it also removes the current step of calibrating a photo against the measured 123mm board width, since the scanner's stated DPI is the calibration.
The real obstacle is that the board isn't flat once populated, so getting true platen contact takes some care:
The JAE connector's body is the main offender — it's the tallest thing on the solder side, and if it's resting on the glass it'll tip or rock the rest of the board just enough to throw off everything else, not just its own footprint. Since we already decided its pin positions are coming from the datasheet rather than the scan anyway, the fix is simple: position the board so the connector overhangs past the edge of the platen entirely, rather than trying to accommodate it. It's on the board's PDS-facing edge, so this should be straightforward. Everything else on the solder side — ordinary solder fillets, VRAM/passive leads — sits low enough that it generally isn't a problem for a flatbed's depth of field.
If the lid can't close flat over the board with the connector hanging off, don't force it down — prop it open a little and drape something dark and opaque over the top to block ambient light instead. That's a normal workaround for scanning anything with real height, and it beats compressing the board against the glass.
For resolution, 600–1200 DPI is worth doing even though it's more than strictly necessary — it gives headroom for me to precisely locate hole centers by eye/pixel rather than working right at the edge of what's resolvable, and at that resolution any residual sub-pixel measurement error becomes negligible next to your actual manufacturing tolerances.
One more option worth having in your pocket: since the GALs and ROMs are socketed and pulling them is zero-risk, you could also scan the component side with them removed as a cross-check — thru-holes go straight through the board, so hole centers measured from either side should agree once mirrored, and having both gives you a way to catch any local distortion that slips through on just one pass. Not required if the solder-side scan comes out clean with the connector off-platen, but useful insurance given how much rides on this one.
So much easier to remove that dang connector! Once done, I can use washers to hold the card level on the platen. They’d be equal to or a tad thicker than the height of the tallest pin/soldertail protruding from the PCB.
Making the PDS adapter replacement for Magicbus is a lot less expensive in terms of time, money and pulled hair than a trial and error approach to interfacing daughtercard/wire wrap pins.
The washer/shim approach is the right call — that's a cleaner solution than my overhang workaround, and it's moot now anyway with the connector coming off. One refinement worth doing before you cut or select washer thickness: measure the actual tallest protrusion with calipers or a depth gauge rather than eyeballing it — solder tails are usually pretty uniform, but a stray taller blob or a socket pin that wasn't clipped as short as the rest is an easy thing to miss by eye, and if it's taller than your washers you're back to a board that won't sit flat. Worth checking a handful of candidate spots, not just one, and matching washer thickness at all the support corners so nothing's tilting the board even slightly off-parallel to the glass.
And yes — the reasoning on the PDS adapter holds up well now that it's laid out end to end. The FPD board only needs to be touched once for all of this (pull the connector, get the clean scan, done), rather than staying a recurring dependency every time you need to interface something new to it. Everything downstream of that — bring-up, the daughtercard, whatever comes after — runs through the new adapter's connectors, which are modern, documented, and actually sourceable, instead of riding on a 40-year-old discontinued JAE part you'd otherwise be chasing replacements for indefinitely. That's a genuinely better trade than iterating trial-and-error against original hardware that's already fighting you on multiple fronts — it also means once this pass is done, both FPD cards go back to being intact, undisturbed reference units rather than staying in the modification loop.
Finally I've convinced you!
Ha — fair, and honestly earned. You kept correcting me toward the more grounded answer at each step: the corroded-card mixup, the J2A bottleneck, the connector pitch, and now the flatbed-vs-photo distinction. That's a good sign for the project, too — better to have hashed out the wrong turns in conversation than half a board's worth of drilled holes.
Good luck with the connector pull and the scan. Ping me when you've got it and we'll turn it into the drill map.
Performer was another company, not Radius, and an unrelated product. The Radius16 had the sixty connections to the JAE female connector implemented and MagicBus was a low cost jumper card for use of the FPD/TPD for SE sans accelrator.
Noted, and that's a much cleaner picture of the actual lineup — thanks for straightening it out. Performer being a separate company entirely means I shouldn't be mentally grouping it with anything Radius-specific; it's just a card you want to physically co-locate on the same board, nothing more.
And the Radius16/MagicBus relationship makes a lot more sense now: the accelerator itself carries that same 60-pin JAE female connector natively, so MagicBus was simply Radius's cheap way to give FPD/TPD owners without the accelerator access to that same interface. That also explains cleanly why Radius16 worked as your fallback path earlier — it wasn't a workaround, it was doing exactly the job it was designed for. And it's a second, independent confirmation that 60 lines really is the full interface FPD/TPD need, since Radius built two separate products around that exact same pinout rather than just one.
You said you had the footprint for the female connector on the MagicBus card, do you have the footprint of the four rows of fifteen male connector on FPD for use on the PDS adapter card?
Let me be precise about what I actually have, because I think there's a mix-up between two very different connectors.
What I found for the MagicBus card's connector (JAE PICL-60S-ST, the 1.27mm-pitch original part) wasn't really a detailed footprint either — it was the general envelope dimensions of its modern replacement family (Hirose HIF6A, 60-position, right-angle: roughly 59mm x 49.5mm x 56.65mm overall). That's useful reference info, but it's not a pad-by-pad CAD footprint, and more importantly it's a completely different, unrelated connector from what you're asking about now. That 1.27mm JAE part is the one coming off FPD entirely for the scan — it has nothing to do with the new interface.
For the four rows of fifteen 0.1"-pitch pins going on FPD's component side, what I gave you earlier was generic dimensional guidance for that connector family as a whole — 0.025" square post, standard 0.1" pitch, roughly 0.040"-0.045" PCB hole on the header side and something like 0.057" on the socket side for one example Mill-Max part. That's not a real footprint either. A usable footprint needs two things I don't have yet: the row-to-row spacing between your four rows (is it a uniform 0.1" grid front-to-back the way it is pin-to-pin, or something else you've got in mind?), and a specific manufacturer/part number for the header and socket pair, since different vendors' 0.1" wire-wrap families vary in body length, shroud presence, and locating features even at the same pitch.
Give me the row spacing and, if you've already got a candidate part in mind, the part number, and I'll pull its real footprint rather than working from family generalities.
Got it. When you’re searching for anything related to connectors, sockets, ICs and such, you can stop and ask me for help. I see a lot of reports that you can’t read pages. You can’t read DigiKey’s pages, but if you have a part for which you’d like me to snag specs like these. I’m better equipped to do the legwork. ;-)
This is exactly the kind of document that would've taken me several failed fetches to piece together — thank you. And yes, going forward I'll flag connector/part lookups to you directly rather than grinding against blocked pages; you clearly have better reach than I do here.
A few concrete things came out of this:
First, a real discrepancy worth resolving before you commit to parts. Both this Preci-Dip catalog (page 139, "Open Frame/Wire-Wrap") and the Harwin sheet you sent earlier agree on something specific: a wire-wrap socket's own PCB-mounting tail is the familiar 0.025" (0.635mm) square post, but the socket's contact — the part that actually grips whatever gets plugged into it — is only rated to accept round pins in the 0.40mm-0.56mm diameter range. That's meaningfully smaller than a 0.025" square post's flat-to-flat width, let alone its corner-to-corner diagonal. So if the plan is genuine 0.025" square wire-wrap posts on FPD's new header plugging directly into these sockets' contacts on the PDS adapter, that's an oversized mating pin for what these particular parts are rated to accept — worth flagging now rather than after you've committed to a socket order. If the header pins are actually going to be more modest round pins (~0.5mm), the whole Preci-Dip DIL/SIL open-frame family here is a clean fit; if you want true square wire-wrap posts on both sides of that mating pair, we'd need a socket explicitly rated for that cross-section instead.
Second — page 150, "Staggered Zig-Zag Strips," might be exactly the part family you had in mind when you said "offset rows." It's a SIL strip where the pins alternate between two staggered rows within a single strip (5.0mm row-to-row offset per the drawing), rather than a plain single-row header — which maps naturally onto "four offset rows" if you're picturing two of these strips side by side. Worth confirming: is that the part type you're picturing, or something else? One practical note either way — like the earlier Harwin part, the standard order codes here jump from 14 to 16 ways with nothing at 15, so if you need exactly 15 per row you'd be looking at either a 16-way strip with one position left unpopulated, or a custom/consult order.
Those were the first two things I ran across to use as examples, didn’t even twig to the fact that it was a machine pin product line. Those wouldn’t work at all! The pin-thru sockets we identified are intended for square pins compatible with wire wrap. Round pins are not.
Good catch — that's the distinction that matters. "Machine pin" sockets (what both the Harwin sheet and that Preci-Dip catalog turned out to be) are built to grip a round IC lead; the spring clip and rated diameter range are sized for that, and a square wire-wrap post doesn't belong in one. Real wire-wrap sockets are a different product line entirely — same general form factor, but the contact is sized and rated for the square post specifically.
That actually points back to the Mill-Max 1001 series I pulled earlier, before this detour — its datasheet explicitly states it accepts 0.015"-0.025" pins, which covers a 0.025" square wire-wrap post directly rather than falling short of it the way these machine-pin parts do. That's the right family to be looking in, not what got uploaded just now.
Do you want me to run down a couple more genuine wire-wrap-rated socket options in that vein (Mill-Max has several series, and there are a couple other manufacturers worth checking), or do you already have a specific part queued up you want me to pull real dimensions for?
Yep, but in the next go round, it's way past my bedtime.
Sounds good — sleep well. We'll pick up the wire-wrap socket search (and everything else on the list) whenever you're back at it.
482
Got a fabulous breakdown of the entire project to date: DevLog in Claud's color coding for emphasis, not mine.
Inquiry:
That was a very long session with several unrelated tangents, the first being my failure to make sure you got my diagram of the PDS adapter.
Fair point — that imageshack detour cost a few exchanges before the direct upload sorted it out. But once the actual diagram was in front of me, things moved fast: the J2A bottleneck, the staggered pin mismatch, all of it came from images and documents you put directly in front of me, not from anything I dug up on my own. Direct upload just works better here than a link, and now we both know it.
Good night — this one covered a lot of ground.
I’m up and at it again, was trying to make sense of the gaps in communication. I’m running a development log for the project, hoping to help others go down this path. Could you do a synopsis of the session documenting our missteps/unrelated tangents.
It covers eight distinct missteps/tangents in rough chronological order: the imageshack dead-end, the flawed signal-tap plan that a real photo corrected, the scope creep on the adapter's signal set, the two connector misidentifications (Performer/Radius, and the PICL-60P-LT pitch assumption), the two rounds of "avoid removing the connector" advice that got overtaken by simpler calls, the square-vs-round pin catch from the Harwin/Preci-Dip datasheets, the access-limitation process fix, and the separate BlueSCSI/1400 tangent — closing with a short takeaways list aimed at other people pairing with an AI assistant on similar hardware work.
_________________________________________________________________________________________
Dev Log: FPD Clone / PDS Adapter Session — Missteps & Tangents​
Context: This entry covers one working session on the Radius FPD clone project, focused on planning the SE-PDS-to-MagicBus adapter and the physical interface to the daughtercard. It's written up separately from the technical decisions themselves because the process — where an AI assistant helped and where it went sideways — is worth documenting for anyone else pairing with one on a reverse-engineering project like this.
1. Image sharing: skip the third-party host, upload directly​
First attempt to share reference photos was a gallery link (imageshack.com) plus a few direct CDN image URLs. None of it got through — the gallery page was blocked by the site's own robots rules, and the direct image links were blocked outright by the assistant's sandboxed network policy (the same category of block that had already shown up on archive.org and Ubuntu's package mirrors earlier in the project). No workaround exists for either — both are policy-level, not glitches to retry.
Switching to direct upload into the chat worked immediately, every time, for the rest of the session (board photos, a hand-drawn adapter diagram, connector datasheets). Lesson: don't route images through an external host for an AI assistant to fetch — upload them directly. It's faster and it doesn't depend on the assistant's network access matching whatever host you picked.
2. Chasing a signal-tap plan that a clearer photo made obsolete​
Early in the session, working only from a verified pinout CSV, the assistant proposed hand-tapping 14 "missing" PDS signals directly off the physical MagicBus card — reasoning that since the card plugs into the SE's PDS slot, it must physically receive all 96 signals even though only 56–60 get routed onward.
That assumption turned out to be wrong. A clean photo of the actual MagicBus card showed its input connector (J2A) is itself only a 60-pin part — meaning only 60 of the 96 PDS lines ever reach the card at all, not 96. The proposed tap plan was only partially valid at best. This is what confirmed the already-in-progress plan for a dedicated PDS-to-MagicBus adapter card (going straight into the real 96-pin slot) was the right call, not a workaround to reach for.
Lesson: a real photo of the actual hardware beat several rounds of pinout-table reasoning. The assistant's inference from documented data was internally consistent but wrong about the physical connector; a single clear image corrected it in one pass.
3. Scope creep on the adapter's signal set​
After the J2A discovery, the assistant drafted a more elaborate adapter design that broke the extra PDS signals out onto the MagicBus connector's unused third pin row, assuming the new adapter needed to exceed MagicBus's original 60-line set. It didn't — the adapter's actual scope was always just to reproduce those same 60 lines, since that's everything the FPD/TPD cards were ever designed to need. One clarifying line from the project owner cut the design back down to what was actually required.
4. Two connector identification misses​
  • Performer Accelerator was, at one point, being treated as a Radius product related to this signal chain. It's an unrelated company's product that just happens to be sharing physical board space — no relation to MagicBus or the Radius16 accelerator's design lineage.
  • The FPD board's own JAE connector (PICL-60P-LT) was initially assumed to belong to the same 2.54mm/0.1" wire-wrap connector family the project had been sourcing for months. Research turned up that it's actually a 1.27mm-pitch, discontinued part, confirmed via an independent writeup identifying its modern Hirose replacement. Worth catching before any hardware decision was made on the wrong pitch.
5. Two rounds of "avoid removing the connector" advice that got overtaken by simpler calls​
The assistant twice proposed workarounds to avoid desoldering a connector — tapping a corroded spare MagicBus card instead of the working one, then later suggesting a scanner-overhang trick to scan around the FPD board's connector without removing it. Both were reasonable risk-averse suggestions, but in both cases the project owner opted for the more direct route once the actual risk was reassessed (the J2A bottleneck made the first workaround moot; matched washers to level the board made connector removal cheaper and cleaner than working around it for the second). Lesson: a cautious default isn't always the most efficient path — worth revisiting once new information changes the actual risk.
6. The square-pin vs. round-pin catch​
Two uploaded datasheets (a Harwin wire-wrap IC socket sheet, a Preci-Dip DIL sockets catalog) were offered as quick reference examples, not vetted candidates. Both turned out to be "machine pin" socket families — rated for round IC leads (0.40–0.56mm), not the 0.025" square wire-wrap posts the actual interface needs. The mismatch wasn't obvious from either single spec sheet in isolation; it only became clear once real numbers from two independent manufacturers were compared side by side. Both parts were ruled out immediately once flagged.
7. Process fix that paid off immediately​
Partway through, it was made explicit: when the assistant can't reach a page (blocked by robots.txt, 403s, bot protection — this came up repeatedly, including on 68kMLA and several vendor sites), stop retrying and ask for the datasheet directly instead of struggling with fetches that were never going to succeed. The very next datasheets came in as direct uploads and resolved a real design question (the pin-diameter mismatch above) in one pass. Lesson: know your assistant's access limitations early, and route around them by supplying documents directly rather than letting it grind against a wall.
8. One clearly unrelated tangent​
A separate thread — building blank, pre-partitioned BlueSCSI disk images for a PowerBook 1400 multi-boot SD card, including SCSI ID convention research and HFS partition size limits — ran through a good chunk of this session. It's a legitimate, useful piece of work, just on a different project entirely (the 1400 PCMCIA effort, not the FPD clone), and is logged separately.
Takeaways​
  • Upload images/files directly; don't route through a third-party host.
  • A real photo of the actual hardware outranks inference from documentation every time — get one before building a plan around an assumption.
  • Flag an assistant's access limitations explicitly and early; it saves rounds of wasted retries.
  • Datasheet numbers from two independent sources are a cheap, effective way to catch a spec mismatch that a single sheet's phrasing can hide.
  • Cautious/non-destructive alternatives are worth proposing, but don't assume they're automatically the right call — re-check once the actual risk picture changes.
482
The pics Claude couldn't access from ImageShack:
Much confusion ensued. Adapter facilitates reconnection of FPD card to SE PDS after PITA connector removed from solder side of FPD card. That's necessary to get a good scan of the solder side:
I'll check previous session posts and add requisite pics to them.
note: I realize this project is insane, my reply to BMOW when he told me developing a new card was the proper path to be taken:
This project is a love letter to my first Mac. At the end of 1987 I got an SE/20/Radius16 Accelerator that I very quickly topped out at 4MB. It was part of a Vertical Market System for making signs, hence acceleration and Math CoPro for CAD/CAM. I drooled over advert pics of the Radius FPD whilst slaving away doing large scale graphics through the pathetic periscope of a Compact Mac.
FPD Card of dreams is clonable as is the Radius16, so those are my two projects, VidCard first with its drivers in ROM and only a bitty little addition to the System Folder required.
Such was the peak of Compact Mac DTP productivity in that time frame.
Mentions of adding the cloned Performer accelerator to the first iteration of FPD Clone would be a sorry approximation of a future Radiu16/FPD/SE combo clone, but good enough to kick the SE in the @$$ hard enough to more than make up for the performance hit of adding FPD page buffer overhead to a stock SE.
