Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
477
Good eye — that continuous line is real. Zooming into just the photo (no overlay), you can see the trace itself runs right through the ink stamp without interruption — the ink is sitting on top of the solder mask, so seeing copper trace geometry "through" it just confirms it's genuinely part of the board surface at that spot, not a stamp artifact.
But before jumping to a 4-layer buried-plane explanation, I'd want to rule out a much simpler one: U25 and U26 are unimplemented footprints — nothing ever gets soldered there. If Radius's layout software saw those two pad rings as dead space (no populated pins to keep clear of), running an ordinary 2-layer trace straight through the middle of that footprint costs nothing and avoids needing a jog around it. That would fully explain a trace visually "connecting" U25 and U26 without needing anything exotic — it's not really connecting the footprints at all, just happening to physically transit the space between their pads on its way somewhere else on the net.
A true 4-layer power/ground-plane implementation would be a bigger claim, and worth being skeptical of by default: 4-layer boards were meaningfully more expensive to fab in 1986-88, and would be an unusual choice for what's otherwise a fairly conventional double-sided accessory card — though the trace density you've been finding isn't nothing, so I wouldn't rule it out purely on cost grounds either.
A few ways to actually settle it rather than guess:
  1. Check where that line's endpoints actually go. Does it terminate at real component pins elsewhere (i.e., it's just one ordinary net passing through the dead footprint en route from A to B), or does it appear to dead-end at U25/U26 pads specifically with no other explanation for continuity between them? The former supports "ordinary trace through empty space"; the latter is more interesting.
  2. Cross-check against your component-side trace/thruhole layers at the same XY. If there's also a component-side trace at that same location forming part of the same apparent net, that's double-sided routing, not a buried layer — no exotic explanation needed.
  3. Physical test for real layer count, if you want to settle it conclusively: look at a via barrel or the raw board edge (if any is exposed/unmasked) under strong magnification and backlighting. A 2-layer board's via cross-section shows plating only at top and bottom; a 4-layer board shows an additional annular ring or copper reveal partway through the barrel. This is the only truly non-destructive way to confirm internal layers without buzzing things out blind.
If after tracing the endpoints it really does look like an isolated net that only makes sense through a plane, that'd be a genuinely notable find for a card of this vintage — just worth ruling out the boring explanation first given how well it fits (unimplemented footprint = free real estate to route through).
Graphics workstation, now a Mirror Drive Door G4 setup upgrade, is Neolithic 2004 tech along with my software. Like my hardware, I live in the Neolithic when it comes to this kind of thing as well. Taking a file to the edge of the board at a low angle exposes layers like a spectrum. I can determine the number of layers without fooling around with less radical, error prone conventional approaches. ;-)
Fair enough — that's a genuinely better answer than either of mine. A low-angle bevel file exposes the whole stackup at once as a visible cross-section, no probing, no blind buzzing, no hoping a via barrel happens to be visible at the right spot. Metallurgical prep labs call it a "bevel section" and it's exactly the technique used for real PCB failure analysis when someone needs to count layers with certainty — you're not roughing it, you're just skipping the expensive lab equipment version.
One small technique note in case it's useful: keep the bevel angle shallow and consistent (something like 5-10°) rather than steep — it stretches out the layer spacing so thin internal planes don't get lost in file-scratches, and a drop of oil or water on the exposed face while you inspect it under light will make the copper-vs-substrate contrast pop a lot better than looking at it dry.
Good luck with the U25/U26 net — genuinely curious whether it turns out to be the dead-footprint explanation or an actual plane. Either way you'll have a real answer instead of a guess.
Very shallow angle and liquid emulsion are my methods!
Good — that tracks with knowing exactly what you're doing rather than winging it. Let me know what the bevel turns up on the U25/U26 net once you've had a look; genuinely curious which way it goes.
Reactions: Froggy814
477
Here's the first pass, built on the confirmed J1/clamp-network subsystem — "half the data" as promised:
What it shows: the J1 header and its clamp network overlaid directly on the true-scale component-side photo (labels are legible there, unlike bare copper on the solder side), with a pinout sidebar breaking down what's confirmed for pins 2/3/6/7/9, plus notes on the Zener clamp network.
How I handled confirmed vs. unconfirmed, per what we agreed:
  • Green boxes/text = things you've actually buzzed out (J1 pin functions, the clamp network's populated parts).
  • Red dashed line = CR3, called out specifically as untraced.
  • Red text = the Zener common node's destination (a GAL pin 13, designator still TBD).
  • I deliberately left out any long lines running clear across the board to U22 or U2 — I don't have verified pixel coordinates for those ICs' exact locations, and drawing a line I haven't actually confirmed against the image felt like the wrong kind of "confident." Instead those two nets are just stated in the sidebar text (pin 7→U22 pin 7, pin 9→U22 pin 8, pin 3→U2 pin 7) as confirmed facts without a hand-drawn path backing them visually.
Once you've got the component-side buzz-out done, the natural next version would extend this same treatment out to U22 and U2 with real traced paths instead of sidebar text — happy to build that when you're there.
Got it! Thanks for giving me the little available. Understood that the vertical traces on the solder side offer little, if any, clues as to the web of connections between ICs on the board. Horizontal connections buzzed and annotated should tell the tale? Lots of work to do before getting close to there.
That tracks with what we've been seeing. If the solder side is running mostly vertical bus-style traces — signal comes down from an IC, travels a long straight run, and doesn't reveal on its own who it's actually talking to — then it's functioning more like a highway than an intersection. The real "who talks to whom" information lives at the horizontal jogs, which is exactly where a trace is doing the work of steering a signal from one column/IC to another.
Two things worth watching for as you buzz the horizontal runs:
  • Vias are the tell. Anywhere a vertical solder-side run ends and a horizontal component-side run picks up (or vice versa) is a layer change, and that's precisely the junction that decides connectivity. If you can spot and log via locations as you go, that gives you a skeleton of "decision points" even before every horizontal segment is fully buzzed.
  • Watch for false continuity at crossovers. Since the layers are perpendicular by convention, a vertical trace and horizontal trace crossing in the photo aren't connected unless there's a via right at that intersection — worth flagging in your notes explicitly (confirmed via vs. incidental crossing) so future-you doesn't second-guess it later.
Given that, the horizontal/component-side buzz-out is genuinely the higher-value half of the remaining work — the solder-side vertical traces you've already got mostly tell you that a net exists and roughly where it runs, not which IC pins it ultimately ties together. Real slog, but it's the part that actually builds the netlist.
Cool beans! Though not a programmer of note, I’ve heard of vibe coding, I’m thinking of this as vibe diving!
"Vibe diving" is a great name for it — no compiler to catch your mistakes, just a multimeter, a magnifying glass, and faith that the next trace goes where you think it does. Bad continuity reading is basically vibe coding's runtime error.
Enjoy the dive — ping me when you surface with more nets.
Will do. I've found your time stamped operations reports fascinating, could you provide a tight txt file of your processes as displayed while I wait for results. I think others will find it interesting.
Glad it was useful — good luck with the buzz-out, and enjoy the dive. Ping me whenever you want to pick this back up.
477
This one sort of stopped where I'd hoped it would begin, but still interesting I think?
_____________________________________________________________________________________________________________
RADIUS FPD (SE) CLONE PROJECT — CLAUDE PROCESSING LOG
Session date: 2026-08-30/31 (image pipeline) + 2026-09-10 (diagram build)
Tools: Python 3 / OpenCV / PIL / scikit-image / reportlab / poppler-utils
PHASE 1 — PHOTO STRAIGHTENING & TRUE-SCALE CALIBRATION
23:38:50 Rasterized FPD-Schematic-012.PDF (150dpi) to inspect vector
board-outline reference; confirmed it covers J1/crystal/
U2-U7/ROM area only, not full board.
23:39:50 Cropped silkscreen text regions on all 3 uploaded photos
(Solder-V, Component-V, Component-VM) to determine true
orientation by reading text forward/backward.
Result: Component-V and Component-VM both required 180
deg rotation; Solder-V was already correctly oriented.
23:40:32 Rendered 180-degree-corrected previews for visual QC.
23:42:12 Applied gross 180-deg flip + fine auto-detected skew
correction (OpenCV minAreaRect on board contour vs.
background mask) to all 3 photos. Residual skew found:
Solder-V +0.211 deg, Component-V +0.143 deg,
Component-VM -0.141 deg.
23:42:22 Cropped all 3 straightened images tight to board contour
bounding box (20px margin). Board bbox width consistent
across all three: 2732px -- confirms same camera distance
for all shots.
23:46:03 Saved final straightened/cropped outputs, generated
downscaled previews for visual verification.
PHASE 2 — LIFE-SIZE CALIBRATION
User-supplied reference measurement: PCB width = 123mm (calipers).
Calculation: 2732px / (123mm / 25.4) = 564.17 px/inch native.
Derived DPI tags: 1x = 564.2, 2x = 282.1, 4x = 141.0 dpi.
Applied as embedded JPEG DPI metadata (no pixel resampling) so
files print/place at correct real-world scale in any DPI-aware
app. Later regenerated as 8-bit (256-level) grayscale JPEGs at
same three DPI tiers to cut file size ~3x for period-correct
Illustrator 8 hardware (originally a 2004/5 PowerBook, later a
Mirror Drive Door Power Mac G4).
PHASE 3 — AUTO-VECTORIZATION (TRACE + PAD EXTRACTION)
23:57:00 HSV color-threshold segmentation of copper traces
(hue ~55-105, i.e. the teal exposed-copper color) and
through-hole pads (low-saturation/high-value, circular
blobs) on the solder-side image. Masked to board interior
to avoid background contamination.
23:58:07 Extracted 2,420 trace contours + 821 pad circles (solder
side); pickled intermediate geometry.
23:58:25 Built true-scale vector PDF (reportlab): board outline
(stroked), traces (filled teal polygons), pads (filled
gray circles). Page size set from the 123mm calibration.
23:58:30 Rasterized result at 300dpi for visual QC.
23:59:11 Repeated full pipeline for component-side image: 2,358
trace contours, 715 pads. Noted lower reliability here —
less color contrast around IC/ROM footprint silkscreen
boxes causes some non-trace fill artifacts.
00:00:22 Converted both vector PDFs to Level 2 EPS (poppler
pdftops -eps -level2) for native Illustrator 8
compatibility (AI8 predates Adobe's PDF-based file
format, introduced in Illustrator 9).
PHASE 4 — ANNOTATED DIAGRAM (J1 / CLAMP NETWORK)
01:38:14 Cropped candidate regions of the component-side photo
searching for the J1 header and clamp network by e
Reactions: JDW and Froggy814
2,209
@Trash80toG4
I apologize for not having followed your thread until today.
Since you and I do not fear LLMs as some do, I used Gemini to highlight the main points of your two-page thread and compile a progress report. I did that for the sake of newcomers to this thread who otherwise may be overwhelmed by the level of detail posted thus far. But if any of the content below is incorrect, let me know and I will edit it.
📋 Project Overview & Specs​
  • Goal: Replicating the 1986 Radius Full Page Display (FPD) card. This vintage hardware allows a Macintosh SE to output to a portrait monitor.
  • Specs: It runs a 640 × 864 monochrome (1-bit) video signal.
  • Modern Twist: Because original monitors are rare, @Trash80toG4 is designing an FPGA-based addition to rotate the portrait image 90 degrees clockwise so it can display right-side-up on a modern 1024×768 landscape monitor.
🚦 Current Progress Report: How Close Is It?​
Short answer: Early-to-mid phases.
While a massive amount of foundational engineering and data gathering is complete, @Trash80toG4 is still far from an actual working physical clone.
Here is how the project breaks down across its major milestones:
1. Video Rotation Math & Logic — 🟩 95% Complete
  • The mathematical formula to rotate and center the pixels on a modern screen has been completely solved and verified using small-scale tests.
2. PCB Reverse-Engineering (The Netlist) — 🟨 60% Complete
  • Completed: @Trash80toG4 has successfully calibrated life-sized photos of the original board and hand-vectorized the entire solder-side (bottom) copper traces. Crucial components like the video header (J1), power filters, and input-protection diode networks have been mapped out.
  • Stuck On: @Trash80toG4 is currently shifting focus to the component-side (top) traces. They must manually "buzz out" (test continuity using a multimeter) the horizontal connections to see exactly which chip pins link together. They also found mystery "hidden traces" and are using a file to shave a spare board down at an angle to see if it is secretly a complex 4 or 6-layer board.
3. Sourcing the Missing Sychronization Clocks — 🟥 10% Complete
  • The Blocker: To make an FPGA work, it needs a "Pixel Clock" signal. This signal doesn't exist on the external video connector. @Trash80toG4 is currently trying to trace backward through the timing chips to find exactly where on the board they can tap this clock.
4. Hardware Cloning, GAL Decryption, & FPGA Design — 🟥 0% Complete
  • What's Left: Once the schematic is finished, the custom programmable chips (GALs) on the original board must have their logic formulas extracted. Finally, @Trash80toG4 has to design a brand-new expansion circuit board layout in KiCAD, solder a prototype, and write the custom code for a companion FPGA chip.
💡 Summary for Newcomers​
The thread is a goldmine of data because @Trash80toG4 is sharing an "AI-assisted engineering notebook". He's leveraging AI tool to clean up photography, auto-calculate scaling, write engineering specs, and double-check manual trace layouts.
Right now, the project is a deep, slow-burning detective mission using a multimeter, magnifying glass, and old-school design software to map a 40-year-old circuit trace-by-trace.
Reactions: Trash80toG4
477
Thanks, that summary is very much appreciated! Looks great.
- I won't be doing the schematic capture, Claude will do that from my Solder and Component side "coloring books."
- I imagine the PCB design will be done for me as well. ;)
Hoping the long form play by play might have others wondering how to leverage AI in their own enjoyment of the hobby.
edit: forgot to mention that AI can do all the coding to set up the FPGA side of things! We'll be doing that on a project board as soon as I can locate a wedge to pick up the pixel clock before heading into reverse engineering the balance of the board.
2,209
Well, I wish to humbly thank you for your contributions to this forum!
I'm now looking forward to seeing how your project unfolds over time.
Best wishes,
James
477
This one's pretty cool, while Claude was having trouble nailing down a pinout I did an end run and did it visually before he reported back. Great stuff, it's like dueling abilities and dueling limitations all at once.. Sweet music to my eyes! :)
continue the PCB reverse engineering project
I’ve rotated the Component side of the project so ICs appear upright.
Pinout Verification-2.pdf
Did I get the pinout inputs done correctly?
ISTR you saying that GALs U10 and U9 dffer internally, but are the pinouts the same?
I need a text file for that if different and also for GAL20V8-25LP as I can’t locate that one in the last batch of pinouts?
FPD-Comp-Buzz-Verify-005.pdf
Solid purple VIAS represent connections to the solder side and visible trace segments on the component side. I’ll be running down those first. Then I’ll buzz and connect traces for the IC covered VIAs. After that I’ll buzz the rest of the visible traces for the IC to IC connections. I’ll report each addition when complete for feedback. Would you suggest a revised order of processes to gain an earlier take on schematic capture progress?
FPD-Component-Buzz-005.ai
Can you read the layered AI8 file directly or should I continue breaking layers out to dedicated single layer .PDF files?
The AI8 file is very helpful with the Solder Side trace overlay. I can run the cursor “across the strings” of the solder side traces to play the VIA/Pad overlaps like a visual version of a string instrument. If I were to do manual input schematic capture this would be a great help. Of course you’ll be doing the capture, but it really helps in my visualization process mode.
Last I have on file, we'd left off preparing a clean annotated diagram of confirmed J1/signal-trace connections for a forum post (solid lines for buzz-tested connections, dashed for photo-inferred ones). This is a fresh session, so I don't have any of your board photos, schematics, or AI8/PDF files loaded yet. How do you want to pick this up?Continue the hand-tracing/continuity work
Here's where we left the hand-tracing/continuity work, per my notes:
Open threads on the solder-side/component-side trace-out:
  • What CR3 connects to — traced partway but couldn't pin down where it lands; set aside unresolved.
  • Component-side buzz-testing was still partial when we last talked (solder side was fully hand-traced, component side in progress).
  • You'd traced the red-drawn connection between the Zener diodes to pin 13 on one of the GALs, but hadn't confirmed which GAL designator that is.
  • The board's layer count was going to be determined by filing the edge at a low angle to expose the copper in cross-section — don't think that happened yet.
Since this is a fresh session I don't have any of your board photos, the AI8/PDF schematics, or the Pinout-CHECK files loaded — I can't see anything until you either attach files here, connect your computer/folder so I can read them directly, or just tell me what you found and I'll log it and help reason through next steps.
Whichever's easiest — what would you like to tackle: nail down CR3, confirm that GAL designator at pin 13, sort out the layer-count filing, or something new you've found since we last talked?
GALs — U9/U10 pinouts and the LNC/LP question
Rendered your export at 400dpi to actually read it. U9, U22, U17, U13, U8 are all GAL20V8 (either -25LNC or -25LP), and U10 is a different part, GAL16V8-25LP — worth noting since those aren't pin-compatible with each other.
Good news on U10: its pinout is already filled in on the board and it matches the standard GAL16V8 pinout exactly, pin for pin. Nothing to fix there.
On your -LNC vs -LP question: no, they don't differ — the -25LNC and -25LP suffixes are speed/power/process grade only (propagation delay, power draw), not pinout. Same 24-pin package, same pin-to-signal mapping for all five GAL20V8 parts. That's also why you couldn't find a separate "GAL20V8-25LP" pinout in your last batch — you'd only entered U10 (the GAL16V8) so far; none of the GAL20V8 slots have pin data yet. I put together a text file with both pinouts, cross-checked against the archived Lattice datasheet and a second independent reference — sent above.
One thing to flag on that same export: the DRAM chips (U16/U15/U12/U11) have correct, upright pin-number badges, but the function-name text next to them (SDT/OE, 9RAS, 6W0/I0B, etc.) is mirrored and looks like it's overlapping with a second copy of similar text — genuinely not legible as exported. I traced this to the AI8 file itself: it has two separate pinout-text layers (TXT-Pinouts-SS and New Pinouts), and it looks like both are visible in that export with one still carrying its old solder-side mirror transform. Worth isolating one text layer before your next export so it renders clean.
On the AI8 file — can I read it directly?
Yes, partially. I opened FPD-Component-Buzz-005.ai as raw PostScript text (it's not PDF-compatible, but the AI8 format is human/machine-parseable) and pulled out all 15 layers directly:
Solder Side Traces - FROZEN · TEMP · Component Template · Chip Outlines · Component IDs · TRACES - COMPONENT SIDE________ · CAPS/RESISTORS · VIAs · Layer 15 · Layer 14 · Thruholes · SS-Traces-Adapted for clearance · TXT-Pinouts-SS · New Pinouts · COMPONENT - ALPHA
I can pull raw vector coordinates, text-object placement, and layer contents/counts from that file without an export — useful for structural questions ("does this layer have anything on it," "how many objects," etc.). What I can't do here is visually rasterize/render the AI8 the way I can a PDF — this sandbox doesn't have Ghostscript and I couldn't install it (package fetch was blocked). So: keep sending single-layer PDF exports whenever you want me to actually eyeball something (pinouts, trace routing) — that's still the reliable path. The raw AI8 is a nice supplement for structural checks, not a replacement for visual QC. (Two unnamed layers, "Layer 15"/"Layer 14," might be worth naming or cleaning up when convenient — not urgent.)
On revising the buzz-testing order (FPD-Comp-Buzz-Verify-005.pdf)
Your plan — VIAs with visible solder-side trace matches first, then IC-covered VIAs, then remaining IC-to-IC traces — is a sound sequence. To get an earlier readable take on schematic-capture progress specifically, I'd suggest one adjustment: once you're into the IC-to-IC phase, work it chip-by-chip rather than trace-by-trace across the whole board — fully resolve every pin on one high-fan-out IC (a GAL is a good candidate, since it's the "hub" of custom logic) before moving to the next. A single chip's net list, complete, is something we can can reason about and cross-check against the pinout tables above right away; a board-wide sweep that's 30% done everywhere doesn't get you a checkable unit until much later. Your VIA-first step is already the right instinct for the same reason — it reuses confirmed info instead of blind buzzing, so I'd keep that first.
Send the next addition whenever you've got it and I'll fold it in.
I now have AI9 and AI10 installed on the MDD, but not AI8. Working files I plan to keep in the baseline AI8 format. However, If I save the AI8 file in AI9 or AI10 format to upload, will you be able to read the entire file?
Illustrator 9 10 native ai file format PDF compatible file save layers OCG
8 results
https://www.datalogics.com/adobe-illustrator-and-pdf-compatibility
www.datalogics.com
https://helpx.adobe.com/uk/illustrator/kb/optimize-native-pdf-file-sizes.html
helpx.adobe.com
Short answer: yes, and probably better than the AI8 file has been.
The reason the AI8 file I have now is stuck as text-only for me is that AI8's native format is pure PostScript (the file literally opens with %!PS-Adobe-3.0) — there's no PDF underneath it for a renderer to grab. Illustrator's native format changed at version 9: starting with AI9, the "native" .ai file is actually a real, valid PDF with Illustrator-specific private data tacked on for round-tripping, controlled by a "Create PDF Compatible File" checkbox that's on by default when saving. So if you open your AI8 artwork in AI9 or AI10 and save it out with that box left checked, the resulting file should open for me exactly like the PDFs you've been exporting — I can render it, zoom into pin labels, the works — no manual single-layer export needed on your end for me to just look at something.
Two things worth flagging before you build a workflow around it:
The checkbox matters. If "Create PDF Compatible File" gets unchecked (people do that to shrink file size, which might tempt you given the MDD's constraints), the file reverts to a non-PDF native format and I'm back to square one — same as the current AI8 files.
Layers are the untested part. I'm confident the visual render will work — that's well-documented. What I haven't confirmed is whether your named layers (VIAs, Thruholes, Chip Outlines, etc.) survive as separate, identifiable objects the way I was able to pull them out of the raw AI8 PostScript text, or whether I'll just see one flattened composite image the way I do with a normal exported PDF. Illustrator's PDF-compatible files typically preserve layers as PDF "layers" (Optional Content Groups) when reopened in Illustrator, so there's a good chance that structure comes through for me too — but I'd rather confirm it against a real file than promise it.
Easiest way to find out: next time you're saving something anyway, save one copy that way and send it over. I'll tell you exactly what comes through — render and layers both — before you commit to it as the regular handoff format.
I couldn't nail this one down to my own satisfaction, so I want to be straight with you rather than hand you something I'm not confident in.
I tried a handful of routes — direct downloads of the NEC 1986 memory data book and a couple of other archived uPD41264 datasheets, plus several VRAM pinout references (bitsavers, console5's TechWiki, a couple of datasheet aggregators). Most of those domains are blocked outright by this session's network policy (straight 403s on the connection), and the couple I could reach through the web-fetch tool only returned summarized excerpts of very large scanned PDFs that didn't happen to include the actual pin-configuration diagram — so I've got the chip's family and general signal set confirmed (it's a dual-port VRAM — RAS, CAS, W, DT/OE, SC, SE, DSF, address lines, a random-access DQ port, and a serial SAM port), but not a pin-by-pin 1–24 table I'd trust enough to hand you as ground truth for a chip this central to the design.
Given that, I'd rather not have you delete your existing solder-side-legible pinout on the strength of something unverified from me — that's real, hard-won data. Two ways to close this out cleanly:
If you've got the actual NEC datasheet (or even just a decent photo of its pin-configuration page) sitting on the MDD or wherever, send it over — I can read a PDF or image directly far more reliably than I can fetch one through this session's network right now.
Otherwise, tell me what your existing solder-side pinout currently says for U16/U15/U12/U11, and I'll check it against what I do know of the standard VRAM signal set (and against the RAS/WE/DT-OE-shaped fragments I could already partly make out in your garbled export) rather than generating a fresh one from scratch.
Either way, hang onto that old layer until we've actually cross-checked it — worst case it turns out to be exactly right and you've lost nothing by keeping it a little longer.
While you were doing your thing, I copied a link you were looking at and did it my way. :)
Nicely done — that's a clean, fully legible pinout, and it happens to answer the exact question I was stuck on. Read it at 4x zoom to be sure of every digit:
HM53461P (Hitachi) — 24-pin dual-port VRAM, pin-for-pin equivalent to your D41264C
Pin 1 SC · Pin 2 SI/O1 · Pin 3 SI/O2 · Pin 4 D̄T/ŌE · Pin 5 I/O1 · Pin 6 I/O2 · Pin 7 W̄E · Pin 8 R̄AS · Pin 9 A6 · Pin 10 A5 · Pin 11 A4 · Pin 12 VCC · Pin 13 A7 · Pin 14 A3 · Pin 15 A2 · Pin 16 A1 · Pin 17 A0 · Pin 18 C̄AS · Pin 19 I/O3 · Pin 20 I/O4 · Pin 21 S̄OE · Pin 22 SI/O3 · Pin 23 SI/O4 · Pin 24 VSS
Note the address pins aren't in numeric order around the package — A6/A5/A4 go down the left side, then VCC, then A7/A3/A2/A1/A0 come back up the right side. Worth double-checking against your board when you enter it, since it's easy to transpose those.
The HM53461P isn't literally the D41264C — Hitachi vs. NEC — but this is the same first-generation 256Kb dual-port VRAM family, and those were built to be drop-in pin-compatible across vendors (NEC uPD41264, Hitachi HM53461, TI TMS4161, Fujitsu MB81461 all share this pinout — that's the entire point of "second-source" parts from that era). It also lines up with the fragments I could partly make out in your earlier garbled export — DT/OE and what looked like RAS/WE remnants — so this checks out as consistent with what's actually on your board, not just a same-family guess.
Sent the file above — same format as the GAL pinout sheet, ready to drop into your notes once you've spot-checked a pin or two against the board. Good find on that image; saved me from having to hand you something less certain.
AI & Me = Ebony and Ivory - visual thinker adaptation.
Ebony and ivory, indeed — you look at the board and see it, I look at it and parse it, and somewhere in between we get a net list. Different keys, same keyboard.
Whenever the next round of buzz-testing or a new export is ready, send it over.
  • Pinout Verification-2.pdf
477
Pinout Verification
VRAM Pinout Discrepency – real or did I induce it in reformatting your files?
AI9 file import test:
– layers work?
– does the attached template image come thru or do I need to upload it with AI file?
The pinout files you’ve been providing come thru all messed up and need major work to get into LibreOffice and then after several steps I need to again rework in AppleWorks 6 in order to paste the columns cleanly into Illustrator.
For VRAM update and ROMs, could you try a few new approaches?
- Tab Delimited RTF file to open in AppleWorks spreadsheet to copy columns?
- LibreOffice Spreadsheet format for same.
- Straight AppleWorks spreadsheet file?
- RTF file with a double-spaced column ready to copy into Illustrator? Might be easiest?
Good — all three files check out. Now let me deliver them and cover the rest of your questions.
VRAM pinout discrepancy — not your reformatting, and not really a discrepancy. I flipped the old (solder-side-legible) block right-side up and checked it pin-by-pin against what I gave you. All 24 pin positions match exactly — RAS, CAS, WE, DT/OE, every address line, VCC, GND all land on the identical pin number in both versions. The only difference is naming convention on the two multiplexed buses: your older labels use 0-indexed names (IO0–IO3, SO0–SO3), while the Hitachi sheet I transcribed prints them 1-indexed (I/O1–I/O4, SI/O1–SI/O4) — same four physical pins, same order, just whichever datasheet's own subscript convention. Nothing got scrambled in the LibreOffice/AppleWorks round-trip. Since your old numbers likely trace back to NEC's own documentation for the actual part on your board, I'd lean toward keeping that 0-indexed naming and just use my sheet to confirm pin positions — but it's a style choice, not a correctness one.
AI9 test — layers and the template image. Good news and a caveat. I opened the .ai9 directly (it's a genuine PDF, exactly as expected) and it does carry your layer structure — I pulled out all nine layers by name (Component IDs, Component Template, Chip Outlines, TRACES - COMPONENT SIDE, VIAs, Thruholes, SS-Traces-Adapted for clearance, PINOUTS, COMPONENT - ALPHA) along with each one's visibility flag. The catch: Illustrator stores this as its own private extension, not the public PDF "layers" spec, so a plain PDF render only shows whichever layers were toggled visible when you saved — in this file that was just "SS-Traces-Adapted for clearance" and "PINOUTS," and that's exactly what showed up when I rendered it. That's actually a nice workflow upgrade over the AI8 days: you don't need separate single-layer exports anymore, just toggle visibility on whatever you want me to see and save as AI9 — I get the visual render and the full layer structure (including hidden layers) in one file.
The template image did not come through — zero embedded images in the file. Two independent reasons: that layer is currently hidden, and looking back at the original AI8, "Component Template" only ever held a file-path reference to a JPG on your Mac's drive, not embedded pixel data — so it was never actually inside the vector file to begin with. If you want me to see it, either embed it in Illustrator (not just link it) before saving, or upload the image alongside the .ai file.
On the AppleWorks native file — I'll be straight with you: I can't safely fabricate a genuine AppleWorks 6 (.cwk) binary file. It's an old proprietary format with no accessible library to write it correctly, and a hand-rolled attempt risks a file that won't open at all — worse than not sending one. The tab-delimited .txt I sent should actually get you there in one step: AppleWorks 6's File > Open has a text-import path that reads tab-delimited files straight into its spreadsheet with columns already split, no LibreOffice detour needed. Worth trying that directly and seeing if it shortcuts your whole current chain.
Send the next round whenever it's ready.
Not quite, for a 10 pin IC, the data needs to be formatted as
Looks like that got cut off before the format spec came through — what does the layout need to be for a 10-pin part? (If it's the same idea as the DIP diagrams you've sent — left column pins 1 down to 5, right column 10 down to 6, side by side — say so and I'll match that instead of the flat numbered list I've been using.)
Sorry, I hit return . . .
No worries — go ahead whenever you're ready with the rest of that.
_____________
Got it — that's the physical DIP layout: left column top-to-bottom for the low pin numbers, a divider representing the package body, then the right column top-to-bottom in descending order so pin 1 and pin 10 end up across from each other at the top, matching how the pins actually sit on the chip. That's the same convention as the datasheet diagrams you've been sending (like the HM53461P image), just without the outline box — makes sense, especially given how you think visually.
Two things before I redo anything:
Which chip is the 10-pin part, and do you have signal names for each pin, or do you need me to identify them? And do you want me to reformat the GAL, VRAM, and ROM pinouts I already sent into this same two-column layout (rather than the flat numbered lists), so everything going forward is consistent?
Ten pin example’s not an IC, just a representation of the double spaced data format easily copy/pasted into Illustrator. To do even better, a two space separation between Pin# and Signal is perfect for centering the pin number in the pad and the signal just outside its outline.
Current AI8 file pinouts are double spaced as I find that format more conducive to getting the text aligned with the life size pin pitch pads.
GAL, VRAM & ROM can be in a single file as described.
Sent — one file, all four chips (GAL20V8, GAL16V8, VRAM, ROM), each split into left/right columns matching the physical pin layout, two literal spaces between pin number and signal, blank line between every entry. Let me know if the ROM's pin-13/pin-14 split or any of the others need adjusting once you've got it lined up against a pad grid.
FPD_Pinouts_Combined
Looks fabulous, just what I requested. Nice work. Wish I’d thought about this particular problem a while back!
Glad it landed right — that format should save you the whole LibreOffice/AppleWorks relay going forward. Now that it's dialed in, any future pinout goes straight into that same layout, so send them whenever you've got new chips to add.
Great, thanks!
Anytime — good luck with the buzz-testing, and ping me when the next round's ready.
  • FPD_Pinouts_Combined.txt
477
FPD-Comp-Pinout-015.ai9
Pinout Verification – FINAL! Am I good to go?
- layer visibility check of file?
- thinking no template to be seen again in this one?
FPD-Comp-Template-015.ai9
- saved with all layers visible
- found the “Include Attached Files” checkbox!
Both files came through clean — this is looking very good, with one real fix needed.
FPD-Comp-Pinout-015.ai9 — layer check:
Only two layers are visible: Thruholes and PINOUTS. Everything else, including Component Template, is hidden — so yes, exactly as you expected, no board photo in this one. That's the correct state for a pure pinout-reference export.
FPD-Comp-Template-015.ai9 — the embed worked. Real progress: this file now carries an actual embedded raster (1386×1683px, properly compressed) instead of a dangling file-path link — the "Include Attached Files" checkbox was exactly the fix needed. I rendered it and can see the real board photo underneath your pinout overlay, pin holes lined up on the actual pads. One small note: this file has only 3 of 9 layers flagged visible (Component Template, Thruholes, PINOUTS), not all of them — probably didn't matter for what you were testing, but flagging it in case "all layers visible" was the intent for some other reason.
Pinout verification — went through every populated chip against real datasheets. Confirmed correct: all four VRAMs (U16/U15/U12/U11), both ROMs (Ux, U19), all five GAL20V8s (U9/U22/U17/U13/U8), the GAL16V8 (U10), both SN74LS393N counters (U6/U7), the SN74F161N (U5), and the SN74F109N (U2) — every pin on every one of those matches the standard part pinout exactly.
One real discrepancy: U3 and U4 (SN74F166N) have pins 13 and 14 swapped. Your file has 13=H, 14=QH — it should be 13=QH (serial out), 14=H (parallel input). I checked this against two independent sources (TI's own datasheet and a components101 pinout) plus my own knowledge of the part, all three agreeing, so I'm confident this one needs fixing on both chips before you call it final.
Two caveats on my own confidence, in the interest of being straight with you: the LS393 and F161 checks didn't get a clean corroborating source this round — several datasheet-site fetches came back garbled or mutually contradictory (I threw those out rather than trust them), so those two rest mainly on my own solid recollection of very standard, well-worn parts rather than a fresh independent citation. Worth a gut-check against a real datasheet yourself if you want belt-and-suspenders before publishing.
Also, cosmetic only: several active-low signal labels are rendering with a stray "AÑ" where the overline character should be — CLRAÑ, SH/LDAÑ, CLK INHAÑ, 1QAÑ, 2QAÑ, LOADAÑ. That's a font/encoding substitution in how the overline glyph exports, not a data error, but worth a look before this goes out anywhere public since it reads oddly.
So: fix the U3/U4 pin 13/14 swap, glance at the overline rendering, and you're good to go.
Sources: SN74LS166 Pinout – components101 · SN74HC166 datasheet – TI · 74LS109 Pinout – components101
Got it, remember asking about those “invisible characters” and left them in. I’ll try copy/pasting the glyph characters into the AI files. Deleted them and them put them back in . . . oopsie!
Ha — mystery solved. Good chance those are literally invisible in the AI font's default encoding but present as a combining overline character, so any font swap along the copy/paste chain drops the glyph and something else fills the gap. If it keeps fighting you, the plain-text fallback (just typing the bar as _L or # after the signal name, like WE_L or CLR#) sidesteps the whole font/glyph problem entirely and reads unambiguously either way — no pressure to switch conventions, just there if the copy/paste route gives you more grief than it's worth.
Good luck getting it sorted — let me know how the next pass turns out.
