Zane’s public statement about that is here:I'm having trouble finding the exact quote from the WarpSE thread, where Zane talks about being completely fine with people using his hard work and skills, to reproduce these accelerators for themselves…
Free to be forked at any time: https://github.com/garrettsworkshop/Warp-SE
I’ll put our usual license in later (which is some poorly written document which I have no idea if it’s enforceable) but basically you can do any commercial stuff with it as long as you remove the Garrett’s Workshop logos from the board.
Fingers crossed you got the right PCB version! Thank you for the effort to find out.Removed the GW logo from the prerelease Rev.3 USB PCB, in KiCad:
Created a new gerber from the above and uploaded it to JLCPCB:
Looks like $31.90 for (5) green PCB's at JLCPCB.
$51.35 total, with shipping, or $10.27 per individual PCB.
I'd have to solder each SMD/chip component by hand, in order to build the (2) I'd want.
BOM and component placement numbers are included as .CSV files in the gerber.zip attached below.
This should be everything necessary to build these, assuming this is the correct PCB revision, which I believe it is.
Fingers crossed you got the right PCB version! Thank you for the effort to find out.![]()
