That would do it. But it's interesting you made an AIX boot floppy that way. I'm interested to see what actually got on the floppy disk if you can image it before you restore it.
Oh My,John, what ANS goodies are those? Also, I'd love to pick your brains about the Shiner team - see http://www.floodgap.com/retrobits/ans/ for what I have so far, including my (sadly non-functional) ESB prototype.
I also know a lot of people would really love to find that Mac OS version that allegedly ran on early Shiners, though my suspicion from talking to the Cyberpunk guy is this would require the pre-production ROMs.
What my 500 really needs is the SMP card, but I have yet to find someone willing to part with theirs!
OH WOW,@johntucker I'd love to hear about your stories and goodies too.
I ended up with an ANS with a Dual 200MHz card. Would be fascinated to learn more about how far this made it before getting cut.
Yup, Eric started that thread (or if E-mail is better, ckaiser at floodgap dawt com). It is not difficult, just slow, to dump the ROM from OpenFirmware over a serial port.Oh My,
I didn't see this post until just today.
I am so sorry I was not ignoring you.
I'd love to share what I know and along with the goodies I sent Erics way I don't mind giving to others.
Just yesterday I was convinced to work toward making the ANS run Classic MacOS. I know 8.6 works & 9.1 should also.
What I heard was the SMP card was shitcaned because the performance was "suboptimal" (plus 10% to %20 over single 603e.)
Someone may have managed to get the processor card from a 9500/180MP or 9600/200MP to work on a ANS system board.
The Shiner system board was a modified 9500 board due to the major failure to make the an ASIC memory controller to do EEC.
The ABS made a concerted effort to to block MacOS on Shiner and the only Shiners that ran MacOS were engineering ROM builds. There were other ROMs that allowed the PowerPC build of Windows NT. I tried to get one but failed before the whole ANS project shutdown.
I remember the ESB code name but don't remember what it was. Fill me in.
I do have two of the deep dish prototypes and a 700/200 that was fully loaded but the battery has done bad things in the last few years. I think I can fix it but it will take time and some luck. Anyway Eric H has mentioned you as someone that may help with working on the special ROM.
adios,
jt
I had heard similar things about the SMP card, though I thought that was also a 604 or 604e. I know early work on it suffered because of Motorola's problems with the 604. Ah well, the 200MHz card is plenty fast.
ESB = Extra Special Bitter (Shiner is a Texas brand of beer, still sold and advertised when I was in Houston last).
What does ABS stand for? Was this a spinoff from ATG?
What you mention about the other ROMs squares with Ellen Hancock's announcement that the ANS would be able to boot and run MacOS and NT as well as AIX *after* the ANS was released. I am actually surprised that was technically possible without modifications to both OSes (let alone the ROM) but I am very gratified to be proven wrong. Sad to hear you weren't able to get one, there has been some hobbyist interest in PowerPC NT on the Mac lately.
The serial cable should be a null modem cable, such as what you would use to connect a printer, like an Image Writer II serial cable.Yesterday was a good day. I now have my shiner up and running.
I need to wring out the serial connection. I have to parts and the only need time to
determine if I need a null modem adapter between the apple serial cable and the
db9 to USB adapter.
Zip the captured text and attach to a post.As soon as I can capture the data from the serial connection I will get the info to you.
Is there a preferred way to do this?
I'm trying to add Apple Network Server to the DingusPPC emulator. So far I can get into Open Firmware and see messages sent to the LCD.
Can someone report the output of `dump-device-tree` from Open Firmware using a serial port connection?
dump-device-tree shows only some of them. Here's a dropbox link with the required script for Open Firmware:unselect-devlspci command in Open Firmware.lspci; repeat for each PCI root device. Example:dev pci1 \ first PCI host
lspci
dev pci2 \ second PCI host for 9500 or 9600 or ANS
lspci
dev vci0 \ VCI host used by 8500 or 8600
lsvci \ use lsvci instead of lspci here for best results
lspci from pciutils.dl command. This uses a much faster method of accepting text via the serial port so text pacing can be a lot faster. It accepts up to 62KiB of text. The last character needs to be an EOF character (Control-D which is 04 in hex). When the EOF is encountered, it enters and executes the script just like step number 2 does, so proceed to step 3. Using BBEdit.app you can find the end of the file and replace with \x04 which will appear in the document window as a red upside question mark ¿, Select All, Copy, type dl in Open Firmware and press return to start the download, then Paste.0 > dl ok
0 > dev pci1 ok
0 > lspci
00:0B.0 [106B:0001] [060000] 6B10010016000000030000060820000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000C000001000000000700000000000000080000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
00:0D.0 [1002:4758] [030000] 02105847140000000300000308200000000000810000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
00006810:81000000.FF000000
00:10.0 [106B:0002] [FF0000] 6B10020016000000020000FF08200000000000F30000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
00008010:F3000000.FFFE0000
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
00008810:00000801.FFFFFF01
00008814:F3102000.FFFFFF00
00008818:F3103000.FFFFF000
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
00009010:00000C01.FFFFFF01
00009014:F3105000.FFFFFF00
00009018:F3106000.FFFFF000
ok
0 > dev pci2 ok
0 > lspci
01:0B.0 [106B:0001] [060000] 6B100100160000000300000608200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000030000002000000000B00000000000000080000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
ok
The maintenance manual is here... last two pages are part numbers.Hello fellow ANS nerds,
It is about time I finally joined Tinker Different, I am the owner of the Apple Network Server 500/132 that is the brother to Eric's, purchased from the same person and was decommissioned from the same data center. My system is currently operational (and running 24/7) with 128Mb of RAM and the base model processor, the 132MHz card. It is running AIX 4.1.5. I'm looking to do some upgrades, most notably to the storage situation. I only have a few of the boards that interface between the drive sleds and the backplane, the rest of my trays are unpopulated. Does anyone know what the connector that goes between each sled and the backplane is called, and/or where to source some? I would happily work on building replica boards if the connectors can be sourced, because drive sleds with those boards are hard to come by it seems. I have attached a couple photos of my ANS from back when I got it, so you know I'm not lying.
Thanks in advance,
Jeremiah
View attachment 24181View attachment 24182
Good to know, I'll check them out!I’ve ordered various ANS parts and sundries from https://www.xs4trade.net/index.php?cPath=1_5_23 with good experience in the past. Not sure how they are dealing with the current tariff situation.
I'm looking for the part number and manufacturer of the connector that is soldered to Apple's 922-2083 interface board, not the Apple part numbers for the boards- I don't think the connectors are listed in the maintenance manual, but I haven't had time to search the whole thing yet, so I will do some more reading. I'm looking to do things the non-Apple service way and build my own PCBs, not buy genuine replacement boards (although I probably would if some came up for sale at a reasonable price).The maintenance manual is here... last two pages are part numbers.
Good information to know, and also glad to see you here! I still have yet to install Doom on my ANS, but you can bet it is on the to do list!Nice to see you here. Apple called them mezzanine interconnect boards, or mezz boards for short (though this probably doesn't help you much).
Thanks in advance,
Jeremiah
