zbig
Hi @0dan0, thank you for uploading the Type D stock recovery image in post #143!
Unfortunately, my standard forum account doesn't have permission to download attachments without a supporter upgrade. Could you please upload the FWDV280.BIN (or zip) file to a free file host like Google Drive / Dropbox, or send it to me via DM? It would really save my D0926 scanner!
Thank you so much!
JohnCT
29
10
I must be the only one, but I run my film under the middle "roller" first, then up to the take up reel directly skipping the other two. I don't see any advantage of running it around the other two guides, and there has been zero instability in my scans. A roller conversion would be great though.
John
ioeuqr
John
I'm with you - I don't understand the circuitous path around the tight bends with old and possibly fragile film. The only thing I can figure is that the take up reel motor is a little too strong and those guide pins drag it down so it doesn't pull the film out of the gate. I'm also confused by the 3 guide pins vs. 4 guide pins that we see on the two different models.
I just published my roller conversion on Thingiverse: https://www.thingiverse.com/thing:7437080
melw
50
72
For A3026 owners - calling @thilosde @ArgieBargie @FrenchNum :
Nobody has an A3026 firmware file yet, and the type probe showed the factory firmware isn't A, B, C or D. But the bootloader on these units can run a firmware file straight from the card without flashing it. That lets you test whether Type D works on your scanner:
  1. Download the attached FW96658T.BIN - it's Type D FW 292 in test mode. It will not flash anything on the device.
  2. Put it alone on a FAT32 card. Make sure no FWDV280.BIN is on the card,.
  3. Power on. The startup screen should say "FW 292 Type D". Check whether the buttons respond, the motor runs and the picture looks normal. If the motor misbehaves, or there are any other problems, switch off the unit.
  4. Power off, remove the card, and power on again: the scanner should be back to its previous firmware and state.
Please report what you see. If everything works, your scanner runs Type D firmware fine, and you can flash FW 292 normally (the previously shared FWDV280.BIN) if you prefer to do so. If you already flashed B and your unit is dead, this tells you whether flashing D is worth trying.
From all the information posted so far A3026* units are not Type B and you should not attempt flashing Type B firmware on them.
  • FW96658T.BIN
JohnCT
29
10
Could be. Before I ran my first reel through, I figured the take up reel was pulling too hard for my liking (I've had old projectors snap tape for the same reason). I took the takup hub apart and removed one washer to reduce the drag. Just once the takeup reel stalled, but I would rather have it not pull too hard on 80 year old film.
I'll check it out!
John
