QuickDraw Speed - Fast Card Benchmarks
phipli
261
Hello folks,
I've been doing some experimenting with QuickDraw this week, trying to get NuBus video on my Centris 650 running as fast as I can, but I don't have any other fast Nubus Cards beyond my PrecisionColor to compare with.
Does anyone have...
1. Some time and enthusiasm.
2. A faster SuperMac Thunder, Radius Thunder or similar late model, high end NuBus, video card.
3. A Quadra of some description.
If so, would you be willing to run Norton System Info's video benchmark suite and share the results? Just a photo of the detailed breakdown (so that it shows the individual scores for each of the tests like text and scrolling etc).
I'm using Mac OS 7.5.3 and Norton System Info 3.2?? or so - the version that uses the Quadra 700 as a baseline. (I'll check and update this post once the huge long MacBench test I'm running finishes). Run the benchmarks at 8bit, 640x480 with appletalk off for consistency.
Make sure you include...
Computer model
CPU Clock Speed
Nubus Video card model
System version
Norton System Info version (double check that it is the same as mine, because the same computer's scores drift between versions - even when you correct for the different baseline computers).
297
306
Charlottesville, VA
As luck would have it I happened to have a Centris 650 with a SuperMac Thunder card
Computer model: Centris 650
CPU Clock Speed: 25MHz
Nubus Video card model: SuperMac Thunder /24 v2 (SuperVideo 2.7.5 Control Panel)
System version: 7.5.3
Norton System Info version: 3.2.1
Reactions: phipli
phipli
261
Absolutely perfect - thank you Fizzbinn.
So serious performance on the scrolling and Picture - those two rely on fast VRAM and blitting. CBits seems to get throttled by the speed of NuBus itself.
The graphics primitives - I suspect Norton's patterned shapes makes it more difficult depending on what exactly is accelerated. I bet a lot of these cards are very good at solid fills. Weirdly with my experiments its Lines that I'm struggling to get good performance from. I expected that to be an easy win.
Reactions: Fizzbinn
alexanderlewis
6
Lines being the weak spot isn't too surprising: many NuBus QuickDraw drivers accelerate blits and fills but leave general line primitives to the 68040, especially patterned or non-solid lines. It may be worth checking whether the SuperMac control panel exposes separate QuickDraw acceleration options, and comparing solid versus patterned lines. If solid lines are much faster, the driver is probably accelerating fills but not the general line path.
phipli
261
Anyone fancy guessing what video card this is (it was commercially available).
Host :
40MHz Centris 650
Mac OS 7.5.3
Mystery Nubus Video Card
8bit, 640x480 for tests.
I will get you PM 7100, I will get you.
phipli
261
Radius 24AC ? :)
Sadly no - hardware-wise the 24AC is a Radius PrecisionColor 24X, and in terms of QuickDraw, identical to the other 7" PrecisionColors (they generally only vary by VRAM amount and RAMDAC speed). I'd be pleased if we could get the 24AC this fast, although I haven't tried yet.
phipli
261
