Trouble Installing DaynaPort Drivers for RaSCSI
rjkucia
233
81
Madison, Wisconsin, USA
Hi all,
I'm trying to set up ethernet on my Mac SE using my RaSCSI and the instructions here: https://github.com/akuker/RASCSI/wiki/Dayna-Port-SCSI-Link
However, I'm having trouble getting the DaynaPort Drivers to work. When I try to unpack the linked .sit file, Stuffit quits immediately (tried on 3 and 4). Using the RaSCSI bootstrap hda, which has the .img file pre-unzipped, DropDisk quits immediately and Disk Copy 6.3.3 reports that the image is damaged and cannot be used (-8819). I've also found the drivers elsewhere (versions 7.7.2 and 7.5.3), which unzipped and started running fine, but they requested that I insert the installer disk, which I of course do not have. Any suggestions for what to look at next?
caver01
126
I am trying to remember what I recently did to get those installed. I am starting to think that I actually created a physical floppy because I was running into the same problems.
1,784
On the RaSCSI bootstrap v3 I made sure to make it a self moutning image as to not have these issue. check it out. Be sure to follow the instructions and only install the driver needed and not overwrite some system files with an older version.
rjkucia
233
81
Was it maybe a Shrinkwrap archive?
I seem to be having issues with the installer I found for 3.5 (crashes instead of doing anything), and 2.1 mounts the image but the system reports that it's not formatted as a Mac disk and needs to be formattd.
I'm using v3 - Double clicking on the image gives me an error: "ShrinkWrap was unable to load a component needed to mount the disk image. The Component Manager may not be available. Error #-9405"
rjkucia
233
81
Thanks! I went ahead and just set it all up in 7.5 - it's not that much slower than 7.0 or 7.1, and as far as I can tell there's not a way to mount virtual disks in System 6? But I was able to get it all going in 7.5 and I just successfully pinged Google with it, which is super exciting!
Thanks for the help everyone. Lesson here - just use 7.5 if something isn't working, lol
