BlueSCSI 1.1a Expansion Slot Bracket for SE and SE/30
PotatoFi
182
373
Hey TinkerDifferent!
I'm very excited to finally release my latest printed bracket design, which mounts the BlueSCSI 1.1a in the Expansion Slot on a Macintosh SE or SE/30!
The main goal of this bracket is to make the microSD card as easily accessible as possible, while keeping your Mac fully "enclosed" (e.g. with no obvious holes in it). The microSD card "sticks out" as much as possible while maintaining a 0.8 mm wall (which is about the thinnest that you can go with a 0.4 mm nozzle). Because of the recess of the Macintosh SE bracket in the case, it's still not super easy to get the microSD card out. I can work it out with one finger on each side, but tweezers do make it a lot easier. Reinstalling it is a snap - I have no trouble installing the microSD card with my bare hands. An ejector-style microSD slot might help this, if you're building your own BlueSCSI for this application.
Also features:
Flush fit: This printed bracket sits flush with the face of the Macintosh SE bracket for a clean look.
LED Light pipe: Very useful for troubleshooting microSD card and image issues. The light pipe uses a simple press fit. In a well-lit room, the red LED is pretty dim, but the green LED is nice and bright. I also made the lens on the light pipe the exact same size as the activity LED lens on the front of the Macintosh SE. It's all about the details!
Blink code indicators: What does 3 blinks mean?! The glyphs on the bracket tell you what you need to know.
Extra hard drive screw storage: When you remove your old failing SCSI hard drive to replace it with a BlueSCSI, you can attach the screws to this bracket. That way, when you stumble on an Asante Maccon Ethernet card, or maybe a Micron Xceed videocard (heavy breathing), you'll have the original hard drive screws waiting and ready to move your BlueSCSI to the hard drive bay.
M3 nuts slotted into the bracket! M3 nuts inside the bracket mean you can snug the M3 screws down nice and snugly. Yeah... that's not going anywhere.
Potato: It has a potato on it.
There are two ways for you to get one! If you have a 3D printer, and want to take a crack at printing your own, you can grab the files, instructions, and hardware list from Prusa Printers.
If you don't have a printer, you can buy one from my Etsy shop, and it will include all of the hardware. If it's not in stock, check back in a day or two. 100 percent of the proceeds go towards keeping the 3D printers fed, and additions to my retro Macintosh collection (I can stop whenever I want, right? Right?). But seriously - I love making stuff, and getting to connect with other vintage Macintosh enthusiasts.
Massive thanks to the BlueSCSI team for creating an affordable, reliable, performant solid-state SCSI hard disk replacement! Expect to see at least one more BlueSCSI-related part soon.
Drake
Emeritus Board Member
795
Wowee kazowee! Gadzooks!
You did a good job on this one, I'm proud of you son :)
Good potato 🥔
Reactions: PotatoFi
734
Really love this design. Is there a reason you didn't make the opening a bit larger for the microSD card?
Maybe my printer is printing a bit small. but I need to use pliers to get the SD car because it's so tight of a fit. I like the look, but it feels like the SD card opening could be twice as tall and 20% wider and it would still look great, but have more wiggle room for the SD card to be held in just by the SD card slot on the BlueSCSI.
Just some thoughts. I'll probably throw it into MeshMixer and see if I can make the opening a bit larger.
PotatoFi
182
373
Hmmm... I can't say I've run into any fitment issues with the microSD card. On my pair of Prusa MK3S printers, the microSD card doesn't touch the printed bracket during or after installation - the card is held in exclusively by the microSD slot.
Is there a specific side that the microSD card touches on, or is it all sides?
Reactions: wottle
734
It's likely an issue with my printer. My supports didn't come off cleanly and there was some left over supports on the bottom which pushed the board up as a slight angle. and there may have been some left over supports on the bottom edge of the top of the opening. So the card was rubbing against the top. I took a razor to it and removed a bit of material and it's moving freely now. Also had a hard time getting the nuts into the slots, making me think my printer may be printing things a bit undersized.
caver01
175
Hey @PotatoFi what do you think of this:
4C2F3F0C-5EF0-4265-B116-C77226C454A1.jpegB0FDF838-153A-4B15-AEBE-AFEF507BEFFF.jpegFFA6CAC0-5406-44BC-BE08-C61D30791574.jpeg0D7234AB-E1F9-4748-8934-A7D3D56486CF.jpeg
For a while now I have been playing with your designs, making adjustments for different versions etc. but I started thinking about reverse mounting. . . instead of securing it from the inside, I pushed this through from the back and the screws go in from behind!
Of course, this results in a flush-mount. My first iteration had plenty of horizontal tolerance so I tightened it up a bit. The card itself is still really hard to grab, but at least it is not recessed that extra half inch. I don’t have the light pipe installed yet.
If you are interested, I can share the STL file—I am just messing around in TinkerCAD. The main points are:
  • The face extends 13mm back from chassis expansion port screw holes (the metal box)
  • The whole thing is a mere 16mm high which clears the metal “box” around the expansion port
  • Trimmed left and right sides around the nut capture channels so it slides into the “box”
  • The existing thickness of the nut capture holes is fine mounted on the outside—as this clears the plastic back case no problem
  • There is a compromise with the bluepill jumpers—go much further out the back, and the jumpers may not clear the expansion “box”. They need to be on the inside of that.
  • The mounting screw holes/arms for the PCB have just enough depth to grip the screws
  • I needed to clip the protruding header pins (yellow header block) off the bottom of my BlueSCSI along the back edge. These are the pins that hold the microcontroller to the bluescsi board. I could have mounted them in reverse, but then they would stick up. In any case, clearance is tight under the board both to fit the bracket and not ground out on the chassis
  • I mounted the BlueSCSI to the bracket before attaching the bracket to the chassis. the outside M3 screw is tough to reach from the inside, but removing the expansion bracket itself (just the one philips screw directly below) lets you swing it up a bit
  • <edit> OH ALSO, I kept the four HDD screw holders and moved them to the side (see the four holes on the printing photo)
  • <edit> And of course, I love what you are doing with the little icons to be consistent with SCSI, ADB, Serial etc.
Thoughts?
caver01
175
Hey, @PotatoFi I am looking at your item on the Prusa site and I believe I misinterpreted the ”remix” marker at the bottom. It says ”remix culture allowed” but of course, the bullet next to those line items is an “x” which, unless you are looking at others where it is a ”✔️“ it just looked like a list. Sorry about that. I won’t post my variations, as I certainly don’t want to undercut your Etsy store or rob you of design credit. Maybe just take the above as some possible feedback for a future version?
By the way, I finally did setup the light pipe. I used something like 12 perimeters to get the filament to run parallel lines on every layer and I gotta say, it’s really bright.
PotatoFi
182
373
Heads up! There were some minor fitment issues with the original 1.0 release, so I have released version 1.1 which makes some minor fitment improvements.
  • Made the light pipe narrower to accommodate Bluepills with a vertically-installed programming header
  • Moved the light pipe slightly further from the microSD card slot to improve fitment with Bluepills with vertically-installed programming headers
  • Created a void underneath the Bluepill pins, so you don't have to trim off the Bluepill pins on the bottom of the BlueSCSI for everything to fit in the bracket
  • Increased the height of the microSD card slot
  • Removed the 1.0 models from Prusa Printers
As before, you're welcome to print your own with the files on Prusa Printers, or you can purchase brackets on my Etsy shop.
Interesting take on the design, @caver01! It's great to see other ideas. Perhaps this is something to explore in the future, as the one thing about this design is that the microSD card is buried a bit too far in there.
Also, I appreciate how you handled the license issue. Your respect to the license is very, very much appreciated. Also - nice Prusa MINI! I have two, and I love 'em!
Reactions: wottle
