An Introduction: My iMac G4 "Ichigo Daifuku"
jeffburg
Hey folks, I have been working to get my iMac G4 to a state where I could share it with everyone here, so please give me a moment to introduce いちご大福 (Ichigo Daifuku). When I was in high school, I was becoming so obsessed with Macs (mostly because of the promise of OS X). When the iMac G4 was announced I was completely amazed and I wanted one so badly. But at the time they were only 15" and I already had my big "flat glass" 19" CRT at home. And to make matters worse, these could not do dual display over VGA, only mirroring. So I ended up getting a Quicksilver G4. But I always wanted one of these iMacs and now I have one and ITS AMAZING!
I live in Tokyo and in Japan they call iMac G4's "Daifuku" Macs because they look like the Japanese dessert. My favorite variety is the strawberry kind, thus Ichigo Daifuku is her name. She is a top of the line 17" model (which I prefer over the 20" in terms of looks):
  • 1.25GHz G4
  • 2GB RAM
  • 1TB SSD
  • SuperDrive
  • Pro Speakers
  • Firewire 400
  • USB 2
  • 10/100 Ethernet
The reason I wanted the fastest version is not for the speed, but instead because these ones have USB 2.0. This means I can sync iPhones with it so I can build back a retro iTunes library. Like many, I got sucked into streaming music and video and so my ancient iTunes library has been sitting dormant on an old hard drive for a long time. So I took about 10GB of my absolute favorite music (down from the original size of 70GB) and put it on this iMac. Then I started buying used CD's for my new KPOP obsessions and imported those like it was 2003 💿. Lastly, I spent an inordinate amount of time getting old iPhone app IPAs so I could also manage them in the library and sync them with my iPhone 5.
But the iPhone 5 was tricky because Apple never allowed iPhone 5 and newer to sync with PowerPC Macs. But I found a way to reverse engineer iTunes to defeat this artificial limitation. I wrote a whole blog post on it here. Now I am finally starting to realize my goal of using an iOS6-powered iPhone as my "main" iPhone with my iPhone 13 mini as as a backup in case needed. This isn't a post about iPhones so I will leave it there... but there is a lot more to come.
What do I do with this iMac?
Well besides the above-mentioned retro iTunes setup. I also have a suite of period-correct apps such as:
  • iLife '09
  • iWork '09
  • Adobe CS3 (I actually use this as I have not had Adobe on my main Mac in ages)
  • NetNewsWire
  • MacTheRipper
  • Max Payne
  • Starcraft
  • World of Goo
  • iStat Menus
  • Xcode 3 (with iPhone OS 3.1.3 Development Enabled)
But actually one of the main things I do with it, is play Youtube in the background while I work on my main Mac. I accomplish this via FFMPEG and it's a pretty big hack, but it works surprisingly well with very high quality video output. I also wrote up how I accomplish this hack. Because of this use case, I use the iMac pretty much every day after I get home from work.
Anyway, this is getting long, in the thread I will leave photos of the full teardown. I cleaned every single surface inside and out before installing the 1TB SSD and new RAM.
jeffburg
Getting this iMac to work properly was kind of an ordeal. I even contacted Kay Koba from this forum for help. He offered me just the kind of positive vibes I needed. I ended up buying 3 junk ones in order to get 1 fully functional one that was 1.25GHz. Something about the hot Japanese summers make these thing turn super yellow... but anyway. This is always the Mac I wanted but could never have when I was in high school. But now I have it and it's amazing. Please enjoy these teardown photos.
akator
37
I'm glad to see someone else who loves their G4 iMac as much as I do. Thanks for the blog posts, that gives me something else fun to do.
Reactions: jeffburg
jeffburg
Thanks for the reply, yeah let's share the love haha. I am a little surprised because in another forum JDW mentioned that these Macs don't get enough love. And I wonder why? They're so iconic. Like such an adorable, odd-ball, design. With brilliant solutions for things like the power supply, cooling system, and screen. So anyway, I will continue posting stuff about my iMac G4 even if people are not super interested 😍
jeffburg
I really want to do this display upgrade seen in this video on one of the broken leftover iMacs, but I don't think I have the skills or the patience to painfully wire through the EDP connector 1 wire at a time like that. But those displays he showed are super nice spec wise and cheap AliExpress so I am so tempted to give it a shot.
akator
37
I think there's lots of appreciation for the G4 iMacs, but they never reached the overall popularity and recognition of the earlier G3 iMacs so have less nostalgia associated with them.
Over the years I've seen several modded/repurposed G4 iMac projects like the video you linked and all have been very impressive.
Reactions: jeffburg
Yoda
163
105
I looked around for a while to get a 17-inch G4 iMac in reasonable condition, and finally found a 1.25 model selling pretty cheaply due to a hard drive problem. It would boot, but only after a lengthy delay during which the drive would make long beeping noises.
I replaced the drive with an SSD and swapped out the optical drive for a faster Pioneer unit, which gave me my first experience of just how tightly packed-in these systems are!
The plan was to use it as my iTunes music repository and player, but it hung out on my coffee table as a distraction-free word processor for a couple of years instead. I
t's hard not to admire the design and engineering that went into it.
Reactions: akator and jeffburg
akator
37
I used my G4 iMac as an AirPlay music server for many years, streaming synced audio to speakers in every room. AppleScript and the built-in web server allowed me to control iTunes remotely and also integrate everything with my Home Assistant automation. It worked perfectly as a music server, then as a music server integrated with home automation for years.
Part of what inspired my iMac iTunes AirPlay project was how cheap AirPort Expresses were on eBay. Eventually I had 8 AirPort Expresses connected and playing synced music.
Several years ago I wanted to see how far I could push the G4 iMac and connected 4 iSight FireWire cameras (with a FireWire hub) to do time lapse. The time lapse images were combined into a video using FFMPEG. All snapshots and videos were accessible on the iMac's web server, and like iTunes was also integrated into my home automation. The iMac performed perfectly but the iSight cameras did not, each freezing at least once every 24 hours. Adding the iSight cameras and integrations seriously pushed the iMac's capabilities and CPU usage was constantly high, so between the high CPU usage and frequently failing iSight cameras I ended that project after a few months.
In the end, rising electricity prices convinced me to start using a Raspberry Pi for the same tasks. 10W for the RPi3 vs. 70-130W for the iMac running 24/7 was a noticeable difference on my electric bill (and would be even worse now).
It was a lot of fun maxing out my iMac and pushing it to the limits, especially doing things that were prohibitive 20+ years ago because of expense. It was difficult but rewarding to integrate the iMac's iTunes and cameras into Home Assistant — all of the existing methods and tools to integrate iTunes with Home Assistant were available for later Intel Macs running much later versions of Mac OS X and iTunes. It was, of course, all a bit silly because I could do all of the same things and more using a RPi running various open source projects like ForkedDAAPD (now OwnTone) and MotionEye, but doing these things on a G4 iMac running 10.4 was one of those personal nerd achievements.
EDIT: to fix copious spelling errors
Reactions: jeffburg
2,038
Funny, I never paid much attention to how people here in Japan referred to that particular iMac through the years. But I guess the reason I've never heard the Daifuku comparison is because there are just so many darned Windows users here! :) That coupled with the fact I read English language Macworld rather than MacLife Japan. Even so, when you ponder it, the machine does indeed (the body at least) look a heck of a lot more like a white, round Daifuku than a so-called iLamp or Sunflower!
Edible Ichigo (Strawberry) Daifuku is fabulous, but only when Shiro-An (white bean paste) is used, in my humble opinion
My wife who is Japanese shares that sentiment about Shiro-An being a better match for Ichigo Daifuku.
But technically, you can find Ichigo Daifuku using Kuro-An as well...
It's all about the look and taste. Kuro-an is a bit too harsh in taste and takes away from the strawberry. Shiro-an is just right and looks like a strawberry wrapped in a little snowball.
The best ones are handmade at a local Mangyu shop as opposed to something mass produced in a box, and you can often get larger a tastier ones that way too. It's seasonal and not sold all year 'round.
The actual food item is really a discussion separate from vintage Macs, but I just wanted to add my thoughts since the Japanese was used in the opening post. But in terms of my feelings on the iMac G4, I have used one of those in the past, and the arm is really the neatest thing about it. It had to be designed well because you could opt for up to a 20" LCD on the iMac G4! Naturally, the arm looks beautiful too. Sure glad the Apple of old built it rather than the Apple of 2019 who released a $999 Apple Pro "Stand." That Ichigo Daifuku Mac has an arm just as neat as the Apple Pro Stand, in my opinion, but with the entire machine at a price point that most people could afford. And that's really what made it special.
