2,184
I am currently filming a new video about the Apple IIe Card in my Color Classic Mystic. As many of you know, I performed the VGA mod on this CC earlier this year, which boost the stock resolution of 512x384 to 640x480. Smaller pixels means everything is smaller, but the upside is you can run many games and other apps which require VGA as the minimum resolution. Even so, aging eyes line mine prefer larger pixels, and I always thought it would be neat if we could switch back to the stock 512x384 on the fly.
One thing I have learned in my testing of the Apple IIe Card is that it switches the CRT screen resolution to 560x384, regardless of whether you have the stock 512x384 or the 640x480 mod! The IIe Card proves it is possible to switch resolutions without having to hack anything on the hardware side. I don't think the IIe Card has any video control circuitry on it, and instead it is just sending some kind of command to the Mac to perform the resolution switching. Would any of you know if that command is something hard coded in ROM?
I'm just trying to brainstorm about whether it is possible to use the same trick to alter the resolution to something else, such as going from 640x480 to 512x384 and back. It would be SUPER NEAT if that was possible!
Reactions: wottle
Solution
Bumping because I'm working on a color classic video myself, and I noticed that when I have my (unmodified) LC 550 board installed my CC I can set the monitor to 560x384 in the Monitors control panel. I had System 7.5.3 loaded at the time. Its slightly squished without a geometry adjustment but it does work. The original CC board still doesn't expose it under system 7.5. I have a hunch that this is because of the 520/550's LC III roots—the LC III's developer note does mention 560x384 as an available standard output mode. So if you want slightly more horizontal res and a slightly squished display, Color Classic II owners (or folks who put in a 520/550 board) can switch to the 560 mode.
Incidentally, don't insert a Macintosh TV board...
2,184
I especially want to hear from a Color Classic owner who also owns the IIe Card and who has done the high-voltage VGA mod, which changes the refresh to 67Hz. I suspect resolution switching even in that case would work fine, but that isn't something I've tested.
Now that I've done the 84V Mod, I can answer my own question.
I only did a single test with the IIe Card installed on the stock CC motherboard, and the Mac's resolution is now 640x480 with the 84V mod. But for reasons unknown, the left/right black borders are thicker than when I have the LC520 or LC575 boards installed. Meaning, I installed the 575 board initially and made my CRT adjustments so the black borders all around were between 5-6mm thick. But then when I put in the CC motherboard, those borders thicken to be like this...
And when I enter IIe mode (A2robots game), the resolution does change to 560x384, but with even thicker borders all around as shown below.
But the borders were thick even when I had the 68.4V VGA Mod and used my LC575 Board with the IIe Card...
Border thickness aside, resolution switching does indeed work when using the 84V mod.
BobDaAggie
23
I really enjoyed your video. I am currently gathering the components to also do the 84v mod. I wonder if a ROM hack would be able to give the option for the different resolutions.
kefkafloyd
26
Massachusetts
www.userlandia.com
@JDW,
That's interesting. I assumed that a CC stock board to behave the same as a Mac TV/520/550/575 board in terms of standard Mac video timing (and thus geometry) at 640x480 67Hz. But now you've got me thinking.
First, some basics:
  • The CC (and Mac TV)'s video comes from the Spice and Tinker Bell ASICs, which are evolutions of the V8 gate array from the LC / LC II. These ASICs handle video generation, and they're descendants of the RAM-Based video used in the IIci.
  • The LC III replaced V8 with Sonora, which improved its video generation capabilities considerably. The Sonora was then refined into the Ardberg used in the LC 520/550 logic board.
  • The LC, LC II, LC III, CC, LC 520, and LC 550 all use the same Ariel RAMDAC. The Mac TV's Ariel+ is largely the same.
  • The LC 575 (and LC 475 / Quadra 605) use MEMCjr and the Antelope RAMDAC to generate video. This is a revision of the djMEMC video from Q800/650/610 which itself is a reimplementation of the Direct Access Frame buffer developed for the Q700/900.
I have a Color Classic and Mac TV with original logic boards. I also have an LC 550 logic board (Color Classic II is identical). My Color Classic has not been modded for 640x480 output. So I decided to run some tests:
  • I booted both the Color Classic and Macintosh TV with their original boards as sanity tests. My machines need some geometry adjustment, but it's good enough for a baseline. The image is largely centered on both.
  • I put the Mac TV and LC 550 logic boards into the Color Classic to verify their operation on the 10 inch display (which AFAIK the operating system and sense lines treat like an Apple 12 inch RGB display for the LC machines). The geometry on all three were identical at 512x384 60Hz, as far as I could see.
  • I put the Color Classic board in the Macintosh TV and the geometry was identical to the Macintosh TV board. This makes sense, because their video generation circuitry is largely the same.
  • I put the LC 550 logic board in the Mac TV and the geometry was different! The display was shifted over to the left by a noticeable amount (about a quarter of an inch). I didn't measure the actual size of the image.
When I was doing research on Mac built-in video and RAMDAC designs recently for "How Much VRAM Does a Mac Color Classic II Have, Anyway?" I couldn't get a definitive answer on whether Sonora or Andberg's improved video generation was based on efforts done for Direct Access Framebuffer and the djMEMC. The LC III was released at the same time as the Q800/650/610, but because it uses the Ariel RAMDAC can't use resolutions greater than 832x624. The Antelope or AC/DC RAMDAC is needed for higher resolutions. Since you say the LC 550 board behaves the same as an LC 575, I'm inclined to believe that the video circuitry in Sonora/Andberg is in fact related to DABF and similar to what's in djMEMC/MEMCjr.
After going back into the Apple Developer Notes for the IIci, LC, LC III, and LC 520, I discovered something I overlooked when doing that research: the timings for the 640x480 67 Hz mode are different on the LC! The LC III and LC 520 match the IIci with the following specs:
Dot Clock: 30.24 MHz
Dot Time: 33.07 ns
Line Rate: 35.00 KHz
Line Time: 28.57 microseconds
Frame Rate: 66.67 Hz
Frame Time: 15 ms
Here's the diagrams:
IIci:
LC III:
LC 520:
However, the LC / LC II is clearly different. Although there is no Mac TV dev note and the Color Classic doesn't mention 640x480 mode, I have a hunch that their timings match LC / LC II based on what we've observed.
Dot Clock: 31.3344 MHz
Dot Time: 31.91 ns
Line Rate: 34.975 KHz
Line Time: 28.59 microseconds
Frame Rate: 66.62 Hz
Frame Time: 15.01 ms
Based on these timing diagrams the difference in geometry we're seeing when using a Color Classic or Macintosh TV logic board in a Hook chassis versus versus an LC 520/550/575 board makes perfect sense. The horizontal blanking interval on the LC / LC II / Color Classic / MacTV is longer, resulting in the image being shifted over to the right. Conversely, using a LC 520/550/575 board in an 84V modded CC will result in the image being shifted to the left.
A test I would try for sake of curiosity would be to take an AppleColor 13 inch or other monitor that's fixed at 640x480 67 Hz and do the following:
  • Hook it up to an LC III and adjust the geometry for a properly sized / positioned display.
  • Plug the monitor into a IIci. The geometry should be the same.
  • Plug the monitor into an LC 475 / Quadra 605. The geometry should be the same.
  • Plug the monitor into an LC / LC II. The geometry should change.
Now, the question is why does the LC / LC II / Color Classic / Mac TV have a longer horizontal blanking at 640 x 480 67Hz versus the rest of the Mac family? That I can't say. My hunch is that it has something to do with the Apple IIe mode when using a 640x480 monitor on an LC / LC II.
Now we're on to the next bit: the quirks of the Apple IIe card's video modes. The computers that are compatible with the card all have slightly different handling of that mode depending on what monitor (or all-in-one) is used.
LC / LC II / LC III / Color Classic / LC 475 / Quadra 605 with 12 inch RGB monitor: special 560x384 60Hz mode. Note: When the IIe card is used in the LC, LC II, and Color Classic the timing signal for this special mode is generated by the IIe card itself and transmitted over pin 31 of the PDS slot. This signal ignored in the LC III and later because the IIe video timing is generated by the Sonora/Andberg/MEMCjr ASICs.
Color Classic / CC II / LC 520 / LC 550 inside a Color Classic: special 560x384 mode (same as 12 inch RGB monitor).
LC 520/550: Apparently the Apple IIe mode on these machines is supposed to switch to an actual 560x384 60 Hz mode. I don't have a IIe card to test this. It won't take up the whole area of the display; it would be a bordered mode (similar to what JDW saw in his video). I'm wondering if this is an error, given how other headless LC machines operate with 640 x 480 67Hz monitors and Apple IIe cards, as we'll see below. But I am curious.
JDW, can you try the combination of LC520 board with Apple IIe card in your VGA modded CC and see what happens? I don't recall seeing you post it here or in the video. I'm curious if it behaves differently than your LC 575 board with Apple IIe card.
LC 575: Unlike the 520, the 575's tech note specifically declares that it uses the standard 640x480 67Hz mode but displays the 560x384 mode in the middle of the display.
LC 475 / Quadra 605 with 67Hz display: The tech notes have this to say:
When the Apple IIe Card for Macintosh is installed in the expansion slot, the computer generates an Apple IIe video display with 560 by 384 pixels. On the 12-inch color monitor, that display requires changes to the video timing, as shown in Table 2-2.
The Macintosh LC 475 and Macintosh Quadra 605 computers can provide a 560-by-384 display on any size monitor; only the 12-inch monitor requires modified timing parameters to provide the 560-pixel display width.
They're identical to the 575, except it seems like it can generate a IIe mode display on any monitor that can be attached.
LC / LC II with 640x480 67Hz display: mg.man tested this out earlier in this thread and got a 640 x 480 67 Hz display with bordered output. I would be very curious to see how this would match a...
LC III with 640 x 480 67Hz display: I bet the geometry would look slightly different in IIe mode, or the border would be slightly different. You'd still end up with a bordered 67Hz display either way. The Sonora (and presumably Andberg) ASIC does support VGA 60 Hz output, and my hunch is that the 640x480 60Hz mode seen on the LC 520/550 is actually the VGA mode with a border. That said, the real curiosity is...
LC III, LC 475, or Quadra 605 with higher resolution displays: Has anyone tried the IIe card when the resolution is set to 832x624 or higher on an LC III, LC 475, or Quadra 609? Is it just a smaller display in the middle with progressively larger borders?
The problem with enabling the hidden 560x384 mode for a Mac desktop on the Color Classic is that the geometry will be wrong when you change resolutions. It would end up squished horizontally with the standard geometry. That works for IIe mode because the IIe display has rectangular pixels! For proper square pixels you'd end up needing to adjust the H/V size to square things up and you'd end up with black borders on the top and bottom of the display.. You can't adjust the H / V size without removing the back of the case, so... That's likely why it's locked out as a selectable resolution. The technotes I've seen also say this mode is limited to 4-bit color. The Quadra 605 / LC 475 tech note says this mode can be explicitly chosen in the monitors control panel on a multisync or 12-inch RGB monitor, but I don't have one around to verify.
2,184
It would be quite nice if a simple ROM flash could switch resolutions because it's easier to pull the motherboard out for a ROM flash than it is to pull the Analog Board. But alas, resolution changing is hardwired to those silly Analog Board SENSE LINES. 😕 And very sadly, on top of that, the monitor is NOT multi-sync, which is why you are then forced to do the CRT Adjustments via the POTs at back (requiring the rear plastic housing to be removed). Meaning, you are forced to change the sense lines to switch between the stock resolution and VGA, and then you must change the CRT adjustment POTs to get the video centered and wide/tall enough.
It's a fiddly mess, to be quite honest, and I personally dislike it. And that's why most people either stick with the stock resolution or setup one of the two VGA hacks and then leave it that way forever.
My friend @Kay K.M.Mods has multiple Color Classic machines, which gives him the ability to just grab one if he wants the stock resolution or VGA via the 68.4V mod or the 84V mod. Some of his CC machines are stock, others have the 68.4V mod and others have the 84V mod. Grab the one you want and use it. Easy. But only if you have multiple CC machines. (I myself only have the one CC.)
@JDW,
...now you've got me thinking.
And a lot of thinking you did too! Wow. It's this kind of deep analysis that makes the hobby fantastically fun!
Sadly, I'm starting my work day right now and won't be able to test for at least 14 hours. But I see you want to see how the IIe Card displays on the CRT when installed in the LC520 board so as to compare with how it looks on the LC575 and stock CC boards. Understood! Will do that later. And thanks again for probing this matter so deeply!
Reactions: kefkafloyd
kefkafloyd
26
Massachusetts
www.userlandia.com
Thanks for that video!
The slight syncing differences between the CC and 520 boards (66.6 for the CC vs 66.7 for the LC 520/575) make sense due to the color classic's LC/LC II-based video. Those systems (and the CC and Mac TV which are derived from them) are specified to run at 66.62 Hz versus the 66.67 of the LC 520 and LC 575. The Color Classic (and Mac TV)'s 640x480 mode is slightly slower from a frame rate perspective than the 520/550/575. Even then, there's a possible +/- variance that I've seen documented in the various tech notes.
It does answer my big question about the LC 520 displaying Apple IIe mode at 640x480 though. Your video shows the LC 520 board outputting a bordered 640x480 67Hz mode for IIe display and not a 560x384 mode as specified in the LC 520 tech note. Which makes sense, because it would be an outlier amongst any other system that outputs IIe mode to a 640x480 67Hz. The Apple IIe mode on LC, LC II, LC III, 475, and the 14 inch all-in-ones seems consistent when using a 640x480 67 Hz monitor.
The 520 doesn't have a multisync display, and your LC 520 board IDs as a 520 inside your modified color classic. So I would expect this same behavior in a "real" 520 chassis. But I guess I'll have to be satisfied with 99% certainty until I get my own IIe card to mess around with. :LOL:
kefkafloyd
26
Massachusetts
www.userlandia.com
Incidentally, don't insert a Macintosh TV board into an unmodified color classic. While an original Color Classic logic board will work at 640x480 in a Mac TV or other Hook chassis just fine, the Mac TV board apparently doesn't connect the sense lines for 512x384 to the edge connector, and it's stuck at 640x480 inside a CC! The display is very ugly, but still readable enough to shut down (and check the monitor control panel to see if I could manually change it. I could not).
Also, to update on the timing difference between the LC II 640x480 and the LC III 640x480 timing, it turns out this is because there's a difference in how the LC systems derived their dot clocks versus the Mac II. From the 1991 Apple Macintosh Hardware Overview document:
The LC / LC II use the 31.3344 MHz CPU clock to derive the timing instead of a separate 30.24 clock. This results in the extra black pixels seen in the timing charts and why the CC board is "wrong" inside of a Hook chassis (and vice versa). Apparently the Apple Macintosh Color Display M1212 RGB monitor (I believe that's the Jersey monitor mentioned) compensates for this difference somehow.
This timing difference was abandoned with the LC III and later LC Macs. Only the LC, LC II, Color Classic, and Mac TV have the extra black pixels.
Solution
2,184
@kefkafloyd
Your first post in this thread said this:
But my CC now has the 84V VGA Mod (640x480). So although I do have an LC 520 motherboard that works, my VGA mod most likely would prevent me from seeing 560x384 as a selectable option in the Monitors Control Panel under System 7.5.5. As such, it would be nice if a fellow CC owner who also has that same LC520 motherboard but NOT the VGA mod could chime in with their own testing of the
Monitors CP to tell us what selectable resolutions they see.
Mark_W
31
27
I do have a 520 logic board installed in a cc chassis, and I can confirm you can switch resolution to 560x384 in monitor settings:
And switching to 560x384 does work, the screen shifts a bit to the left and compresses horizontally. However, the first time I tried to switch to 560x384 crashed the system and mouse pointer disappeared, I had to reboot it but second time it succeeded:
The cc analog board is unmodified but I did overclock the 520 logic board to 33mhz by moving 2 resistors on the back, and cc thinks it's a cc II. Btw here's the system info:
2,184
Stock CC resolution is 512x384, so it’s neat to see you can get 560x384 if you have an LC520 or 550 motherboard installed AND don’t have the 640x480 VGA mod setup on the Analog Board.
Thank you very much for testing and sharing that info!
QUESTION: Are the pixels still square?
You may need to do CRT adjustments to make it look right after choosing 560x384, but I assume you can open a graphics app, hold down the SHIFT key and sketch a perfectly round circle?
Reactions: Mark_W
Mark_W
31
27
Nope, without adjustment the picture is slightly compressed horizontally, vertical size remains the same. Makes sense as vertical/horizontal size is set to 512x384.
To adjust aspect ratio to 560x384 I have to shrink vertical size since horizontal size is already at its maximum, so I will end up with less screen space than 512x384. Don't think this resolution is very practical, might as well just go with VGA mod to get higher resolution with proper 4:3 aspect ratio
joevt
328
130
560x384 is meant for Apple II graphics which has non-square pixels.
Apple II graphics is 192 lines (half of 384). Double Hi-Res or 80 column mode is 560 wide (4 per NTSC color burst period). Hi-Res or 40 column mode is 280 (2 per NTSC color burst period).
The 12 inch RGB display is a fixed frequency display so it's going to display the 512 or 560 pixels in the same space and time. The horizontal resolution doesn't really matter since it's analog. It just matters that it takes about the same amount of time for both 512 and 560 width.
Reactions: Mark_W and JDW
kefkafloyd
26
Massachusetts
www.userlandia.com
Yep, this is exactly what i saw with my 550 board in my unmodified CC. Not surprising since they're the same ROM and ASICs. I didn’t suffer any crashes or issues (except for the non-rectangular pixels on the standard geometry).
incidentally, I remembered why the stock CC can't arbitrarily set that resolution like the LC III and the Ardberg/djMEMC machines—it's because the LC, LC II, and CC require the Apple IIe card to generate the timing signal for that mode and transmit it via pin B31 on the PDS slot. That's not the case with machines newer than that (Sonora, Ardberg, MEMCjr, etc) because their ASICs generate the timing signal for that mode by themselves. They don't need the IIe card. Therefore they can select it as a standard Macintosh resolution. It can use any color mode up to thousands of colors assuing you have enough VRAM installed. I had posted that earlier in the thread, but didn't put 2 and 2 together for the requirement.
On the LC / LC II and CC the dev notes call this out specifically as a 4-bit color mode when the IIe card is installed. If anyone has a IIe card installed their LC with a 12 inch RGB or a CC 1 and sets it to 4-bit color mode, is 560x384 manually selectable? If not, we can fairly say that a ROM change combined with the internal timing support likely opened up the ability to manually select the mode on the LC III and newer machines.
Yes, exactly. Given that these aren't MultiSync monitors the mode works perfectly for the intended behavior for IIe emulation.
But if someone was willing to adjust the geometry on thier built-in display (or an external 12-inch RGB), they could have slightly wider horizontal resolution (and a little more blank space at the top and bottom). I personaly wouldn't do it, but hey, whatever floats someone's boat.
Reactions: JDW and Mark_W
