Macintosh Mini - Maclock conversion project
wells
15
25
12
I noticed a trim pot on the Adafruit sound module. I think it’s a gain adjustment but I wonder if adjusting it would have any effect on the digital noise it’s picking up and amplifying.
If the gain is too high, you'll likely hear noise. If lowering the gain solves the problem (and sound is still audible) then you should be set.
I was having trouble finding the description of what the buttons are supposed to do. The left one for me chimes and resets the emu. I can’t get it to do more than that. I thought a long press or a double tap exits to command prompt. Maybe that’s the right button which does nothing for me. Are these commands editable?
Buttons are configurable, see here in the docs.
caver01
174
Perfect! Thanks!
I was finally able to get in there with a multimeter and probe my button 1 and sure enough, it was non functional. Maybe the heat from desoldering or part of the pin was left behind. . . in any case this switch was DOA so I replaced it with a traditional tactile. After flattening out the curved leads of the new switch it sits nicely on your board. I scraped back some of the solder mask to give the switch leads more to grab onto, as my switch doesn’t have any strain relief—the pins themselves are designed to grab the holes you normally solder them into.
The tac switch worked so much better than the originals that I pulled the other one off too.
Today I am taking a tiny drill and files to the back of the case to add a USB port! I am aiming for the back right corner to replace one of the existing fakes. The rectangle there is perfect.
Reactions: wells
caver01
174
Also, I WAS able to tweak the gain on the audio using the trim pot. I think for now I will be satisfied with a compromise between audible emu value and dropping the noise to a less-noticeable level.
Reactions: wells
caver01
174
Two steps forward one step back: Having constructed a working Micro-to-USB-A adapter cord that I will mount in the back, I wanted to test it first. No mouse control. No keyboard control! In fact, if I SSH into the running system and check run 'lsusb' I only get the root hub device.
However, if I opt to ingore the little floppy switch power input and run power directly into one of the USB Micro ports, the other USB port works just fine, even into the emulator. Upshot: USB is not working properly when powered from the 5V input via the USB-C/Battery input. Now, that power works fine, and in fact I can run off battery alone (no USBC plugged in) which is great. My optical mouse even gets power to the red LED imager--but the OS doesn't recognize anything. What gives? Is the image configured to ignore USB ports at low voltage? I am at a loss.
Also, I can't get a double-press <EDIT: I can, it's just hard to get the timing just right!> of button 2 to trigger an emu exit. Only the restart. My timing may be off--I see 500ms is the delay, but pretty sure I am hitting that and I only ever get restarts.
caver01
174
Ok, I made a new observation. The audio noise is coming from the use of the USB-C battery connection. I think I am going to try to bypass it. I want to keep the connector, but since this will be a desk accessory, battery power is just a novelty to show someone for a few moments. It will be powered normally. When I use a Micro USB power connection to the Pi Zero directly, the static goes away. So maybe it's not the battery necessarily, but running the power through the mini board? Who knows. In any case, I'd like to turn the gain back up and get more volume even if it means I don't get to use the battery. I am OK with that tradeoff.
caver01
174
I think you showed that in the video with a short mouse/kbd dongle attached.
I am tempted to add a second one now that I removed the battery.
Today I set it up on my desk having tweaked the image to randomize the most recognizable After Dark modules. A few people have noticed and everyone got a kick out of it.
Thanks for making the board and enabling so many features. It's a flexible platform now and a nice desk accessory and more to my liking than the well-intentioned LCD clock. I am happy!
wells
15
25
12
I've been working on a new revision of the board with the following changes:
The new design (rev 2026.09) is solderless!
  • Onboard audio: no need for a separate (bulky and expensive) audio amplifier
  • Sourced components: I found a supplier for the rotary encoder and side-mounted switches, so no more desoldering is needed.
    • It was both annoying to do, and error-prone. The switches in particular don't survive the heat of a hot iron for too long, and can either break or get mushy
  • JST connectors for power, switch, and speaker: no more cutting off the stock connectors and soldering. The board should effectively be plug-and-play
The previous design is still available on my GitHub, but I ordered the first batch of production samples today. I ordered a bunch, so if anyone is interested in buying one or two (assuming they work), I'd be open to that.
caver01
174
I have had my little macintoshMini deployed as a desk accessory After Dark gizmo for a couple weeks now and just brought it back home to do updates. I booted it back on my WiFi and connected remotely, ran the update script and let it finish and reboot. I missed the last updates, so now I have a fully working dimmer dial! Nicely done! And the rotation takes effect before any thing appears which is great too.
I did notice two things. First, there are a few command line updates to the screen before the emu kicks in. I know we are avoiding the logo using updates in cmdline.txt but I think we can tweak it even further. I haven't tried any of this yet because I brought mine mack to work again, but:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet loglevel=3 consoleblank=0 logo.nologo
That is the long cmdline.txt from my old Arcade setup which runs RetroPie on a Pi 4. It's running an aging version of raspberry Pi OS, but some fothis might still be relevant. I haven't tried these on the macintoshMini yet but what I recall is that on my arcade, some of these served to hide the TTY console at boot such that none of the auto-login text or anything else for that matter gets written to the screen.
I know I should try these first and then share, but it will be a few days before I get to it.
The second item I noticed is that when I am away from my LAN with this (configured wifi not available) Basilisk II complains about that and pops up an error that DNS is unavailable--basically that the ethernet feature will be disabled. I am running without a mouse so I cannot click OK, and when I connected a wireless mouse to USB I have no cursor. Strange. Going to restart and see if I can get past it. I must have done so before.
wells
15
25
12
Let me know how it goes! If I get a chance, I might try it myself as well. Feel free to also open a PR on the repo if you have success 🙂
Re: cursor — the script installs a transparent cursor to avoid showing two cursors on screen in Basilisk, so if Basilisk is complaining outside the emulator, you won't get a cursor. I will look into how we can fix this... thanks for reporting!
caver01
174
Ok, that worked, but it took a while. I connected a mouse and made an ever-widening spiral and click click click until I landed a click into the OK button. It worked, but I think now I remember in the initial reales that maybe the emu cursor wasn't transparent on this screen.
In the earlier release, I do remember seeing dual cursors once, but most of the time I didn't. Was that a recurring issue for anyone else? Perhaps there is a way I can enable that cursor on mine? If it could be changed on the fly, we could wait 5 minutes before making it invisible. Just a thought.
caver01
174
I was able to hide ALMOST all of the boot text updating cmdline.txt by integrating:
console=tty3 loglevel=3 quiet
There is still one line remaining that pops up for a moment right before the chime.
caver01
174
One more comment: These little tweaks are, of course, very minor quality of life improvements--overall, the board and the software config is fantastic!
I work in a photo studio and some of the post production folks are just mind blown when I show them I can launch Photoshop 1.0 on this little thing! It's amazing.
I had some trouble initially getting a disk image moved over, and now that I have one (it's running 7.5 I think) I realize it's not a great image. It's a huge Mac Pack filled with software, game folders back to 1984 etc. Some of you may be familiar with that image. Anyway, it boots, and about the only thing I love about it is that After Dark is already setup.
What I want is a stock 7.5 image or something close that boots in Basilisk II, and has all of the standard system 7 beep sounds, control panels etc. but crucially with AD so I can see my flying toasters! I assume others are trying to setup something similar. If someone has an image the love, it would be fun to collaborate!
wells
15
25
12
Shipped some fixes in 1.5.0:
Fixed​
  • No more unclickable dialog when offline. Basilisk II and SheepShaver are built without GTK, so warnings (like "Cannot get DNS address" with no Wi-Fi) go to the journal instead of a modal nobody can click. Existing installs rebuild the emulator once on update.
  • Boot text gone. The (automatic login) line and systemd status lines no longer flash before the chime.
  • Bluetooth is back. The performance option no longer disables it; installs that lost it get it back after the next reboot. Use --no-bluetooth to turn it off on purpose.
  • Brightness dial turns the right way. Clockwise brightens.
  • Night cutoff and reboots. Rebooting after the cutoff dims for ten minutes instead of coming up black.
Changed​
  • Black-and-white installer theme, after the System 7 Installer.
Reactions: caver01
wells
15
25
12
While I wait for the new revision of the board to ship from China, I made this...
With the old design, you need to hand-solder 7 jumper wires to the correct GPIO pins on the Pi, and bend/cut those leads so they don't go into the Waveshare display header on the other side.
This new interposer board plugs in between the Pi and Waveshare display, effectively 'stealing' the pins we need for the Macintosh Mini board and presenting them as a row of pin headers. So now all you need is 7 female jumper wires to connect from the Pi to the other custom PCB. No more bending or cutting leads on your Pi.
I mentioned solderless before... but with this add-on, the design will make the entire project solderless!
Yes, I might be a little crazy.
