Macintosh 128K Analog Board (120V P/N 630-0102) & Logic Board (P/N 630-01010) Capacitor List
This guide was created based on an early 1984 128K Mac analog board P/N 630-0102 with a black anode cap and Logic Board P/N 630-0101. Regardless, this guide should also apply to later revisions of the 128K, 512K and Plus. Links to Digikey and Mouser have not been included since things go out of stock quite often. Instead, use the specs below to shop for available parts and best pricing at the time of your project.
Notes​
  • Physical sizes and lead spacing are as measured with cheap calipers. They may be off by a part of a millimeter.
  • If you need the 240V version of the analog board, check out this post.
  • 33uf 25V axial is a bit cheaper than 16V, so I plan to replace all with 25V. @JDW recommends replacing with radial caps to save even more money. If C5 is replaced with a radial type, it needs to be bent out of the way of the CRT.
  • The typical C38 replacement (PME271M610MR30) was out of stock at Digikey in February 2022. I ended up ordering PME271M610MR04. I haven't been able to identify the difference yet but it worked okay for me.
Location(s)CapacitanceVoltage
High Freq.
Temp RatingPackage~Diameter (mm)~Height (mm)~Lead Spacing
Analog BoardC13.9uF (replace with film type)250105ºRadial33x16.5277.5
C24,700uF1685ºRadial1837.57.5
C3, C30220uF16
105ºRadial10.5185
C547uF1085ºAxial6.51420
C6; C1422uF5085ºAxial6.51620
C910uF16085ºRadial10165
C1133uF1685ºAxial61218
C1333uF1685ºAxial6.51318
C24; C292,200uF10105ºRadial16317.5
C25; C26; C311,000uF16105ºRadial16257.5
C35; C36100uF20085ºRadial18337.5
C380.1uF X (Replace with X2)275110ºRadial23x6.51420.3
C39; C43470uF1085ºRadial10155
Logic BoardC5; C2033uF1685ºAxial512.5N/A
C224.7uF3585ºAxial512.5N/A
This is a pre-recap photo of the reference board. It is the original board from the system with serial number F4263JNM0001.
This is a pre-recap photo of the logic board from the same system.
Author
Elemenoh
Views
856
First release
Last update
Rating
5.00 star(s) 3 ratings
More resources from Elemenoh
Latest updates
  1. Minor corrections
    Updated the description text to include the logic board part number. Changed C11 from 25V to...
Super helpful, thanks for your work !
Thanks for posting this. By the way, I have a Google Spreadsheet with all the caps here: https://docs.google.com/spreadsheets/d/132RwzC8HM5ask-BdY_31txErOCwJDSkz099GY2XLpE0/edit?usp=sharing
It shows 3 board revisions too. Note there are 3 "sheets" tabbed at the bottom.
Elemenoh
Elemenoh
Oh nice. I’ll update my list with the vendor names from my reference board and some other detail too.
Excellent content!
