PowerBook 5300c Recapping Guide
The PowerBook 5300c has three circuit boards with electrolytic capacitors. The locations and specs may vary in other models such as the 5300ce and 5300cs.
Location(s)CapacitanceVoltagePads (edge to edge)SMD Size RecommendationNotes
INVERTER BOARD
C310uF50V9.5mmC (6mm L) or
D (7.3mm L)
C92.2uF50V6.5mmB (3.5mm L)
POWER SUPPLY BOARD
C6733uF25V9.5mmC (6mm L) or
D (7.3mm L)
11x: C68, C69, C70, C73, C74, C75, C76, C77, C78, C79, C80100uF35V12.5mm6.6mm X 6.6mm - 10.3mm X 10.3mmTantalum not a typical/affordable replacement option.
MAIN LOGIC BOARD
C5533uF25V9.5mmC (6mm L) or
D (7.3mm L)
Reactions: alxlab and eric
Author
Elemenoh
Views
565
First release
Last update
Rating
5.00 star(s) 1 ratings
If you've got the long LC death chime on your 5300 unit or if your system won't turn on, this would be a wonderful resource to get your '96 world-saving PowerBook back to life.
