Emate 300 without battery pack
yomatiase
30
19
Is there a way to use the Emate 300 without battery pack, I plug it in the wall, the light shitch on but there is no other activity
splorp
148
Calgary, Alberta
splorp.com
Yes, the eMate should run without a battery pack.
A few things to check:
  1. Are you using an original Newton AC adapter? The correct voltage and current rating is important.
  2. It’s possible that the display cable has been damaged by a broken spring in the display hinge.
  3. Does the display make any odd sounds when moved?
  4. Does the display flicker at all?
  5. Does the backlight work?
yomatiase
30
19
I'm getting back to this project.
This emate is pristine.
I'm using the original AC adapter
Hinge and cable are in perfect conditions
Display doesn't make any sound when moving it.
The backlight doesn't light up
It has the two cards in the slots
I disassemble it and check voltage around the board.
The board gets electricity including various components
BUT, the pins on the board that gives voltage to the LCD has no voltage al all.
I checked visually it looks pristine. I reviewed the board as thorough as I could and couldn't find any anomalies.
I don't know what else to do...
Elemenoh
425
414
Bay Area
Did you install the little plunger back correctly? That pushes a switch to turn the screen on when it's opened. If it's not there, you'd get a symptom like you described. Check the eMate Service Source manual to see the bit I'm talking about.
yomatiase
30
19
Thanks for the answer, do you mean the Backlight wire connector?
yomatiase
30
19
I think I have a new version of this.
I have like this square thing and this switch on the board...
Elemenoh
425
414
Bay Area
No but you should be able to work backwards by measuring the hole the 'pin' goes through and the enclosure parts where it rests. Good luck!
yomatiase
30
19
Ok, no luck at all.
I replicated the piece. I even fixed the switch on the ON position.
Still only the light turns up. No sound, no sign of light out of the screen.
