Emate 300 without battery pack
yomatiase
22
19
Is there a way to use the Emate 300 without battery pack, I plug it in the wall, the light shitch on but there is no other activity
splorp
142
Calgary, Alberta
splorp.com
Yes, the eMate should run without a battery pack.
A few things to check:
  1. Are you using an original Newton AC adapter? The correct voltage and current rating is important.
  2. It’s possible that the display cable has been damaged by a broken spring in the display hinge.
  3. Does the display make any odd sounds when moved?
  4. Does the display flicker at all?
  5. Does the backlight work?
