I'm pretty sure the VRM in my Cube is toast. Has anyone had any luck obtaining a SuperVRM, or equivalent?
Cheers,
Cheers,
Yes, that button is terribly unfortunate. As much as I love to rave about the G4 Cube, that awesome looking power button tech wasn't fully fleshed out before the machine was released. Fabulous concept. Less than stellar execution.Ohhh, that may be what has been tripping me up...
Very interesting. Hmmm... I too used an mSATA SSD in an IDE adapter with one of those green boards, but it did not work.I did get my SSD install working last night James.. nothing particularly special. mSATA SSD in an IDE enclosure, and then one of those green adapter boards hanging off the back.
It's really a tragedy that the CubeOwner was never properly archived
Not to mention all the data loss at the-other-forum-which-shall-not-be-named through the years. The goal with TinkerDifferent set out to change that, with people who run this great forum being part of the vintage computer community, rather than just one person who may pass away or lose interest or lack funds to maintain it. So long as this forum remains true to its founders intentions of keeping it in control by the community, and so long as the community keeps funding it, I do hope it will remain alive and well long after I am gone. With that said, being able to mirror online content in a smart way (not like Wayback Machine was doesn't know how to properly backup forum content, perhaps in part due to some forums locking content behind memberships and passwords) is crucial to ensure longevity of the said content.Lost forums...
Hi! I recently joined the forums and saw your post. I have a post on the G4 Cube SSD replacement thread in which I was successful in installing a SSD in my G4 Cube. I hope there is some information that can help you out.I only wish I could figure out how to get an SSD to work in my two Cubes. My previous attempt wasn't too long ago, and that ended in failure.
Anyway, I'm glad to see you are giving your Cube some love, @pocketscience !
What OS are you running on it? My install is pretty clean using stock bits, but it simply won't boot into Tiger. 9.1 is perfectly fine.Hi! I recently joined the forums and saw your post. I have a post on the G4 Cube SSD replacement thread in which I was successful in installing a SSD in my G4 Cube. I hope there is some information that can help you out.
Have you reached out to vendor for some trouble shooting tips? I just got the same VRM to accommodate a 1.6 GHz CPU upgrade and an ATI 9200 video card. Also, do not rule out the PSU. I have one that is good and one that is deadI'm pretty sure the VRM in my Cube is toast. Has anyone had any luck obtaining a SuperVRM, or equivalent?
Cheers,
Curious...'evanboonie' has started an open source design of this VRM-board on GitHub: https://github.com/evanboonie/CubeVRM
Good question.Curious...
My question to "evanboonie" would be this: how powerful is "high power"? 150% related to stock?
Setting the Operating Frequency
Selection of the operating frequency is a trade-off between efficiency and component size. High frequency operation allows the use of smaller inductor and capacitor values. Operation at lower frequencies improves efficiency by reducing gate charge and transition losses, but requires larger inductance values and/or more output capacitance to maintain low output ripple voltage.
In higher voltage applications transition losses contribute more significantly to power loss, and a good balance between size and efficiency is generally achieved with a switching frequency between 300kHz and 900kHz. Lower voltage applications benefit from lower switching losses and can therefore more readily operate at higher switching frequencies up to 3MHz if desired. The switching frequency is set using the FREQ and PLLIN/SPREAD pins as shown in Table 1.
