Galena – a free board diagnosis tool for techs (Mac and Linux), *preview*
idabbleinit
Missouri
maketokeep.com
Howdy!
I have been building something for the bench and it is at a point where I want it in other techs' hands. It is called Galena and it is a tool for techs, made by a tech, and it is FREE. No account, no subscription, no catch – download it and use it.
What it is (a diagnosis tool for sick logic boards)
Galena is meant to take the guessing out of a dead board. Is it power, the clock, the ROM, RAM, a chip, or a trace that a leaky cap ate? Galena walks you through it one question at a time, tells you what to measure and where, and narrows it down until it points at the part. Every fact it shows says where it came from and how far it is trusted (Proven, Official, Likely, or Reported) so as to keep the folklore separate from what has actually been checked on a real board.
It is built around the way we already work – a meter, a logic probe, a scope, a phone camera and your ears. You do not need any special hardware to use it.
What it does right now;
- Repair – the step by step walk. Where a step wants a test, "I'll measure it myself" tells you where to probe and records what you saw, with the tool, the value and pass or fail.
- Board – every part of the board grouped by kind, what each one does, the tests that touch it, and what can stand in for it (made today, old stock, donor only, remade, reprogrammable) with sources. Drop in a photo of the board, box the parts once, and you have a map of your own board.
- Capture and Board Log – it checks your pictures are sharp enough to read before keeping them, reads the labels and chip markings (you confirm every one, nothing is taken as fact on its own), and keeps a log that follows the board: received, inspected, fault found, repair, tested, passed on. The log is chained so a changed or missing entry shows, and it prints a small QR tag and a card to send with the board. No names, ever.
- Schematic – follow a signal pin to pin. The SE/30 comes with a full netlist from an open redraw (186 parts, 526 signals). For anything else, build your own one connection at a time and export it to KiCad or a spreadsheet.
- Listen – beep codes by ear. Hold the mic to the speaker, or type what you heard, and it tells you what each BIOS maker says it means, with the source.
- Lights – POST codes and debug LEDs read from a photo of the display.
- Diode – diode-mode readings against a known-good board, pin by pin: matches, differs, or short to ground.
- Share – shows exactly what would go into a shared library, with anything personal stripped first. Nothing is sent from this version; it saves to a folder so you can look.
- Add a Board – it ships with the SE/30, IIci, Quadra 605 / LC 475 and the 7200, but it is not locked to those. Add whatever is on your bench – classic or modern, Mac, PC, Amiga, whatever.
What it plans to do;
The Galena hub is still being built and that is where this goes next. It talks to the board through the places the board already has, no soldering – a diagnostic ROM in the ROM SIMM socket for the SE/30 and the Mac II family that tests the board with no working RAM and reports back, Apple's own Test Manager through the modem port, a probe for signature analysis compared against a shared library of known-good boards, a card that watches the PDS slot, and a clip for a PC board's BIOS chip. When it ships the test steps in the walk answer themselves.
Also on the list; the shared library (so what one tech finds helps the next), more boards, Award BIOS codes, Memtest86+ logs, and logic analyser captures. The software stays free – the only things that will ever cost anything are the physical tools, and you never need them to use Galena. The details for makers who want to build their own cards for obscure systems get published with the full release, because those cards can only come from the outside, I do not have every machine and never will.
- This is a preview. It is not signed by Apple yet, so the first time you open it macOS will balk – go to System Settings › Privacy & Security and hit Open Anyway (on Sonoma, Control-click › Open works too). One time only.
- Mac: macOS 14 or later, Apple silicon or Intel. Linux: x86_64 with GTK 3 – unpack it and run ./galena, same screens, same words.
- There is a full guide (PDF) on the page that goes through every screen.
Download and guide: https://maketokeep.com/galena/
I plan a Windows version that will come with the others at release.
The point of all this is to keep these machines alive, and the techs who keep them alive need robust tools that do not cost a fortune. I would really like to hear from people who put it on a real bench – what is missing, what is wrong, what boards you want in it, anything. thoughts?
– Scott
robertseward
The confidence tiers are the part I keep coming back to. On a bench where half the dead boards I see are old stock with no history, "Reported" versus "Proven" is exactly the distinction that gets lost. My uncertainty is scope: I mostly work on vintage arcade boards, so I'd need to know whether Galena expects a specific board family before the step-by-step walk is useful. I came across Windsurf (Devin Desktop) Review (2026): Pricing, Pros & Cons while comparing tooling costs, and it made me think about how many free utilities I already juggle versus one focused diagnosis path. Does the photo mapping work on densely populated boards without a lot of overlap?
Reactions: idabbleinit
idabbleinit
Missouri
maketokeep.com
The idea, at least the one I am hoping to accomplish, is that as the data is collected the database grows and with that comes greater accuracy. As it stands now, it is limited by my personal scope of Macintosh between 1990-1996, and some older x86 things, which is the machines I have and am working on. I relied on already know sources of trusted materials as well as any official documentation.
The step by step walk was prepared from this data and my experience with the hardware. A method for others to accomplish the same is what I am working on now.
I can test by adding in some arcade board specifics as well as any repositories of useful data. If you have some places in mind I can look at I will work on that aspect right away.
The photomapping with the capture steps completely accomplished should be able to resolve quite a bit of any board. It then allows you to manually place the parts with drag boxes, and label them.
I can imagine there are loads of features still needed and the feedback and questions really help me to further wrap my head around it.
Ultimately you hit on my issue and goal - A more unified tool to the tech - One free of charges, one that you can make your own tools and accessories for to fit your niche.
idabbleinit
Missouri
maketokeep.com
So I went ahead and added some things.
What is new (arcade boards, 1970s through the 90s);
- ROM Check (is this chip good or not) – read a ROM or EPROM with your own programmer, open the file, and Galena tells you if it is a known chip. It checks the CRC32 and SHA-1 against the 150,514 chips MAME knows, system ROMs and the ROMs inside MCUs included. Type the game's MAME name and it checks against that game's chips. It also calls out the usual bench mistakes: a blank chip (all FF), nothing read (all 00), a chip read at twice its size, and a CRC that matches but a SHA-1 that does not, so as to keep a bad chip from passing as good. Nothing leaves your machine, Galena only keeps checksums, never the chip itself.
- Capture for arcade boards (the ROM labels name the game) – pick an arcade board and Capture asks for the pictures that matter on these; the maker's marks, every sticker, the ROM labels, the CPU and custom chips, the crystals and DIP switches. It reads the stickers on the ROMs and matches them to MAME's chip names, so it can tell you which game and which version the board is, how many of its chips it read, and warn you when there are chips from another set mixed in. It lays MAME's CPU and sound clocks next to the crystals it read off the board, and it recognizes the common parts by their numbers (Z80, 68000, 6809, 6502, 8080, the YM and AY sound chips and so on). You confirm every reading, nothing is taken as fact on its own – same as the Mac boards.
- Pac-Man in the library (an example arcade board) – Midway's Pac-Man ships as the first arcade board, next to the SE/30, IIci, Quadra 605 / LC 475 and the 7200. Every part with its MAME name, size and place on the board (the program ROMs at 6E to 6J, the tile and sprite ROMs, the colour and sound PROMs, the RAM, the watchdog), the 18.432 MHz crystal and the 3.072 MHz Z80, and a repair walk from +5 V at the edge down to the clock, the watchdog and the ROMs. It all comes from MAME's own source, so it is marked Likely until it has been checked on a real board, and anything not in the files is left blank, not made up – the edge pinout for one.
- Your Work (only the boards you care about) – tick Consoles › Arcade boards in Settings and the list shows the arcade boards. The plan is an example board for every kind of work as each one gets addressed, so whatever you tick, there is something there to start from.
- The guide – now 27 pages, with ROM Check and capturing an arcade board walked through step by step.
What is next (on the list);
A proper way in for the tools you already own – the open minipro software for the TL866 and T48 programmers so a read goes straight into ROM Check, MAME to check a whole board's set at once, and logic analyser captures through sigrok. Also more boards, arcade and otherwise, and the hub is still being built.
The fine print
- Still a **preview** and still not signed by Apple, so the first open needs System Settings › Privacy & Security › Open Anyway (on Sonoma, Control-click › Open). One time only.
Let me know if there is anything that is wrong. thoughts?
– Scott
