ThinkC How to detect the cursor keys press?
pfuentes69
380
290
Hello,
I need to process the KeyDown event for the cursor keys, but I can't figure out how to do it.
I managed to understand how to process key press for most keys, but not yet how to read the cursors.
For other keys I can do something like this:
        // The key is pressed while our windows are active
        theChar = theEvent->message & charCodeMask;
        switch (theChar){
            case kBackspaceChar:
                return;
            case '0':
            case '1':
            case '2':
            case '3':
            case '4':
            case '5':
            case '6':
            case '7':
            case '8':
            case '9':
                break;
            case '+':
                break;
            case '-':
                break;
            case kReturnChar:
            case kEnterChar:
                break;
            default:
                  // Nothing to do here
                return;
Any hint would be appreciated
Mu0n
573
532
Quebec
In THINK Ref Viewer, in the page named "Keyboard Compatibility" you get the following advice; the cursors first appear with the Mac Plus keyboard (they are not part of the original one).
Unless you program for System version before 4.1, you should stick with this above advice. You can use the exact notation 0x1C when you're using a short iirc. The compiler will deal with it.
The other parts of an event's message are as follows:
just use those masks as you do with charCodeMask to get to the other bits of info you need.
