Alpha is A-Okay
After spending time on Bravo's audio problems, I decided to check out Alpha's speaker problem while the subject was still fresh in my mind. Alpha was working perfectly after I restored it back in 2021, but I was using it as a known-good system for testing, and along the way, my sloppy probe work resulted in the speaker dying.To get things started, I verified the signal coming out of the Sony ICs and followed it to the bottom of the board. Everything was making sense up to the TL071B op amp at UK3. The signal was coming into pin 2, but the output from pin 6 was garbage. It was coming out a -8.8V and there was just the faintest hint of a signal. All the other pins looked normal, so it seemed something had gone amiss with the op amp.
I ordered replacements, so I installed a new TL071B--and the problem remained. Maybe I ordered the wrong part; so I scavenged one off the battery-bombed Foxtrot--and the problem remained. I was now scratching my head, because all the signals and voltages coming into the op amp were correct, but output was wrong.
I pitched the question to ChatGPT and it suggested the problem was coming downstream of pin 6, keeping it from producing good output. I followed its recommendation and removed R41 to isolate the downstream circuit, and sound came out of the speaker! The sound was a bit hissy, but it was something.
So, I reinstalled R41 (not easy given how small it is) and removed Q11 (an NPN). The probem was back. So, I reinstalled Q11 and pulled Q10 (a PNP), and the speaker was working again. So, apparently I had damaged that transistor with my probe. I had ordered new MMBT3906s from Mouser, but I remembered the issue I had with Bravo, and I supected the pin orientation did not patch the footprint on the board. Since this circuit was easier to follow, I was able to figure out that collector and base were reversed on the new MMBT3906 compared with how the board is oriented. Luckily, I was able to scavenge yet another part from Foxtrot, and with its Q10 installed, the speaker sounded great.
In the end, I replaced UK3 (twice), and I had to reinstall nearby C41 when it came off while replacing UK3. I also pulled and reinstalled R41 and Q11, then finally replaced the faulty Q10. I was distracted by the odd output coming out of UK3, but after working my way down the cirucit, I found the shorted transistor.
