Video:
Analog board has been recapped, no cracked solder joints or anything that I can see. I reflowed the joints for the flyback, and all of the connectors that go between the logic board/CRT.
Happens with multiple logic boards
If I have it on, and tap around the analog board with the rubber handle of a screwdriver, nothing seems to change at all, so I'd assume if it was a cracked solder joint or something it would have showed normal, even for a second.
Any ideas of specific spots to triple check? Any components that may go bad on the analog board that would cause this? I have an analog board I bought with a Parts Mac Plus, but the flyback transformer was cut off, so I was thinking worse case I could remove that flyback, and move the flyback from this one to the other one, but I'd like to avoid doing that if anyone has any ideas
