Personal Newton Repair Mission
Idomeneus
Hi All,
New to the forums here! Over the coming weeks, months, and possibly years, I am on a mission to dedicate a portion of my free time to get as many of my Newtons back up into working order. Here is a photo of my personal line-up:
Included are three MessagePad 2100s, an eMate, a MessagePad 120, and a MessagePad 100. All power on with a power cord, and over this past weekend I managed to get the 2100 to the lower right to work for the first time with a battery rack (it was heavily corroded and needed internal and external clean-up). But, it now can be used as a mobile unit again, without a cord!
The middle 2100 has a stripped screw, so I"m working on getting tools so that I can fix that and actually open it to clean. The 2100 to the left is missing a piece of the internal charger where batteries are inserted--likely some soldering or spot welding is needed there (TBD). And, of course, all the rechargeable battery packs need re-doing. Those will be my first efforts, so I hope y'all stay tuned and watch as I bring these Newton devices back to working life!
Very nice to meet all of you!
Idomeneus
Idomeneus
Okay, so, I decided to start with the more difficult 2100 to the left, which is missing a piece of metal that connects to one end of the battery array.
Here are the working 2100 to the right, and the faulty 2100 to the left. We're looking inside the battery casing (the container area where the battery trays or rechargeable battery packs slip into). Note the tip of my finger on the right Newton, there is a piece of metal projecting out leftward. On the left Newton, that piece has somehow broken off, and I have no idea where that piece of metal is. Thus, the left Newton has no possibility right now of being powered by batteries. Below are two close-ups of the Newton's above:
Above is the working Newton, with the full metal piece.
Above is the Newton missing the metal piece.
I'm planning on fashioning a small metal strip of nickel into a similar shaped metal piece. I will then solder it onto the existing, partial metal point shown in the photo above. Because I'll be using solder, I'll need to create a "tray" to catch any dripping solder so that it doesn't get into the battery enclosure above. I'm using a spot welder to create such a "tray" using a handful of the nickel strips I have (bought a packet of about 100 of them):
Above is the start of it. I'll cut this down to a small size and any dripping solder will hopefully fall into that, so I can easily remove it after the soldering run! More updates later!
Oh, and does anyone know the image rules for this forum? My initial image in my first post was quite large (5 MB) so I've scaled these down (hopefully) in size quite a bit. Is there a MB limit? I want to play by the rules for sure.
Idomeneus
Idomeneus
Okay, latest update--I finished off my solder-catching tray, spot-welded from the nickel strips. I used a large, old-style paper cutter to cleanly cut the strips:
And then placed the finished sheet into the opened battery enclosure. I then cut back another nickel strip and fashioned a "duplicate" battery connector:
The connector that I fashioned is shown next to an actual one (in one of the other MP2100s) above.
One thing that I realized just now is that nickel strips bend waaay too easily, although they do conduct electricity really well. I'm going to try to use the solder where the bended parts are in the connector that I fashioned to try to lock those points in place so it won't just bend to the point where it cannot make a connection anymore. If that doesn't work (consistently), then I'll need to think on it and come up with something else!
Next time will be the soldering and hopefully and end result on this repair!
Idomeneus
splorp
179
Calgary, Alberta
splorp.com
I have a bin full of spare MessagePad parts and likely have at least one of those metal pieces.
I’d be happy to send it to you for the cost of postage. (I’m located in western Canada.)
Let me take a look through the bin and see what I can find.
Idomeneus
Hi,
Yes, that is indeed the part! Although, installing the entire piece of metal might be more difficult.
If you have a couple of those (or even just one!), I'm up for paying for shipment.
Feel free to post a private message to me and we can work this out!
Idomeneus
