PowerBook 2400 Power/IO board capacitors
Elemenoh
384
374
Bay Area
The PowerBook 2400 uses tantalum caps on it's motherboard but has some atypical (for Apple) through-hole electrolytic caps on its power/IO board.
LocationCapacitanceVoltage RatingDiameterHeightTemp Rating
C39100uF10V10mm6mm105º
C48100uF10V10mm6mm105º
C47150uF6.3V10mm6mm105º
C38220uF10V10mm10.5mm105º
C46330uF6.3V10mm10.5mm105º
C2610uF30V8mm10.5mm105º
C1533uF25V10mm10.5mm105º
C2510uF30V8mm10.5mm105º
3lectr1c
629
294
the United States
www.macdat.net
Ah, those aren’t electrolytic caps. They’re Sanyo OS-CON caps which are solid polymer and won’t leak/are very unlikely to fail. Still good to have the values just in case but the chance of one of those failing is next to none.
