Reverse engineered iMac G3 tray-loading IO door + interposer (missing parts solution)
zenaror
I’ve been working on a project involving an iMac G3 tray-loading shell that I picked up incomplete (it was actually being used as a pet bed).
During the process, I found that two IO-related parts were missing:
  • the side IO door cover
  • the internal interposer bracket (the structural piece that supports the ports and door)
Since I couldn’t find replacements anywhere, I ended up recreating both parts from scratch using 3D scanning and reverse engineering.
The goal was to match original geometry and mounting points as closely as possible. After a few iterations, I was able to get proper fit and alignment with the original shell and IO layout.
A couple of notes:
  • The door includes a separate ring piece, so it can be printed in different colors (to match original aesthetics)
  • The interposer is structural, so stronger materials like PETG/ABS are recommended
  • Both parts were tested with the original mounting system
Even though this started as part of a modding project, I believe these parts could be useful for restoration as well, especially since these tray-loading units often show up with missing or broken IO doors.
If there’s interest, I can share the STL files.
jojo2k
That's pretty darn neat.
What's the story behind the rest of that iMac? Those ports don't look original! : p
