ThinkC [Study Group 1] Drawing on the Macintosh
Kabootie Computey!
15
19
www.kabootie.com
I cobbled together a first QuickDraw program this afternoon - a recreation of the virus Jeff Goldblum wrote on his Powerbook 5300 in Independence Day. So if aliens ever invade, don't worry folks, I got us covered.
A couple interesting things I learned:
  1. It was really easy to put all the text into a STR# resource and iterate over calls to GetIndString() to retrieve and display it.
  2. I needed to add a call to WaitNextEvent() into the main loop so that I could take a screenshot... otherwise the program never yielded to the OS, and the screenshot wouldn't grab an image until the program had exited.
pretzelFTW
Aha, well that fixed the bounding box issues, still seems to redraw the same pattern. My fault for copy/pasting and editing the repetitive parts. Can you blame me?
My second correction wasn't quite accurate.
Where you have the second instance of this line:
C:
gLines[i].bottom += gDeltaBottom;
…it should be:
C:
gLines[i].right += gDeltaRight;
Crutch
293
228
Chicago
Yes - or just call SystemTask(), which yields time to the system if you don’t care about getting an event (or, in an older app/pre-MultiFinder system, where you call _GetNextEvent instead _WaitNextEvent).
Reactions: Kabootie Computey!
jenna32bit
United States
Ok! I think I have it right now. This is why I treasure PRs in modern dev settings.
C:
#define kNumLines            50 // Can be higher for more linearity!
#define kMoveToFront        (WindowPtr)-1L
#define kRandomUpperLimit    32768
#define kEmptyString        "\p"
#define kEmptyTitle            kEmptyString
#define kVisible            true
#define kNoGoAway            false
#define kNilRefCon            (long)nil
/*** Globals ***/
Rect    gLines[kNumLines];
short    gDeltaTop=3;
short    gDeltaBottom=3;
short    gDeltaLeft=2;
short    gDeltaRight=6;
short    gOldMBarHeight;
/*** Functions ***/
void    ToolBoxInit(void);
void    WindowInit(void);
void    LinesInit(void);
void    MainLoop(void);
void    RandomRect(Rect *rectPtr);
short    Randomize(short range);
void    RecalcLine(short i);
void    DrawLine(short i);
/*** Main ***/
void    main(void)
    ToolBoxInit();
    WindowInit();
    LinesInit();
    MainLoop();
/*** ToolBoxInit ***/
    InitGraf(&thePort);
    InitFonts();
    InitWindows();
    InitMenus();
    TEInit();
    InitDialogs(nil);
    InitCursor();
/*** WindowInit ***/
    Rect        totalRect;
    Rect        mBarRect;
    RgnHandle    mBarRgn;
    WindowPtr    window;
    gOldMBarHeight = MBarHeight;
    MBarHeight = 0;
    window = NewWindow(nil, &(screenBits.bounds),
                       kEmptyTitle, kVisible, plainDBox, kMoveToFront,
                       kNoGoAway, kNilRefCon);
    SetRect(&mBarRect, screenBits.bounds.left,
            screenBits.bounds.top, screenBits.bounds.right,
            screenBits.bounds.top+gOldMBarHeight);
    mBarRgn = NewRgn();
    RectRgn(mBarRgn, &mBarRect);
    UnionRgn(window->visRgn, mBarRgn, window->visRgn);
    DisposeRgn(mBarRgn);
    SetPort(window);
    FillRect(&(window->portRect), black);
    PenMode(patXor);
/*** LinesInit ***/
    short i;
    HideCursor();
    GetDateTime((unsigned long *)(&randSeed));
    RandomRect(&(gLines[0]));
    DrawLine(0);
    for (i=1; i<kNumLines; i++)
        gLines[i] = gLines[i-1];
        RecalcLine(i);
        DrawLine(i);
/*** MainLoop ***/
void    MainLoop(void)
    short    i;
    while (!Button())
        DrawLine(kNumLines - 1);
        for (i=kNumLines-1; i>0; i--)
        RecalcLine(0);
        DrawLine(0);
    MBarHeight = gOldMBarHeight;
/*** RandomRect ***/
    WindowPtr    window;
    window = FrontWindow();
    rectPtr->left    = Randomize(window->portRect.right - window->portRect.left);
    rectPtr->right    = Randomize(window->portRect.right - window->portRect.left);
    rectPtr->top    = Randomize(window->portRect.bottom - window->portRect.top);
    rectPtr->bottom    = Randomize(window->portRect.bottom - window->portRect.top);
/*** Randomize ***/
    long randomNumber;
    randomNumber = Random();
    if (randomNumber<0)
        randomNumber *= -1;
    return((randomNumber * range)/kRandomUpperLimit);
/*** RecalcLine ***/
    WindowPtr    window;
    gLines[i].top += gDeltaTop;
    if ((gLines[i].top < window->portRect.top) ||
        (gLines[i].top > window->portRect.bottom))
        gDeltaTop *= -1;
        gLines[i].top += 2*gDeltaTop;
    if ((gLines[i].bottom < window->portRect.top) ||
        (gLines[i].bottom > window->portRect.bottom))
        gDeltaBottom *= -1;
        gLines[i].bottom += 2*gDeltaBottom;
    gLines[i].left += gDeltaLeft;
    if ((gLines[i].left < window->portRect.left) ||
        (gLines[i].left > window->portRect.right))
        gDeltaLeft *= -1;
        gLines[i].left += 2*gDeltaLeft;
    if ((gLines[i].right < window->portRect.left) ||
        (gLines[i].right > window->portRect.right))
        gDeltaRight *= -1;
        gLines[i].right += 2*gDeltaRight;
/*** DrawLine ***/
    MoveTo(gLines[i].left, gLines[i].top);
    LineTo(gLines[i].right, gLines[i].bottom);
Kabootie Computey!
15
19
www.kabootie.com
Interestingly, SystemTask() doesn't allow me to take screenshots. It looks like it yields the CPU to desk accessories, but not to whatever routine does screen captures, possibly? With WaitNextEvent() I can specify that I'm yielding for 1 tick per cycle and give it a nil pointer, and everything seems to work. But am I doing something really non-idiomatic here?
C:
while ( !Button() ) {
     WaitNextEvent( everyEvent, nil, 1, nil );
ExitToShell();
Crutch
293
228
Chicago
Huh, I probably stand corrected, I thought SystemTask checked for an FKEY press (for a screenshot) but looks like you need GetNextEvent or WaitNextEvent for that. Thanks for making me check myself.
Your snip is totally fine except I think you should really pass a pointer to an EventRecord in your second argument there, even if you don’t care what gets stuck in it. WaitNextEvent isn’t meant to get a NULL EventRecord pointer.
Kabootie Computey!
15
19
www.kabootie.com
Thanks for the tip. In fact, I was seeing some erratic behavior in my Toxecret program that went away when I put an EventRecord pointer back in, so yay! While I was in there, I also incorporated your tip about calculating the line height for the text from post #26, instead of hard-coding it.
KennyPowers
359
396
I'm caught up through chapter 3 and did all of the example programs. Then I threw together a simple animated bouncing ball thing. It uses TickCount() for frame-rate independent animation (ball moves the same speed regardless of how fast or slow your mac is...will just be less smooth if the system can't keep up). I also figured out how to draw to an off-screen buffer and then copy it to the window for flicker-free animation. A (horribly compressed) gif of it running on my IIci:
pfuentes69
382
299
I'm caught up through chapter 3 and did all of the example programs. Then I threw together a simple animated bouncing ball thing. It uses TickCount() for frame-rate independent animation (ball moves the same speed regardless of how fast or slow your mac is...will just be less smooth if the system can't keep up). I also figured out how to draw to an off-screen buffer and then copy it to the window for flicker-free animation. A (horribly compressed) gif:
This is very cool.
Would you share the code?
I’m specially interested on the off-screen drawing.
JonThysell
Pacific Northwest
jonthysell.com
KennyPowers
359
396
This is very cool.
Sure...code is attached. I've only compiled it with ThinkC 6 on System 7.1. Be sure to link in the MacTraps library. I don't think this code will work on System 6 either (I think System 7 is needed for offscreen graphics worlds). Chapter 6 in this document was helpful, though I don't claim to entirely know what I'm doing (probably don't need to lock/unlock the offscreen buffer every frame for example) :) Also, the ball's collision detection with the edges of the window is somewhat naive. When a collision is detected, it just backs the ball up to its previous position to prevent the ball getting stuck on the window edge. The "correct" way to do it would probably be to back the ball up along its previous movement vector to the precise point where it collided with the window edge. However, the naive way looks good enough for what was really an exercise in offscreen drawing.
C:
#include <QDOffscreen.h>
#define kBaseResID 128
#define kBallRadius 20
#define kInitialBallXPosition 100
#define kInitialBallYPosition 100
#define kBallXVelocity 2
#define kBallYVelocity 2
#define kBallColor redColor
typedef struct Vec2
    float x;
    float y;
} Vec2;
typedef struct Ball
    Vec2 position;
    Vec2 velocity;
    float radius;
} Ball;
// Function prototypes
void ToolBoxInit();
WindowPtr WindowInit();
GWorldPtr OffscreenGraphicsInit(WindowPtr window);
short round(float number);
void MainLoop(WindowPtr window, GWorldPtr offscreenGraphicsWorld);
void DoBallPhysics(Ball* ball, float deltaTicks, WindowPtr window, Rect* ballRect);
void StepBallPhysics(Ball* ball, float deltaTime, Rect* ballRect);
void DrawBall(Rect* ballRect, Rect* rectToClear, GWorldPtr offscreenGraphicsWorld);
void main()
    WindowPtr window;
    GWorldPtr offscreenGraphicsWorld;
    ToolBoxInit();
    window = WindowInit();
    offscreenGraphicsWorld = OffscreenGraphicsInit(window);
    MainLoop(window, offscreenGraphicsWorld);
void ToolBoxInit()
    InitGraf(&thePort);
    InitFonts();
    InitWindows();
    InitMenus();
    TEInit();
    InitDialogs(nil);
    InitCursor();
    WindowPtr window = GetNewWindow(kBaseResID, nil, kMoveToFront);
    if(window == nil) // Couldn't load the WIND resource
        SysBeep(10);
        ExitToShell();
    ShowWindow(window);
    SetPort(window);
    return window;
    QDErr error = NewGWorld(&offscreenGraphicsWorld, 0, &(window->portRect), nil, nil, 0);
    if(error != noErr || offscreenGraphicsWorld == nil) // Couldn't create offscreen graphics world
        SysBeep(10);
        ExitToShell();
    return offscreenGraphicsWorld;
    return number < 0 ? (short)(number - 0.5f) : (short)(number + 0.5f);
    Ball ball =
        { kInitialBallXPosition, kInitialBallYPosition },
        { kBallXVelocity, kBallYVelocity },
        kBallRadius
    Rect ballRect;
    Rect previousBallRect = window->portRect;
    long lastLoopTicks = TickCount();
    while(!Button())
        long currentLoopTicks = TickCount();
        float deltaTicks = currentLoopTicks - lastLoopTicks;
        lastLoopTicks = currentLoopTicks;
        DoBallPhysics(&ball, deltaTicks, window, &ballRect);
        DrawBall(&ballRect, &previousBallRect, offscreenGraphicsWorld);
        previousBallRect = ballRect;
    Vec2 initialBallPosition = ball->position;
    float deltaTime = deltaTicks * 0.5f;
    StepBallPhysics(ball, deltaTime, ballRect);
    if(ballRect->left < window->portRect.left || ballRect->right > window->portRect.right)
        ball->velocity.x = -ball->velocity.x;
        ball->position.x = initialBallPosition.x;
        ball->position.y = initialBallPosition.y;
    if(ballRect->top < window->portRect.top || ballRect->bottom > window->portRect.bottom)
        ball->velocity.y = -ball->velocity.y;
    ball->position.x += ball->velocity.x * deltaTime;
    ball->position.y += ball->velocity.y * deltaTime;
    ballRect->top = round(ball->position.y - ball->radius);
    ballRect->left = round(ball->position.x - ball->radius);
    ballRect->bottom = round(ball->position.y + ball->radius);
    ballRect->right = round(ball->position.x + ball->radius);
    GWorldPtr onscreenGraphicsWorld;
    GDHandle onscreenDevice;
    PixMapHandle graphicsWorldPixelMap;
    GetGWorld(&onscreenGraphicsWorld, &onscreenDevice);
    SetGWorld(offscreenGraphicsWorld, nil);
    graphicsWorldPixelMap = GetGWorldPixMap(offscreenGraphicsWorld);
    if(!LockPixels(graphicsWorldPixelMap)) // Graphics world buffer has been purged
        SysBeep(10);
        ExitToShell();
    ForeColor(blackColor);
    PaintRect(rectToClear); // Just clear the ball's Rect from the previous frame instead of the whole port
    ForeColor(kBallColor);
    PaintOval(ballRect);
    SetGWorld(onscreenGraphicsWorld, onscreenDevice);
    CopyBits(&(((GrafPtr)offscreenGraphicsWorld)->portBits), &(((GrafPtr)onscreenGraphicsWorld)->portBits), &(offscreenGraphicsWorld->portRect), &(onscreenGraphicsWorld->portRect), srcCopy, nil);
    if(QDError() != noErr) // Probably means insufficient memory
        SysBeep(10);
        ExitToShell();
    UnlockPixels(graphicsWorldPixelMap);
Reactions: pfuentes69
Crutch
293
228
Chicago
I am not sure but actually think NewGWorld etc. was added in (maybe certain versions of?) System 6. I’d love to find out.
Edit: I mean of course I could just try it with every system version. But that’s tiresome ….
pfuentes69
382
299
This is great. Thanks to all.
I think my development already has other dependencies with System 7, so it would be fine if this is also another one. I'll try to work on this in the weekend and see how it goes.
My main interest is to be able to calculate the screen contents and store it, so I don't need to recalculate for each redraw if the content didn't change.
JonThysell
Pacific Northwest
jonthysell.com
AFAIK the GWorld stuff was only added in System 7, which is why I did the backing bitmap approach so I could support System 6.
And I got the idea from looking at the Glypha source here: https://github.com/softdorothy/Glypha3. Specficially the CreateOffscreenBitMap() method here: https://raw.githubusercontent.com/softdorothy/Glypha3/master/Source/Utilities.c
Reactions: papakatsu
pfuentes69
382
299
Hello,
I tried your code... I had an error with FillRect(&(window->portRect), black); , which I changed to PaintRect().
I could build in Symantec C++ 7, as is the environment I'm using in my project. In this case I can build, but the window doesn't show (I use System 7.5.5)
Then I tried in TC 6, and I got a build error claiming that "thePort" (as in InitGraf(&thePort)) is undefined... I'm just starting with the ToolBox, so need to figure out what else I'm missing...
pfuentes69
382
299
Hello,
Never mind... I was forgetting to create the resource file. Your code runs on Symantec C++ 7 and System 7.5.5 with no issue.
But in TC6 I still get the build error (undefined: thePort).
Crutch
293
228
Chicago
Just checked this in the 2nd edition of Knaster’s Macintosh Programming Secrets and he confirmed my suspicions.
You could use _NewGWorld etc. under System 6 (maybe even earlier), you just needed the 32-bit “Color QuickDraw” INIT in your System Folder.
System 7 just made these routines built-in. But they were available earlier (and indeed originally made available only) with the INIT installed.
