Synchr030/S 256MB SDRAM Accelerator for the SE/30
MeTheMac
70
15
Mars
Good to know. Please let me know if there is any important information, but as soon as my Syncro030/S is shipped out and arrives to me and I will try it out!
zigzagjoe
19
30
I already had a sidebar going with this user predating this thread, but I will lay it out here in more detail. This is uncharted territory, I do not have a Synchr030 to test with and only performed some testing with the booster while I had one on loan. I don't recall if I tried Synchr030 with a 30Video card or any other combination thereof.
There's a few other things to unpack here, so I'll clarify in no particular order.
In general, any more than 1 card in a SE/30 (whether it's located in PDS or CPU socket) is not a guaranteed to work scenario. Most combinations of two cards are fine, but 3 card configurations are a wildcard. The only 3 card configuration I'll say definitely works is Bolle Riser + Carrera/Powercache/Turbo040 + 30Video (any model).
There are a few requirements of any card with a passthrough slot in order to improve compatibility with additional cards and accelerators. One of those is buffering of the system clock for downstream cards as the SE/30 system clock is weak to begin with and with multiple cards it degrades badly. I do this on all of my boards with passthrough slots that use the system clock signal.
Booster configurations: Accelerators should be located as close to the logic board as possible. In this case that's definitely the preferred option here as that arrangement will allow the booster to buffer the clock for the Synchro and any other cards downstream. I don't believe that clock buffering is done on the Synchr030, so that's part of the reason I think that strong pull up resistor on the clock can allow the booster on top configuration to work. From what I found all clocks were stable on my board and had the expected phase relationships, so the exact mechanism of action with the resistor is unclear here (however I don't know what requirements/tolerances the Synchr030 has).
My stance on the clock pull up: If the resistor works for you, great, it's probably fine but it's not something I "bless" as a supported way to make that configuration always work especially as why it helps is not known.
30Video cards are not clones, they are a scratch designed board and driver I created last year. The HC and SI cards do not depend on or use the system clock and should be immune from any issues with it. The GS card does use the system clock, if no other clock in the system buffers the clock signal the GS card should be first in the stack to allow it to do so. Anything but that is an untested/non-recommended configuration. Not to say it can't work, but if any issues occur/system instability (well, beyond the usual for Mac OS) that's a possible root cause.
The 30Video cards are very compatible (I've never run into a scenario where they don't co-exist with another board of any type) so I would not expect an issue with Synchr030 itself, keeping in mind the 1-card-per-system intended spec for these systems. The 30Video cards are all fairly closely related so where one works, I would expect the other models to also work. I am aware that it's been tested with the Synchr030 at least a couple of times in the GS version as seen above. I don't know if anyone is running a finished setup with a Synchr30+30Video though.
Reactions: YMK and JDW
MeTheMac
70
15
Mars
Yes, I forgot to mention that I had talked to you. I'm so sorry about that!
Thanks for the in-detail explanation, that is very good to know. I will let everyone know if it works and if not, what issues I am having. Thank you so much to everyone who is contributing over here, I can't stress enough how cool this forum is!
1,918
@YMK does the Synchr030/S work with Optima under System 6?
I never tested Optima, so I have no idea.
I searched the Synchr030/S documentation, but there is no mention of even System 6 or 24-bit addressing.
I searched through past emails between myself and YMK (because there are so many), and I couldn't find "Optima" as a keyword. I then searched for 24-bit addressing in our email dialog and found one email from January 2025 saying:
The only worthwhile reason to use the [Synchr030/S] extension in 24-bit mode is acceleration with the stock CPU and the Booster (and hopefully soon, the P33 [PowerCache accelerator]). Since memory is capped at 8MB, the 256MB expansion is unusable anyway. Therefore, there's no reason to load the extension if it causes a performance decrease by giving up the L2 cache.
Of course, the above statement did not take into consideration Optima's tricks of implementing 32-bit addressing (and therefore, access to more than 8MB of RAM) under System 6. So it boils down to the question of whether the Synchr030/S Extension is compatible with the Optima INITs, and again, I don't know that because I never tested it.
What I CAN say is that you get 128MB of RAM when the Extension is NOT loaded (not the full 256MB), which is the case running System 6 normally, without Optima installed. You are simply limited to 8MB of usable RAM (with 24-bit addressing), with the remaining 120MB being reserved for you to use as a RAM disk.
Reactions: YMK
HardwareHacker
Massachusetts, USA
You'll need a custom ROM like the Rominator II or similar to make the machine 32-bit clean
Reactions: YMK
HardwareHacker
Massachusetts, USA
Reactions: YMK
1,918
The Synchr030/S documentation mentions a non-stock ROM as being very important, and in my video I stated it as being pretty much a requirement...
"Required"? Really?
Well yes, and for more reasons than just to become 32-bit clean. Because unless you want to sit through RAM checking for 384MB (it would check 128MB, then the Extension would load, trigger a reboot, and then it would check the full 256MB), a non-stock ROM is essential to practical use of Synchr030/S. That's because non-stock ROMs kill the infuriatingly slow RAM checks at cold boot. Honestly, I wish Apple had never implemented that checking. It's so incredibly bothersome!
The good news is there are many ROM SIMMs to choose from, as I mention here.
Also note that simply having a ROM-inator II (or similar) to make your machine 32-bit clean doesn't magically make System 6 32-bit clean. System 6 (without Optima) is 24-bit only, regardless of your ROM SIMM. Optima promises to change that, but I've read about many software incompatibilities. So even if Synchr030/S is found to be compatible with Optima, one would need to contend with those incompatibilities.
YMK
406
339
"Required"? Really?
Agreed. The RAM check would have been better triggered by a certain startup key if RAM is suspect.
Enabling the full 256MB depends on certain code being present in a IIsi derived ROM, not just for the practical reason of skipping RAM tests. In other words, you will not get 256MB with the stock ROM.
YMK
406
339
@ElBaroni I tried out the 128MB version of Optima in 32-bit mode, with and without the Synchr030/S and the result is the same:
I get a dialog on startup that says "Finder is older version" and a forced restart.
This is with System 6.0.8 and Finder 6.1.8.
The good news is that with the Synchr030/S extension in 24-bit mode, it boots fine with the ACCEL LED illuminated.
If you have any ideas, I'm happy to try them.
1,918
The Optima page on Macintosh Garden has only a single download. No PDF manual is offered, sadly. But I downloaded and Unstuffed the file and found there are two versions, each with their own README files:
The README for Optima 32 v2.0 says this...
OPTIMA normally requires System 6.0.7, and only functions as a RAM disk under System 7. On the IIci only, it can be made to work with Systems 6.0.4-6.0.7. Foreign Systems (including Kanji) can run with 6.0.6 and 6.0.7, but 6.0.7 is recommended.
No mention of 6.0.8 :(
The README for Optima 128 v1.0.1 says this...
It also requires System 6.0.4 or later...
OPTIMA is now compatible with many more foreign file systems. It has been tested and is compatible with German 6.0.5 & 6.0.7, Italien 6.0.5 & 6.0.7, Swiss 6.0.5 & 6.0.7, French 6.0.5 & 6.0.7 and Kanji 6.0.5 & 6.0.7 Systems. Others are supported as well.
Again, no mention of System 6.0.8. :(
I then used ChatGPT "Deep Research" to spare me an hour of manual Googling, in hopes of locating the full Optima manual or otherwise get confirmation from multiple sources about OS compatibility, as it pertains to System 6. Deep Research checked 53 info sources (such as Macintosh Garden, Macintosh Repository, the 68kMLA, TinkerDifferent, BMOW, LEM, MacGUI, Wayback Machine, vintageapple, Reddit, Emaculation, Macworld, various Japanese, Korea, Portugese & Spanish sites) with 142 searches. In summary, it said basically what the README told me: compatibility up through 6.0.7.
However, Deep Research also found the following info about a ResEdit HACK on the BMOW site in the comments section...
SOURCE PAGE
Reactions: YMK
YMK
406
339
Thanks @JDW for this info. Apparently Connectix had very dumb version detection that didn't expect newer Finders and flagged 6.1.8 as "older version".
After using ResEdit to change all references of 6.1.8 in the Finder's vers resource to 6.1.7, it boots:
Synchr030/S is running at full speed here; two cycle reads and writes with both ACCEL and /ECS LEDs illuminated.
Thanks again to @JDW for figuring this out!
1,918
I'm truly thrilled to hear that ResEdit hack on the Finder worked! And I apologize I myself haven't found time to test it yet.
Fabulous to see 256MB fully accessible under System 6.0.8 (hacked Finder) with full acceleration too!
And just so everyone reading this is aware, Optima did have some software conflicts, or so I have read. But so long as you don't use software that triggers those issues, Optima sounds like a fabulous overall solution, especially because System 6 really allows you to FEEL THE SPEED of your SE/30 (versus System 7).
Thank you, @YMK for testing, hacking and confirmation!
Reactions: YMK
ElBaroni
15
Canberra, Australia
Thanks for checking it out, both. That’s amazing work by Connectix. Imagine being able to rewrite a memory manager but not use >= in version checking…
Of course, the absence of multifinder in 32-bit mode makes high ram in system 6 fairly redundant, but it’s nice to have these unnecessary options!
