68kandcoffee
Hmm well the ROM is only 32 kB, of which only like 22 kB is used (i.e. not part of a big string of 0xFF bytes). So not too much but more than the minimum 1-2 kB required to boot a 68000 and do something useful. I haven't disassembled it though. Maybe later I'll put it into IDA and see what it does.
Hi there! I have a SE 8MH and am looking forward to this project with GREAT interest.
2,230
@Zane Kaminski
Your official posts in this thread have have been silent for the last 4 months, so I do hope there are still plans in the works to make the fabulous accelerator happen.
To continue what I had said before about distorted sound, I was Googling SE accelerators yesterday and found that the Total Systems (Mobius) Gemini Ultra and the Novy Quik30 68030 accelerators (about the fastest cards made for the Mac SE) could use the same control panel driver, which interestingly enough fixed distorted sound on both. Scroll to the very bottom of this web page to see the software and description:
https://vintageapple.org/macdrivers/accel.shtml
While I fully understand yours is not based on the 030, the fact those two accelerators were cured of the audio glitch problem with a software solution implies that your forthcoming accelerator might be able to achieve the same. This is an important consideration in light of how significant "good audio" is in the vintage computing experience. Most people play games on old computers, rather than do modern day Photoshop or web design work, making good audio as important as the accelerator itself.
Anyway, I hope all is well at Garrett's Workshop!
Bolle
99
At least that's what it says there. I do have both, the Quik30 as well as the Gemini Ultra (branded Extreme Systems) and they both do have sound issues when used with Gemstart - it's just not as bad as with other drivers but it's still there.
What's interesting is that with less crackles and pops in the audio comes worse video performance. Without diving into it any deeper it looks like the software is holding things back to be able to accurately fill the sound buffer when needed and deprioritizes other things.
Reactions: Ubik
Yeah. Back then, communication between organizations and people was not as instant as today. Sometimes an update was released for one thing, and another update or another that missed each other. Programmers were writing code in software to try to compensate for that sound issue under acceleration. Then when the accelerator code was updated to fix the sound issue, the other software had not updated,d so things may have gotten out of sync.
Acceleration was for the benefit of some things, not everything. It was too fast for some games but suitable for spreadsheets and word processing.
Ubik
64
82
Orange County, CA
Great discussion on the sound issue. Despite the distorted sound I still really enjoy my SuperMac SpeedCard on my SE and would love to see the WarpSE come out, even if the sound issue is still in progress.
I'd hate to see solving the sound issue become a block to getting the board out. No doubt the sound issue could eventually be improved by firmware/software.
Reactions: Cam
BFEXTU
190
161
@JDW re SpeedCard - I have been super busy for the past couple of months. I will still look at what we discussed. Otherwise, I have been trying to find a SpeedCard, but no luck If someone has one they would like to get rid of/sell, let me know.
2,230
Both. Wow! The 50MHz Gemini Ultra is THE fastest SE edition accelerator I can find, since no 040 accelerators were available for it. But are you saying that when using the newest drive, video is slower than stock when the accelerator is running, or are you saying that the video isn't accelerated as much? If the video is slower than the stock video with the accelerator running, that obviously would be about as bad as distorted sound.
I find it interesting that so many SE accelerators have audio issues, versus SE/30 accelerators which don't (except for the Carrera040 when running in 040 mode). My DiiMO, Daystar socketed PowerCache, and Turbo040 all run without distorted audio.
Despite the distorted sound I still really enjoy my SuperMac SpeedCard on my SE...
I like my SpeedCard only when I am not running games. When you run games, you have audio. And when you have audio, you get distorted sound which ruins the experience. Of course, you can do the programmer's switch at cold boot trick to kill the acceleration to eliminate the problem. But that is annoying because I don't need to do that with my SE/30 accelerators so I can enjoy the benefit of clean audio and fast loading times on that machine.
Do you think you could resolve the audio problems in software if you had a SpeedCard?
BFEXTU
190
161
@JDW It might be possible. I will try to shift a little time in that direction. I also need to wrap up my Mac II FPU testing. I will also try out my ProdigySE board. My 68K workspace is in video board chaos at the moment and I also have to get my drive storage sorted out.
Reactions: JDW and retr01
Bolle
99
I think a 50MHz PowerCache will be faster due to the cache that most of the other fast SE accelerators lack.
The PowerCache adapter for the SE also comes with RAM which is hanging on to a fast 33MHz bus on the adapter itself.
I think the PowerCache when used in an SE benchmarks faster than when it's running in an SE/30 because of the faster RAM.
That beast of an adapter is probably rarer than any of the other accelerators on their own.
2,230
The reason I didn't highlight the "PowerCache" in yellow in the chart I posted earlier was because it doesn't include the "SE" in the compatibility list...
I have the SE/30 edition, which is a socketed accelerator board, but of course the SE has a 68000 which is a different shape.
There were of course the P33 cards for the IIci and IIsi...
And even the rare one for the Macintosh II...
But I am not aware of PowerCache cards that work in the SE. Does an "SE" (not SE/30) edition "PowerCache" really exist?
2,230
Holy cow, @Bolle ! That's the first I've ever seen of that SE-compatible PowerCache. That's the most unique vintage Mac accelerator I've ever seen! Super rare, to be sure!
QUESTION: My SE/30 edition socketed PowerCache has no issues with audio. Does your SE edition PowerCache have issues, or is audio perfect?
2,230
@jasa1063
Based on the previous reply below, I think we just need to wait until the end of February, because... well... @Zane Kaminski did say "sooner than [March 2023]" after all! :)
I should also mention that being able to have acceleration without distorted sound is important for the experience. Toward that end, @Bolle has resolved the audio glitching issue on his Carrera040 clone by way of an updated Control Panel. That gives me a tiny bit of hope that perhaps something could be done on Zane's forthcoming accelerator to better ensure audio works as it should.
Anyway, hoping all is well at Garrett's Workshop!
Lovemyclassicmacs
I’m looking forward to getting my hands in one of these cool cards once they are out. Well done guys working through the process and double checking things do work.
