Hmmm....I have a dual FDHD SE. Even if I swap out to an 800k for one of the drive bays, I still can't do 400K, eh? Go WarpSE!
Based on my previous dialog with Zane in this thread, when you have a WarpSE installed, it doesn't matter if your SE motherboard features an older IWM or newer SWIM chip because WarpSE comes with the SWIM flashed. With WarpSE, if you want the IWM (while keeping the WarpSE active), you just flash WarpSE using a vintage MacOS app. It's basically the same sort of app you use to flash the original ROM-inator), and you then have the older IWM which lets you have 400K and 800K drive compatibility (no 1.44MB drive compatibility). Again, this is the discussion I had with Zane earlier in this thread.Hmm⦠if the SWIM werenāt required separately - maybe? With the SWIM I feel like youāre talking $50-60+, plus the cost of a SuperDrive. Generally speaking, I feel like youāre going to have two camps:
1. Folks that are generally content with the machine as-shipped (or prefer the original configuration for historical accuracy; these folks probably have both an original SE and an FDHD)
2. Folks that want to max everything out, and who will jump at the WarpSE (including the FDHD ROM), and will supply their own SWIM and SuperDrive (or have an FDHD that theyāre upgrading with the WarpSE).
Iām not sure there are many folks in between, that effectively want to convert their original SE to an FDHD. At least, I could see myself in either #1 or #2, but Iām pretty sure I wouldnāt upgrade my 800k to be an FDHD - Iād either add a WarpSE and live with 800k floppies, or Iād pick up an FDHD and upgrade one (or both) of my SEs with WarpSEs.
No! I just wanna be clear that this isnāt true. The SWIM isn't something you can flash or store somewhere to enable 1.44M floppy support. The WarpSE will have the FDHD ROM but not the SWIM chip. It's not something that can be added to the Mac without connecting to the floppy drive. So you will have to supply your own SWIM chip if you want to use 1.44M floppies.Based on my previous dialog with Zane in this thread, when you have a WarpSE installed, it doesn't matter if your SE motherboard features an older IWM or newer SWIM chip because WarpSE comes with the SWIM flashed.
Yeah. Now if someone could come up with the Verilog code or logic schematic of a SWIM chip, we could just integrate that on the WarpSE and put our own 20-pin floppy connectors. Big Mess O' Wires has his Yellowstone disk controller for the Apple II but I think it's only an IWM, not a SWIM. I'm not aware of any other IWM/SWIM implementations so we're outta luck.Okay, the I/O would be handled by the logic board since WarpSE is the accelerator. Correct?
However, the 400K support was dropped beyond System 7.1, AFAIK. So, with System 7.1 and below, can use 400K.
My muddled memory of that era tells me it might not be so much an hardware issue as a filesystem issue. Original Macs were using MFS (Macintosh FileSystem) on the 400K floppies, before the introduction of HFS (Hierarchical FileSystem) that may or may not have coincided with the introduction of the 800K in the Plus.The ability to write 400K disks was dropped at some point I think (but believe it was later than 7.1?? maybe Iām wrong). But you can certainly still read 400K disks with later system versions. I do it all the time on my SE/30 running 7.5.5.
I suspect 400K floppy using MFS were dropped somewhere in the 7 era, but 400K floppy in HFS remained supported.
Just grabbed the Sony-Tektronix AWG2040 out of storage. Iām gonna use it to try overclocking the WarpSE.
I mean, itās open source so you can do anything with it you want. Weāre going to be selling 25 MHz units, but I am just seeing how much further it can go. There are always the āworst caseā and ātypicalā specs in engineering specifications including for chips. So if I bump the clock up too far past 25 MHz, the RAM and Xilinx CPLD will have to operate faster than their worst-case specs. And the CPU as well, plus itās already overclocked by 5 MHz.Ooooo! Wow!
So, maybe we can up the WarpSE to 40 Mhz? What about the crystals?
