larsovef
Kensington Turbo Mouse ADB Trackball
Update: No luck in cleaning the bearings. So I’ve desoldered the LED and removed the black housing with the bearing shaft on it. The...
May 25, 2026
T
ttyR2
Flashing AEC6280 for Mac use
Beige PowerPC (Old World ROM)
Howdy folks! First time posting here. I've been surfing the forum for a few weeks and figured I should register. I successfully...
May 25, 2026
campbellashe
Mac Portable 5V Line and Troubleshooting
I had the RAM error: 0000 0003 / 0000 FF00. Replaced the first lower row of RAM nearest to the Hybrid Module and.... the sweet sound...
May 25, 2026
campbellashe
Well removing the Sony transformer I lost some legs -- they were pretty brittle. Anyone have a similar issue and fix it?
May 25, 2026
Tango 2 without drivers installed is hanging my 6360 during Happy Mac phase of boot. Does that make any sense?
It's Alchemy Architecture, not Gazelle in which this card is problematic without the Great Gazelle PCI Fix. Makes no sense to me unless...
May 25, 2026
campbellashe
What was your approach to the carnage?
May 25, 2026
A
antonioos
Apple IIe floppy disk differences
Apple I/II/III
Hi, is there a difference between floppy disk I and floppy disk II? Could the PC also work with floppy disk II? Thanks a lot.
May 25, 2026
PL212
I recap'ed my Portable power supply that was in similar/worse condition... one tip is to (carefully!) do an output voltage test before...
May 25, 2026
A
AlpineRaven
MacSD inside a Mac Color Classic 'Mystic' - possible?
I was really curious - interesting as I hadn't seen it before and I was just curious! Seems a good unit to get and looked it up! Cheers AP
May 25, 2026
campbellashe
Macintosh Portable
Working on various parts of my Macintosh Portable as I await RAM to replace on my board..... This is the M5136 (CR-76U) from my non...
May 25, 2026
Hâlian
Nondestructively convert case-sensitive volume to case-insensitive one?
Yeah, I ended up finding iPartition independently, and it worked fine.
May 25, 2026
Disassembled ROM sources for Macintosh 128K, 512K, and Plus
@jonathanschilling Great work on that. Did you happen to take into consideration Steve Chamberlin's commented Mac Plus code found...
May 25, 2026
