One person on FaceBook is giving me feedback, and I just tried two different methods, although both have the same bad result... METHOD...
Friday at 8:10 AM
Macintosh IIx - Manufactured Feb 1991. What??
CR-45S. So, it's loud. 😞
Friday at 7:52 AM
That occurred to me as well. Even if Apple announced discontinuation for consumers, I imagine they would fulfill contracts that went...
Friday at 5:21 AM
Yes, and that keyboard sequence is on the back of the computer too. I've tried it without success multiple times. Here are high...
Friday at 5:11 AM
Apple Lisa 3d Case Project
Sounds like a sound approach! :) I just stuck that supply board up there if you wanted to check it out. Are you considering using a...
Friday at 5:03 AM
thecloud
On the PDQ it's a key sequence rather than a button. I found an article that mentions the PMU reset is holding down Fn-Ctrl-Shift-Power...
Friday at 5:02 AM
Where is there a PMU "reset button" on the "PDQ"? (Mine is indeed a "Wallstreet" in that it is 2nd gen., but technically it is "PDQ")...
Friday at 4:43 AM
It is a major limitation for people like myself who mostly have Apple keyboards, all of which (USB models) have hubs. But beyond that...
Friday at 4:37 AM
thecloud
My Wallstreet PowerBook G3 died in a similar way. It also had a long-dead (or mostly dead) battery, and so I always relied on powering...
Friday at 4:31 AM
Radius FPD/SE clone with Rotation Transform and Output from HDMI of FPGA Project Board
Couldn't have explained this better mysel . . . that way at all! :ROFLMAO: Hope this makes sense to the gang here. Claude figured...
Friday at 4:15 AM
I found the ideal way to measure the voltage output... But I too am not getting any chime or video, and yet you say your experience...
Friday at 4:01 AM
Garth Beagle
Also these same PSUs can be used with other PowerBooks (IIRC at least 2400, 3400, original iBook) so if by chance you have one of those...
Friday at 3:55 AM
# Scanline Rotation Transform — Engineering Spec ## 0. Project Context: Cloning the 1986 Radius FPD (64/68Hz Board) This project...
Friday at 3:53 AM
