2112st
I Need Help-A Problem With Installing Linux Mint On a 2012 MacBook Air
Thanks, everyone! :)
Oct 26, 2026
V
VegasChris
First 100 personalized Mac's
Good day all! We received a donation of vintage computer equipment and while moving some things around recently we came across this...
Oct 26, 2026
S. Pupp
The Apple Airport Express can be used in bridge mode, and is cheap (I bought a pack of five for about $50) at shopgoodwill.com. It can...
Oct 26, 2026
If you have another Mac, you could use internet sharing and connect a thunderbolt cable between the two or if it’s older, a cat cable to...
Oct 26, 2026
François
JASONDOESITALL Adapter for 17" ADC CRT Monitor
IIRC the ADC CRT is fixed frequency. It’s complicated to use with anything that is not a Mac, unless you can control precisely the...
Oct 26, 2026
A
AlpineRaven
Wifi bridge module - I recommend this white or purple Vonets Wifi Bridge will do the job. Cheers AP
Oct 26, 2026
You can create a wired connection for local devices by using a router in bridge mode. Basically the router connects to your building's...
Oct 26, 2026
Mark_W
Macintosh LCII failure
No, only LC III and LC 520/550 has onboard vram. There's no activity on scsi bus at all? You can also try to insert a floppy disk, see...
Oct 26, 2026
2112st
Intel-based Macs
Hey folks...it looks like there is a problem with installing Linux Mint on a 2012 MacBook Air I want to buy... You need to have an...
Oct 26, 2026
jonschultz
There are several sort of silly things that could be wrong at this point, each having a low probability of being the root cause...
Oct 26, 2026
P
PappaDF
updated their
status
Emulated G3 (wasm JIT) + Rage 128 (WebGPU backend) playing Quake 3 in the browser:
Oct 26, 2026
