And this is the reason things like the Kensington MacSaver was developed:View attachment 6537![]()
Macintosh Plus - Wikipedia
en.m.wikipedia.org
Just to say thanks for uploading this! I've used it to replace a noisy squirrel cage and it's a lot quieter now.
I did have to make a small hole in the mount to get through to the original fan's power lines.
Even Apple stated in owner's manuals that Macs must be at comfortable temperatures like ours.
I think they meant the Mac should be operated in ambient conditions that are comfortable to people, not that no component inside should exceed room temperature or human body temperature.
Look up the operating temperatures for just about any component inside. They're designed to run much hotter than room temperature.
That is something we could tinker with and come up with nifty cooling solutions that Apple did not come up with back then. The R Pico and other modern chipsets could be easily used to provide automatic internal temperature adjustments to maintain a reasonable range of internal operating temperature than on the high end, especially with older compact Macs.
Sure, also to keep them quiet in cool conditions. Simple analog circuits can do this quite well and reliably.
Liquid cooling is for CPU only in that i7 hack and in any conventional rig, no? He says that the fan that removes heat from the liquid cooling rig in the usual SE position? Looks like that's the only case cooling installed? He says "The exhaust air doesn’t even feel that hot!" THAT hot in relation to what? I'm thinking he's stressing the System with limited cooling, CPU temp sampling's not directly related to system temp.Liquid cooling could work in a compact Mac case. While this person's Mac SE case did not have the SE stuff as an i7 Mac was put in, liquid cooling was installed.![]()
I wonder, maybe a smaller liquid cooling kit could be done?For example, I saw a computer cooling pump measured at 119.5 x 65 mm (4.70 x 2.56 inches). Would that fit in with the tubes and an additional small fan for liquid cooling?
Nice! Adapter bolted up to the A/B without a hitch? What fan did you use?Just to say thanks for uploading this! I've used it to replace a noisy squirrel cage and it's a lot quieter now.
It's EVERYTHING in the Bucket. Some components throw off more heat, some less and all have varying amounts of heat tolerance. Yep, PSU and A/B components would be the worst offenders for BTU production I'd think? Dunno what the weakest component would be in terms of heat tolerance?Yeah, it's not the CPU. It's the heat radiating from the flyback and PSU, correct?
Getting rid of spinning rust drives is probably the easiest and most effective heat reduction measure.
The SE(/30) PSU PCB can be removed from its case and mounted to the AB with a custom adapter plate for better convection cooling.
Why did you have to make a hole? I just ran the original wires on top of the bracket like Apple did for the original squirrel cage fan and metal fan brackets.
retr01 said:@NickB that is awesome!Can you take more pictures, like the front, back, and another side of the fan, for more perspectives of the updated design of the @alxlab fan bracket?
Trash80toG4 said:Nice! Adapter bolted up to the A/B without a hitch? What fan did you use?
Noctua's a big improvement. Fans like that have come a long way in the past 30+ years. How noisy was the "squirrel?"
