Might’ve hit the jackpot what do you all think I should do with these?
jajan547
732
295
North Carolina, USA
So this is the technical procedures 1-7 and peripherals. It covers all apple ii lineups, both the apple iii and iii+, Macintosh 128k to se. We even have almost all printers and monitors and the iigs series. What should I do with them? Also HD20, Disk ii and Disk iii.
Reactions: eric
Good! I can scan them in. My scanner is fast, about 30 ppm, and will OCR simultaneously with precision to PDFs. Then upload here on TD. :D
On the other hand, I can show you how to do that. I noticed many scans of Apple documentation were poorly done; I know those scans could have been done better. I am fully adept with Photoshop and clean up pages very quickly.
I hope you pick "SCAN!" :sneaky:
jajan547
732
295
North Carolina, USA
I have a brother 940DW it goes to 600DPI I wouldn’t mind scanning them if you can correct them like any alignment issues. And of course I’m choosing option 2.
Alright. 300 DPI should be fine—scan in grayscale to TIFF files. Then I can fix them up and PDF them all. :)
Then, I could group them to each Apple II and Macintosh model. More accessible for someone to pick out a specific model than to go through one big book. Ha.
Unfortunately, I do not have Adobe Photoshop (PS) anymore. Using GIMP works but is time-consuming as it doesn't have macros I could create in PS to process each TIFF image quickly - about 10 to 15 PPM with the PS macros.
I tested with a PDF of SE/30 Owner's Guide and realized it is hard without macros to speed up the process. I used to work on scanned pages to clean them up in PS. I created many macros for processing scanned pages to make a new PDF book from a scanned book.
GIMP can have macros but requires programming in script-fu or python. It does not have a record feature like PS, where actions are recorded into a script automatically to run a group of tasks linked to a hot keystroke or function key.
Hey @jajan547, I just thought of something. Why not use iPhone or iPad camera to snap pics of all pages and make them in PDF? The phone or tablet can be easily set up to do that. Apps already have built-in anti-skewing, focusing, OCR, etc.
jajan547
732
295
North Carolina, USA
I can but it’s not always the best, I haven’t started on these 8 yet but there’s another not listed online and I’m entering the last page PM me your Email and I’ll send it to you otherwise we have to wait for it to upload to archive.org. Also one of these books are staples any ideas how to upload that properly without causing damage?
No hurry. I can wait for it to show up on archive.org.
As for staples, it depends. Can you take pictures of the front, left side, and bottom? Then, I will have a better idea of how to explain to remove the staples safely.
Reactions: davidg5678
jajan547
732
295
North Carolina, USA
One second.... Here you are
Okay, that is pretty simple. Use something flat, such as a narrow plastic butter spreader. You can use metal, but it needs to be thin like a knife edge and done carefully.
  1. Gently go under one of the staple ends in the middle of that book.
  2. Work your way so that both ends of the staple are straightened up.
  3. Then turn over the open book so it is open and spread out in the middle on the bottom.
  4. You should see the staples there on the top.
  5. You can gently remove them with your fingernail (or a thin spreader).
  6. Repeat the process for the rest of the staples.
As long as you do that carefully, there should not be tears but tiny holes through all pages. Some will say to use a staple remover, but it runs the risk of tearing up the paper from so many years ago.
