Spent some time checking the PCB. All the connections between the BluePill, resistor nets and DB25 look good. Gave board another clean just in case. Nope.
Weren't there some issues in old System (7.x?) versions with exactly 2Gb partitions? Might be worth trying a slightly smaller or even 1Gb one.2097152KiB / 2048MiB
Just a thought...
That IS why I said "exactly 2Gb". I can't find where I read it ATM. It was just a suggestion of something to try.2 GB is 2048 MB.
No that's not it because the same Mac will happily boot from the same card in a different BlueSCSI. There's something whack-a-do (technical term!) with this BlueSCSI. But I tried a 20MB partition with 6.0.8 on it anyway. Same deal..Just a thought...
OK, thanks for that. I don't have exhaustive experience with BlueSCSIs, but have used several over the last couple years. I (well, someone I built one for) did have a super weird situation with one recently. We tore our hair out over several days only to discover that the uSD holder was warped enough so that the card was not making good contact against all the "pins" (pads?) in the holder. The solution was applying pressure - believe it or not, he used a guitar capo!! Maybe another thing to try - apply pressure to the uSD holder and see if that makes any difference...the same Mac will happily boot from the same card in a different BlueSCSI. There's something whack-a-do (technical term!) with this BlueSCSI.
No, not really... it was a genuine (and genuinely frustrating!!) situation :to clutching at uSD sockets...
