BluesSCSI hda files corruption
pocketscience
261
185
Sydney, Australia
Tried a different card and one image... same same..
BlueSCSI <-> SD - https://github.com/erichelgeson/BlueSCSI
VERSION: 1.1-20220626-USB
DEBUG:0 SDFAT_FILE_TYPE:3
SdFat version: 2.1.2
Sd Format: exFAT
SPI speed: 50Mhz
SdFat Max FileName Length: 32
Initialized SD Card - lets go!
Sd MID:12 OID:4V
Sd Name:SD
Sd Date:1/2016
Sd Serial:407585335
- HD50_512 P71ENG2GB.img / 2147483648bytes / 2097152KiB / 2048MiB
0:----:
1:----:
2:----:
3:----:
4:----:
5: 512:
6:----:
Finished initialization of SCSI Devices - Entering main loop.
@eric can you DM me a DEBUG > 0 firmware? Maybe I can catch some debug spew..
Just a thought...
Weren't there some issues in old System (7.x?) versions with exactly 2Gb partitions? Might be worth trying a slightly smaller or even 1Gb one.
I have images on BlueSCSI that are 2048 MB and work fine under System 7 that uses HFS. 2 GB is 2048 MB. :)
8 bits = 1 byte
16 bits = 2 bytes
32 bits = 4 bytes
64 bits = 8 bytes
16 bytes
32 bytes
64 bytes
128 bytes
256 bytes
512 bytes
1024 bytes = 1 kilobyte
1024 KB = 1 MB
1024 MB = 1 GB
and so forth...
pocketscience
261
185
Sydney, Australia
Just a thought...
No that's not it because the same Mac will happily boot from the same card in a different BlueSCSI. There's something whack-a-do (technical term!) with this BlueSCSI. But I tried a 20MB partition with 6.0.8 on it anyway. Same deal..
BUT, thank you for the suggestion - I'm clutching at straws here currently.
Sd Format: exFAT
SPI speed: 50Mhz
Sd MID:3 OID:SD
Sd Name:SC16G
Sd Date:9/2011
Sd Serial:4215912579
- HD10_512 20MB.img / 20971520bytes / 20480KiB / 20MiB
0:----:
1: 512:
2:----:
3:----:
4:----:
5:----:
6:----:
mg.man
141
73
Ardley, UK
OK, thanks for that. I don't have exhaustive experience with BlueSCSIs, but have used several over the last couple years. I (well, someone I built one for) did have a super weird situation with one recently. We tore our hair out over several days only to discover that the uSD holder was warped enough so that the card was not making good contact against all the "pins" (pads?) in the holder. The solution was applying pressure - believe it or not, he used a guitar capo!! Maybe another thing to try - apply pressure to the uSD holder and see if that makes any difference...
Reactions: pocketscience
mg.man
141
73
Ardley, UK
to clutching at uSD sockets...
No, not really... it was a genuine (and genuinely frustrating!!) situation :
...and before anyone asks, yes, this was a "kit" I built, *but* it came with the uSD holder pre-soldered. Never had an issue like this before, and will be speaking with the guy I bought the kit off - I doubt he's had this weirdness before as well!
