What are Modern Monitor/ Video Adapters for Old Macs?
Another thing I want to point out is that the Extron is not a swiss army knife type of solution. I use my Extron mainly for my Apple IIGS to display on a modern VGA or HDMI monitor through appropriate cables and adapters. If you want a swiss army type solution that will have so many options, get the RGB2HDMI.
jajan547
732
295
North Carolina, USA
It’s in the plans
525
DB15 to VGA should work because that is what I have, although I am using Apple part number 590-0322-A. But what are you connecting from Extron to the monitor? HDMI to HDMI?
I have heard this version (590-0322-A) of the adapter allows you to use a IIgs video output with the Extron (more info here: https://www.apple2faq.com/apple2faq/iigs-to-hdmi-using-an-extron-rgb-hdmi-300a/ ) Any chance you could map out the pins on the adapter so I can try to make my own adapter?
