2,184
I am currently filming a new video about the Apple IIe Card in my Color Classic Mystic. As many of you know, I performed the VGA mod on this CC earlier this year, which boost the stock resolution of 512x384 to 640x480. Smaller pixels means everything is smaller, but the upside is you can run many games and other apps which require VGA as the minimum resolution. Even so, aging eyes line mine prefer larger pixels, and I always thought it would be neat if we could switch back to the stock 512x384 on the fly.
One thing I have learned in my testing of the Apple IIe Card is that it switches the CRT screen resolution to 560x384, regardless of whether you have the stock 512x384 or the 640x480 mod! The IIe Card proves it is possible to switch resolutions without having to hack anything on the hardware side. I don't think the IIe Card has any video control circuitry on it, and instead it is just sending some kind of command to the Mac to perform the resolution switching. Would any of you know if that command is something hard coded in ROM?
I'm just trying to brainstorm about whether it is possible to use the same trick to alter the resolution to something else, such as going from 640x480 to 512x384 and back. It would be SUPER NEAT if that was possible!
Reactions: wottle
Solution
Bumping because I'm working on a color classic video myself, and I noticed that when I have my (unmodified) LC 550 board installed my CC I can set the monitor to 560x384 in the Monitors control panel. I had System 7.5.3 loaded at the time. Its slightly squished without a geometry adjustment but it does work. The original CC board still doesn't expose it under system 7.5. I have a hunch that this is because of the 520/550's LC III roots—the LC III's developer note does mention 560x384 as an available standard output mode. So if you want slightly more horizontal res and a slightly squished display, Color Classic II owners (or folks who put in a 520/550 board) can switch to the 560 mode.
Incidentally, don't insert a Macintosh TV board...
2,184
...or what about going to 560x384 in "Mac" mode? That might be more doable - since the h/w has been modded for 640x480? I assume the Apple IIe mode is stable with the VGA mod in place?
It is stable, yes. It looks as perfect with the VGA mod as without. I never tested my machine with the IIe Card in the stock resolution, but when I find screenshots online of the stock resolution CC using the IIe Card, it looks identical to mine with the VGA mod in place. Again, this is proving that the IIe Card is ignoring what resolution is set in the hardware (on the Analog Board) and is forcing a particular resolution (560x384) to display on the CRT. This is why I said, if that is possible (and we know it is), then it should be possible for us to manipulate the resolution in the same way. I just don't know how, on the technical side, hence my opening post.
mg.man
141
72
Ardley, UK
That begs an interesting question... if you're correct that the Apple IIe card forces 560x384, then that would mean it's "boosting" the resolution of a stock CC. Are you sure it's not just a case of the CC analog board having the ability to sync on the 'lower' Apple IIe resolution? How have you come to the conclusion the IIe output resolution is 560x384?
2,184
ANSWER: this Apple technical document
(Side note: I have the standard VGA mod which retains the 60Hz refresh rate. Not sure what happens if you use the other VGA mod which uses 67Hz.)
For even more detailed info, start watching this video until about the 13:00 mark. He shows both the LC and the Color Classic.
mg.man
141
72
Ardley, UK
Cool, THANKS for those! I was wondering about the LC.
I do have a IIe card in my CC II, and I do have a LC575 'board, so have been toying with doing the VGA mod. Good to know I won't lose IIe capability.
I'm still curious as to whether or not MacOS could access this 560x384 mode without alteration... :unsure:
mg.man
141
72
Ardley, UK
the Mac requires SQUARE pixels
I don't think it's "required", more 'designed-for'. Example, you can run MacOS on a Lisa - but it looks a little odd because the Lisa does not natively have "square" pixels. For the Macintosh XL, there was a "square pixel" mod to correct this. My point is, it should 'work', but it may not look right.
2,184
But if 560x384 isn't a supported resolution in MacOS, would it even work? Not sure. Maybe not.
Mac on Lisa works, I assume, because it is something supported by the Lisa, right?
Regardless, we need to know how the resolution switching on the Mac is done in order to know if it's possible to swap between VGA and the stock CC resolution. I suppose other resolutions like 560 or even higher resolutions than VGA could work too, but in my testing anything higher than VGA on the CC's CRT is too small and grainy to be usable.
All said, I personally want a switch (either software or a mechanical toggle switch) to flip between the stock CC resolution and VGA. That would satisfy me just fine! :)
mg.man
141
72
Ardley, UK
there's 'bootstrap' code in the form of MacWorks by Sun Remarketing. Perhaps that 'patches' the underlying ROM functions to add the Lisa resolution?
Do you mean CC? Regardless, I'm now curious what happens when going from LC 640x480 to "IIe" mode [560x384?] with an external monitor - esp. a flat panel LCD. I think I'll pull my IIe card and pop it in my LC and hook that up and see what happens - never tried.
2,184
I especially want to hear from a Color Classic owner who also owns the IIe Card and who has done the high-voltage VGA mod, which changes the refresh to 67Hz. I suspect resolution switching even in that case would work fine, but that isn't something I've tested.
mg.man
141
72
Ardley, UK
Just remembered... the "LC" supports 512x384... I do have a LC, but not sure I have a working CRT that will work at that rez (don't think my LCD will?). I'll see if I can explore that path...
2,184
I cannot comment on the LC except to say that typically the Apple 12" RGB Display is used with them, and that display has a native resolution of 512x384. So it seems you have something other than the 12" display. Regardless, I'd love to see a photo of your display when the IIe Card is in the IIe environment.
mg.man
141
72
Ardley, UK
I don't have anything on the LCII to load atm... must get the TotalReplay image...
mg.man
141
72
Ardley, UK
Haven't had the chance / energy to do a full Total Replay / ProDos partition set up on the LC II, but I did connect my FloppyEMU in SmartPort HD mode with the bundled FE image from BMOW...
No resolution switch... the output stays 640x480 @ 66.7Hz
2,184
But in your first screen photo, I am not noticing anything being chopped off or truncated or pixel-distorted. It looks exactly like it should when the resolution is set to 560x384. If it was displaying in something other than 560x384 mode, I would expect some kind of distortion. But again, I am not seeing that in your first photo.
