Design68: A 65% replacement keyboard using AppleDesign controllers
demik
46
Was working on this since a few weeks. Since it works, I'm gonna post that here.
One common issue I and a few other folks have is that while Apple Extended Keyboards are great (and still my favorite keyboard), they are kinda big for test benches or if your retro corner is small. That and we have too much dead AppleDesigns siting around
The following idea was reusing the keyboard controller from a dead AppleDesign into a custom new keyboard.
Please note that this is ISO only for now, but everything including PCBs will be put on GitHub for people to mess with !
I only tested with an ALPS ISO 341-0001 Controller. Others controllers will probably need a different PCB
What's needed​
- Tester68 keyboard from CIY
- A dead AppleDesign keyboard
- 70 MX styled switches (5 pins recommended)
- 65% Apple styled keycap set
- custom PCB
- 2U keycap stabilizer
- some tools (a Dremel would help greatly)
Build log​
• Solder everything on the back of the PCB. The controller needs to be socketed
• Cut every leg as close as possible to the PCB
• Convert plate from ANSI to ISO
• Remove batteries holder, USB receiver. Cut case for ADB cables and ADB socket
• Reassemble PCB / gasket / plate / switches (need to temporary remove the controller here)
• Route cables. You may want to use some glue on the panel here. This is to avoid yanking the cable out of the PCB
• Keycap time and it's done ! Please check if the ADB socket hole can accept actual connector, you may need to enlarge it somewhat
Builds​
To give you some ideas, two keyboards are already build:
Build #1
- Case: Tester68 translucent black case
- PCB: Black, red LEDs
- Switches: AEBoard Naevies v2 (Alphas), Cherry MX Clear (Mods)
- Keycaps: Keychron ISO-FR ABS
Build #2
- Case: Tester86 translucent purple case
- PCB: Black, blue LEDs
- Switches: Cherry MX Black
- Keycaps: Keychron ISO-UK PBT Retro
Mandatory family pics (AEKII uncle for scale)
Everything is OpenSource and published on GitHub here
Gerbers files can be downloaded from here
On a side note, We know that there is at least 2 or 3 ISO AppleDesign variants, which may have different controllers (same with ANSI)
I'm trying to document which AppleDesigns are suitable for this project. Can some of you please check what's inside their keyboards ?
Thanks for the help
RetroTheory
82
127
Great project , I have a few different ones
Made in Czech Rep. 3 Screws on base
Assembled in Thailand, 4 screws on base
RetroTheory
82
127
There is also this clone made by ALPS (MEADB-), But inside we have a familiar IC. Not sure if the membrane layout is the same though
demik
46
Thanks @RetroTheory and @François
I didn't know about the ALPS clone.
About the NMB one, it looks like that's really a different controller. The KS88C0504 has internal pull-up controllers, while ion the NMB PCB, it's external. Also a few more things that aren't there on the ALPS version.
For reference, here is the one I used:
demik
46
Thanks to everyone photos who helped: ANSI version of the PCB !
It turns our the controller is dual mode, and will boot into ISO or ANSI mode when installed in the respective PCB.
You can find the ANSI Gerbers files here
Reactions: RetroTheory
François
117
51
France
It’s a really cool project, but I was wondering wether I needed to make it. Turns out I already have a compact ADB keyboard, that even include a trackpad: the one that comes with the TAM!
Reactions: Patrick and wottle
588
I do as well, however:
1. I don't want to put the wear and tear on that keyboard
2. That arrow key layout!
I'm going to be trying to put one of these together. Only have one keyboard with the correct ANSI chip, but will be a fun project. Steal some switches from my son and will be nice to have a new ADB keyboard with modern mechanical switches.
588
@demik , I got my PCBs in today. I am trying to re-use the ADB cable from my original keyboard. I'm not too familiar with the pin markings for the cable (G V A P E). The wires in my cable are black, white, red, green, and blue. Any help on which goes to which? Or if you know which pin on the ADB connector each goes to, I can tone them out.
Also, the socket for the controller covers up some of the switch pin locations. I assume you solder those key switches in first, cut the pins close, and then put the socket on?
Appreciate the work you put in to it! Excited to have a modern ADB keyboard I can play around with!
Reactions: demik
588
OK, So I answered my own questions. First, I made a massive mistake soldering on the key switches without realizing they need to go on AFTER the red rubber later and the top plate (the part with the stabilizers). So desoldering all those switches was fun!
The correct order of assembly, for those who haven't built their own keyboard is as follows:
  1. Solder all the components on the bottom of the board, EXCEPT for the 40 pin socket for the controller chip. See notes below about soldering the ADB cable.
  2. Cut the pins on the top side of the board as close as possible, particularly any that will be sticking out where a key switch will be installed.
  3. Before soldering down the socket, I'd recommend test fitting it, marking where the pins for the key switches will be that will be under the socket. Unfortunately, there are some pins that will be hard to reach if you don't clear away some of the plastic from the bottom of the socket. I used my soldering iron to melt away material where the pins would be. There were 4 pins covered by the socket plastic, at least on the sockets I used. After making room and verifying the location was correct with a test fitting, solder down the socket.
  4. Once all the components on the bottom of the board have been installed, you can add the rubber gasket and top plate to the top of the board (no screws to hold it in place, so just position it for now.
  5. At this point, I added about a half dozen key switches. I used 5 pin types that were meant for hot swapping and they clipped into place nicely. I positioned them in the middle (where the socket is as those will be tricky to solder in with the socket in the way, and then the corners. Note that my PCBs from JLCPCB were a bit warped, so the board was pulling away and I needed to apply pressure to get the board snug to the top plate. Once the switches were soldered in, they will hold the PCB tight against the top plate and it was pretty flat.
  6. It this stage, I went ahead and tested it out the keyboard and the few switches I had soldered by plugging it into a Mac that doesn't require soft power, plugging a mouse into it. Fired up Mac OS 7, ensured the mouse was working through the keyboard's ADB port. Then went into Key Caps control panel and ensured the key presses were registering.
  7. Next, I soldered the rest of the switches, except for those with LEDs under them.
  8. Solder on the LEDs and the final key caps.
  9. Next, I did a test fitting in the case, and marked with a sharpie where I would remove material. For inside the batter case, I removed the area as shown by OP around where the USB wireless adapter was being held. This is where the ADB cable will come out of the case. Make sure you cut this big enough to pull the ADB connector through. I also cut out a section in the batter compartment for the ferrule to have room. It seems too tight to have the cable fold back on itself like the OP did if the ferule is on the cable. I also had to grind a little notch in the battery cover to allow the cable to exit the battery compartment when closed. For the ADB port, I marked the center location and then used a drill bit to cut a perfect hole where the ADB port will be. Looks nicer than what it would look like if I had hacked at it with my Dremel.
  10. Assmbly time! Pull the soldered on ADB cable through the hole in the battery compartment, all the way until the PCB is seated in the case with all the screw locations lined up. Test the hole you made for the ADB port to ensure you can plug an ADB cable into it. If it looks good, you can grab some of the screws you have from the disassembly of the Tester68 keyboard and screw the PCB, gasket, and top plate down into the case.
  11. (Optional), I like the black cable look, so I used Duplicolor Matte Black Vinyl and Carpet Dye to paint the ADB cable black. Matches the black accessories that came with the Mac TV perfectly.
  12. Route the cables as shown by OP, reinstall the battery cover. Improvise strain relief and secure the cable as you see fit.
  13. Install key caps!
Hopefully having the steps laid out will prevent others from making the time intensive mistakes I made.
OK, as for the ADB cable connectors, I mapped out the connection, just in case the internal wire colors are different on different ADB cables. I used two ADB cables. One that came with my AEK, and another standalone ADB cable that has a coiled section, which I like for keyboards. For the AEK cable, the internal wires were black, green, red, white, and blue. For the standalone cable, the internal wires were orange, red, black, and tan, with the shell connected to the uncoated wires going around the shielding.
So, Looking at an ADB cable head on, it looks like this:
     ______
  2 / *  * \ 3
 1 | *    * | 4
I've number the pins. starting with the left lower pin being 1, going clockwise to the right lower pin being 4.
So, the connectors on the PCB are labeled G V A P E. Below is a table of the pin, and the corresponding wire to connect to it for the two cables I used. I'd double check your cable in case the wire colors are different.
PCB labelADB pin numberAEK Cable wire colorStandalone coiled cable wire color
G3greenorange
V2redred
A1blueblack
P4whitetan
Eshellblackbare wire in sheathing
I tested both wires out on two different boards I was assembling and the wiring checks out as far as I can tell.
Reactions: demik and François
demik
46
Hello,
Nice detective job !
I'm not 100% if Apple cables are all the same, but you got that right. The letters stand for :
- G = ground (green)
- V = VCC / +5V (red)
- A = ADB bus (blue)
- P = Power Trickle (white)
- E = Earth / Shield (thick black)
Also thanks for your build log, it will help people more than mine did. I did the socket before the key switches, by pressing them little more the pin will go under the socket. That's socket and switch dependant I guess
If that helps, the other LEDs are :
- NUM Led is under FN (which is the power button)
- Scroll is under Home
You can make them blink with apps like https://macintoshgarden.org/apps/adb-express.
I had another one which would blink the LEDs on Network or LED activity, unfortunately I cannot find it anymore...
The accent key LED is always on and totally optional
Any pictures of your build ? Did you use the ANSI or ISO PCB ?
350
VERY cool! Was thinking along these lines a LONG time ago, but back-burnered because I wondered how the flex switches differed electrically from mechanical switches? Might there be a problem with such, if so?
Reactions: wottle
588
Hello,
Thanks for the response and for building out this PCB!
I used the ANSI layout. I was waiting on key caps to come in before posting pictures, but ended up harvesting the caps from a Kechron K2 I had. It looks good. I'm not sure if I used the wrong LEDs, but I don't get any of the LEDs to work. I'm thinking I may have fried the LEDs with too much heat for too long. I'll see if I can be more careful on my second keyboard when my tester68 comes in.
I need to find another key cap for the power button (probably just throw the fn key back on there), because the red key is meant for the top row, which has a different height / pitch.
A couple of ideas for improvements:
At least for me, soldering the ADB wire directly to the board made for a challenge. The wires, especially the ones on the standalone, coiled ADB keyboard, seems to be a pretty weak connection. Would it possible to adjust the spacing and allow for a connector to be soldered on to the wires and then connected with a JST connector of some time. Maybe something like this:
Or, possibly like some of Apple's ADB cables, make two ADB ports on the back. So replace the cable connector for another mini DIN4 connector? One goes to the computer, another to the mouse?
Second, and this is probably way too much work, but it would be really cool if you could make one with hot swappable key switches. Maybe even be able to harvest the hot swap pin connectors from the Tester68?
Third, I had a bit of a hard time soldering the switches under the 40 pin socket. If they switches were hot swappable, there wouldn't be the need. If not, shifting the 40 pin socket location just a few mm up would probably make this part much easier.
Just some thoughts I had while working on it that might be worth considering if you make other changes to the board.
Additionally, it would be great if there were a new stock source for the controller chips, but I know that is probably a tall ask. I'll just have to be on the lookout for more AEKs that are in bad shape and I can pul the controller from.
demik
46
Might be. The loop resistance of a membrane "switch" is about 100-200Ω and act as a current limiting resistor. When switching to standard switches, it goes down to 0Ω, so you have to be careful in some cases to not short the controller.
The 341-0001 has 33kΩ internal pull-up resistors, so 33kΩ or a 33.1kΩ resistance to ground is a rounding error
demik
46
Thats weird, maybe the LEDs are backwards ?
This does look so good with the Kingston Trackball !
The PCB was designed to use an angled right 2.54mm header or a connector like this (see the silkscreen). I soldered the cables because I've got no patience. The internal connector is a good idea as the wires are indeed pretty weak.
Toyed with that idea for a bit. Had clearance issues with either switches or the case.
There is another way to do it tho:
The mini DIN port can be used as an input port as well. How do you connect the mouse then ? Just build an Y ADB cable with a female socket for the mouse like some ADB devices did back then (either at the keyboard or Mac end)
That should be easy if I can convert he current footprint easily. it will however needs SMD LEDs or no LEDs at all as hot swap switchs cannot support THT LEDs
As for harvesting hot swap pins I kinda melted like 20% of them while trying that but patience etc.
Noted thanks. Moving the 40 pin socket up and down is going to hit the switches. Do you mean left and right ?
And yeah I'm not sure if there is some stock source for theses... I grabbed a $15 trashed one for my second build, but that's a valid concern. Looking for KS88C0504-19 gives a few result on dodgy sites, pretty sure it's out of stock or fake stuff…
588
Possibly. I didn't actually realize the LEDs were polarized. So It is very possible I did it wrong. I'll be sure to get the correct polarity on my second board.
I tried 2.54mm spacing but on my ANSI board they are closer to 2mm spacing, so my 90 connectors didn't work (a 4 pin connector would span all 5 holes).
Interesting, I may try that.
Yeah, that's probably harder to re-use due to their small size and plastic parts.
No, I just didn't look at the top side of the board. I was just trying to avoid the pins, but realize it has to be there to avoid the footprint of the switch.
Yeah, I'll keep an eye out. Unfortunately, none of my trashed keyboards have the right controller. I have one from a rusted out keyboard that is a 341-0875-A (INS8048-6TGZ/N). What's the worst that could happen if I try it in the PCB?
Thanks again for doing this. I've been loving typing on the keyboard!
350
If it's no biggie, could you further explain the ramifications of that differential for the project? What might be done to rectify any such problems? Don't want to throw us into an unnecessary tangential discussion.
demik
46
Sure. For this project with this controller (341-0001) there is no difference. The controller is versatile and has everything built in (Pull-ups, current limiting resistors…)
Using another controller however, pinout issues aside, would maybe need (at lease) a resistor network on the keyboard matrix or different resistors for the LEDs.
You can see that apple provisioned a resistor network on the board (RN1) which isn't populated because the controller has them onboard
demik
46
Usually LEDs (most, not all) do have a flat notch on them. It should match the notch on the PCB silkscreen
My bad, you are right. It's 2mm spaced
You are welcome !
I've never seen the 341-0875-A. Where did you find it ?
