eMate 300 Restoration progress—My notes and your advice
caver01
144
What a happy looking eMate!
I'm very curious about doing this myself, but have been a little wary about buying and soldering batteries. How is the battery life? Any tips you think are important to follow?
Hey, thanks for following along. . .
Great question. I would absolutely do this again and you have even a little skill with the soldering iron this is pretty simple. I would suggest getting tabbed NiMH cells unless you have a battery spot welder. I considered getting one of those mini ones because they are inexpensive and I have seen a few reviews, but opted for tabs and glad I did.
I followed this guide here:
https://www.pda-soft.de/emate_battery_pack.html
which was a fun read and very good instructions. I'd say the trickiest part of it by far is carefully peeling the adhered components off the old pack--paper stickers on the ends and foil covering the thermistor. If you are slow and methodical with an x-acto knife or fine tweezers, you can get all of this off with ease and no damage. Also, the switch on the end cap of the old pack needs to come off which is prying it off the spot welds. Not an issue, but you just need to be careful and use a side cutter or needle nose.
Other than that, my tips are to have some Kapton tape ready and a stick of hot glue makes all the difference holding everything together. You don't even need the hot glue gun--just a few mm of the glue stick which you can nip off pieces with a wire cutter and tap into place with a hot iron tip. The glue easily melts and you can lay it between the touching cells to hold them together and it only takes seconds to harden. You don't need much. See the guide.. Glue cleans off the iron easily.
In therms of battery life, that's a very good question. I bought my cells on Amazon and the sticker says 2000mAh which may or may not be real. Theoretically, they should be giving me nearly double the advertised original life. Apple docs said 24 hours continuous use (depending on usage) which probably means whether you are running the backlight, constantly beaming files, or running PCMCIA cards etc. I have not had a chance to test it, but it charged quickly (cells were already at 1.25v each) and it is properly detected by the OS. . .
I just unplugged power here at 9am local time. I have some errands to run today but I will leave it on battery now for a while and see what happens. Of course, I have no idea what I am doing with this thing, so I will have to just type some junk and make a couple drawings. Ha ha ha, that's maybe as much as I will EVER do with this, but it is fun nonetheless. I will report back when I have more time on battery to share.
caver01
144
I will add that you could probably get away with vinyl electrical tape to hold the pack together. It won't be as smooth--heck, even I didn't have big shrinkwrap--but if you keep tape layers to a minimum it should easily slide back into the plastic case with the clips, and there's plenty of room with the foam spacers inside the eMate even if it bulges a little.
I did not take detailed photos of the soldering, but everything happens on the battery tabs. When lining up two cells end-to-end, just line up the adjacent tabs (positive on one with negative on the other) like a little set of wings sticking out, and solder the tabs together. Done right, you can bend them flat against one of the cells.
When bringing the two joined cells together as a 4-pack, rotate the m so that the tabs you soldered are angled next to the touching edge. Dab some glue to hold the sets together.
Finally, the switch which came off the old pack goes on the endcap opposite the wiring harness. This was spot welded, but you can flatten the contacts a little and tin them, then bend the tabs from your new pack into position so they can be soldered to the switch without anything sticking out beyond the radius of the cells. It doesn't have to be perfect. Paper insulation will go over this (you saved it right) and there is plenty of room if your soldering isn't perfect.
Take your time with the wiring harness and care with the thermistor. Cleanly tape it all up and put it in the case.
caver01
144
Well, it's midday Sunday, and the eMate has been on battery power since Friday morning. The battery indicator is still showing the full bar of power. I see no change in the available power. Of course, it's not like I am using the eMate all day--not even close. But, throughout the day I open it, turn it on, turn on the backlight for a while, try a little typing, some drawing. I am struggling to actually do things with it to test, and since I don't have a good sync cable yet, I don't have any added software to maybe run benchmarks. Is there such a thing for Newton OS? It would be great if I could simulate activity somehow and see how quickly the battery drains. So far, however, this seems like a very useful device for anyone wishing to have uninterrupted productivity--assuming you can be productive with writing for example.
I have done a bunch of Alphasmart Neo restorations which typically run on AAs. They last for months though--something like 800 hours. Yet, the experience is not even close. The Neo(2) has a tiny text screen. It's fine for writing or even note, but it is very limited. Now that I own the eMate it might be time to part with my Alphasmart Neos, though it isn't really taking up space and it is a nice piece of comparative nostalgia.
I am going to leave the eMate as-is on battery for as long as I can now and report back.
Andy
Wow that's really great! Thanks for doing the test and reporting back. Also thank you for all your tips. I probably won't get around to working on the eMate for ...awhile, but I have this bookmarked for future reference.
caver01
144
It's Monday, and I have been trying to get the eMate to dock with my M1 Mac Mini. I bet I have tried the connection attempt via serial about 30-40 times after various troubleshooting steps. None have worked so far, but I wanted to update you about the battery. The bar has moved to about halfway now. I have not plugged it into power since last week. Of course, this usage is not really normal, but I have been powering up, turning on the backlight, trying to connect, over and over today. It's taking a toll on the charge, but not ready to plug it back into power yet. More to come!
Reactions: Andy
caver01
144
@Andy Today I tried to sync the eMate with a few versions of OSX. After several attempts I saw that the battery indicator was getting low so I am plugging it into power. That’s nine days of standby and occasional use for troubleshooting. It’s not a good test of typical usage but it at least demonstrates very good standby time.
caver01
144
The eMate restoration continues. My last updates here were related to the battery which continues to work fine. My problem was getting the eMate to sync. Having done some troubleshooting now on another thread here:
Connecting eMate to Mac OSX - "there was no response"
I now have a working connection between a modern Mac running NCX and/or an older eMac running NCU on OS9. The solution for syncing in my case was twofold: I needed to use a null-modem crossover style serial cable, and I needed a driver-supported USB-to-Serial adapter. When I had both of those in hand and setup on the host systems, I was finally able to sync the eMate. I have already installed a few packages including the patches to support current date/times as well as Macintalk to speak text just for fun.
Next, I'd like to explore some eMate software options. I want to move the networking forward a bit so I can setup an ethernet or wifi PCMCIA card, but I'd also like to maximize any productivity software.
It seems that Newton Works is installed by default on the emate, though I struggle to find the spreadsheet app. I tried installing the NewtWork package but got a message that it is already built-in. Is that true? Where is the spreadsheet?
With my Newton OS patched, date updated, and a few packages installing successfully, does anyone have any suggestions for must-have software on the Newton/eMate?
Thanks for reading along. It has been a fun bit of history and challenge with achievable goals! It feels good to make progress.
Andy
Congrats on getting NCX working! I haven't tried it with a serial connection, but it did work for me over Ethernet ...hmm, two years ago. Hopefully it still does.
For a spreadsheet for Newton Works you want Quick Figure Works. I think it's not part of the system R OM, but was included on the eMate CD. You can download it and also a graphing calculator for Works at http://www.unna.org/unna/applications/NewtonWorks/
Quick Figure also had a more featured version called Quick Figure Pro.
caver01
144
I will definitely try to get it working over ethernet or wifi, but having never synced I am pretty sure I needed software packages first to be able to support the card i have.
Thanks for the details on Quick Figure. That sounds like what I read but I couldn‘t recall the specifics. Now I know what to look for.
