Radius Full Page Display for Macintosh 512ke/Plus - Cloning project possibilities?
462
Looks like my rotation concept proved:
The LCD​
The final size was always going to be determined by the LCD panel which needed to be able to display the 512px x 342px screen buffer. I eventually settled on the smallest 640x480px LCD I could find at a sensible price which was a 2″ TFT panel . Unfortunately it transpired it was technically 480x640px i.e. portrait. I assumed using in landscape would be trivial but I was wrong. The driver being used on the panel (the ST7701S) offers no image rotation function so the only option would be to rotate the frame buffer on the Pico. The problem was that the Pico was already being seriously overclocked to make pico-mac responsive so there just weren’t a lot of processor cycles to spare.
I looked at using one of the spare PIO state machines to rotate the frame buffer but I couldn’t find a way to make that work. In the end I took a step back and looked at a different approach. In its native portrait orientation, the LCD panel I had was 480px across. This was only 32px (1/16) less than the Macintosh screen width of 512px, which might be an acceptable compromise, so I tried getting the PIO that outputs the image data to drop every 16th pixel. This worked … sort of … but the result was unsatisfactory due to the common use if 1px wide vertical lines on the Mac interface such as window borders which would completely disappear at times. What I needed to do was make the emulator output a 480px wide image natively and this meant altering the Macintosh ROM file it uses.
I went about this all the wrong way but eventually managed it and compiled a version of pico-mac that outputs 480x342px … I was back in business. This compromise on resolution had a silver lining. Because I was now running the Mac screen across the full width of the LCD in portrait orientation, it meant the visible screen area was now smaller and that meant the Macintosh could be slightly smaller. It also solved the problem of having to factor in space for wide black margins on either side of the LCD which would have been necessary had I put a 512px wide image on a 640px wide LCD. It also meant the LCD flex cable was located at the bottom, not the side of the LCD so I would not have to bend it tightly.
Apart from an SPI interface to configure the LCD driver, the panel uses RGB565 (5 bits for the red and blue, and 6 for green) for the image data. That’s 16 data bits which was way more than I had available on the Pico. Fortunately, the original Macintosh had a black and white screen. It did not even support shades of grey. So I actually only needed to send one of two signals; all data bits high or all data bits low, and this could be done using the existing RGB data line provided for the pico-mac VGA out. I ran this past Matt but he said he didn’t think a single GPIO could drive that many inputs without using buffers so I began working on adding logic buffers to my PCB design.
In the end I didn’t need to because the backlight on the LCD panel is so bright, I found that only setting the most significant bit of each colour high still produced a bright enough image. Due to the asymmetry of RGB565, I found this gave a reddish tint but this disappeared if I drove the top two bits of each colour and gave be 50% more brightness. That is what I settled on and I have experienced no problems driving these 6 input lines from the same GPIO.
________________________________________________________________________
Seems like his initial approach to going from portrait to landscape mode for his LCD should work. He went with a different approach which worked out very nicely, reducing the size of his Pico-Mac-Nano. I'll have to take pics of my sketches illustrating the first iteration to post.
Capturing the full frame buffer and stripping the "Portrait Mode" pixels out of the buffer at right angles would yield a nicely rotated "Landscape Mode" input of the frame buffer to the LCD I'd think. Then Rotate LCD.
I'd like to build rotation hardware into the FPD card clones.
jmacz
95
112
Interested in what you figure out.
I have been unable to find a reasonable portrait display and card for my stock SE, whether due to brokenness or asking price.
I was hoping to hack my own solution using a rotated LCD and a RGBtoHDMI, using black crop bars and a custom 3d printed bezel, but the RGBtoHDMI cannot rotate the image on the fly, so I had stopped as I don’t have the knowledge required to design something new.
462
Thanks for chiming in! I wind up talking to myself in these threads. :(
As you'll see below (hopefully) the scanline output orientation of Radius' FPD boards is unsuitable for using a standard LCD. I've found only exceedingly expensive solutions for the rotation of Hi Definition Video and the like. I figure rotating only 640x864 single bit pixels ought to be "easily" done. LOL!
Couldn't find the original, so cobbled this diagram together at work in downtime tonight. I think the presentation is a bit better, maybe?
Dunno what panels might be available for a custom build. Been thinking that my 1024x768 or 1280x 1024 panels might work out nicely in FPD mode? In the 1280 panels, DVI connector input appears ubiquitous. Keeping everything digital (DVI-D) would seem to be the ticket.
Scaling to utilize the full panel would be perfect, but haven't gotten around to looking at that as yet. I've got an Extron Scaler, but dream is to do scaling with the same hardware used for stripping out the captured frame buffer. Everything should be built into the FPD Card Clone.
jmacz
95
112
I was thinking 1024x768 which would fit the 640x870 resolution well at 1:1 when rotated, with crop bars (77 pixels on each side and 64 pixels top and bottom) without scaling and cover up the crop bars with a bezel. 1280x1024 would need scaling or have huge crop bars.
I had looked for panels with built in rotation but couldn’t find any.
jmacz
95
112
I might have searched for the wrong thing, there are some panels that are native portrait mode, for example saw one at 800x1280.
462
Interesting, bare panel/controller or full on display? I've been thinking inexpensive/obsolescent displays.
That's exactly what I've been thinking. But figured they're older displays lacking DVI input?
Hoping scaling can be worked out for the likes of my 19"/20" HP and Dell displays.
Fearing that the 1 pixel borders of windows and such will be problematic?
I didn't even search for that.
Been waiting a very long time for big, high res displays with customizable resolution "picture in picture" that can be positioned at lower left or right corner. next to a compact Mac. Scaling FPD res by 2x or 4x would be no big deal. Perchance to dream!
Thinking DVI-D input for "middle aged" displays sans HDMI, but the output of the card should best be Micro HDMI from SBC of some sort.
Micro HDMI end of HDMI Cable ought to be able to be fished through the security port of a Plus?
Screenshot 2025-06-27 at 12-18-55 Amazon.com BENFEI DVI to HDMI Bidirectional DVI-D to HDMI Ma...png
Sub-$10 Adapter transition to DVI-D input of older Display completes the connection. Native HDMI Display or Panel/Controller combo for new build would be straight HDMI cable setup. If using SBC with full size HDMI output can be converter to Micro HDMI internally.
Hadn't thought of using 16:10 WUXGA, that's a very interesting option in a 15" panel! Wondering if it'll fit within bezel restraints?
jmacz
95
112
Bare panels. They are a little small though, 10”.
These seem to be native vertical but not 100% sure. This next one seems to support built in rotation.
mini HDMI.
462
Yep, 10" tablet size panels are much too small to work out at all for me. 15" 1024x768 panels might be the ticket with the right frame buffer tomfoolery. Trying hard not to pull the trigger on this one:
Gotta get someone involved who can pull together the SBC based rotation trickery. Then I can try to get the image squared away with my Extron Scaler on that panel. Gotta find an LCD controller for it with HDMI input as the first step.
Dunno, too many things bouncing around in the noggin' to make much sense of anything ATM. But that panel might just work out for a ground up build. Though still thinking inexpensive displays should be the target at this point.
Need to get the captured Frame Buffer stripped off column-wise for rotation on board the FPD clone with an inexpensive SBC.
jmacz
95
112
Plenty of 15” 1024x768 panels. But at that resolution, do you really need a scaler? Why not 1:1 with cropping?
462
1:1 with customized cropping would be the Extron Scaler's stock in trade. I can set the margins around the FPD output however I want. If such can be handled via SBC magic so much the better, but I'm thinking in terms of what I might be able to do with hardware in hand at this point.
jmacz
95
112
Ah got it. Based on the name I thought you meant scaling it to fill. Cool!
462
Scaling the image for fit an inexpensive, used 20" 1280x1024 panel would be the way to go. Dunno if the Extron is up to that. It's been a long time since a messed with it, baby steps.
Anybody out there interested in implementing rotation along the lines of what I illustrated above?
edited typo
jmacz
95
112
I just found a newer thread regarding display rotation and the RGBtoHDMI project.
Might be a solution to provide both rotation and crop? If not, I would think that modifying that code base would be the fastest path to getting something working? I don’t have my RGBtoHDMI with me to try but will have to give it a whirl when I have a chance.
462
I've been pondering this TTL input spinoff from the RGBtoHDMI project. It keeps everything in the digital realm.
Have you got linkage to the original RGBtoHDMI project handy?
To bad this stuff is so very, very far above my pay grade. 😦
edit: I think it should be a lot easier to implement the frame capture/column stripping technique in my illustration above. RGBtoHDMI seems overly complex for a simple datasnatch rotation of a single bit image?
p.s. thanks for your like of my doodling @JDW
462
Just pulled the trigger on that 15" panel. Gotta find the right controller. Looks like backlight cable power is needed?
Design study/mockup of FPD enclosure is right up my alley. Printing a case and cobbling the bits together is well beyond the scope of this project however. Scaling the image to a the likes of an obsolescent 20" 1280x1024 Display is definitely the way to go. KISS principle compliance!
madcow
12
I have one of the Plus/512k cards with the 68000 CPU on it sitting around. I can try to take some photos of it if that would be useful.
462
Absolutely positively! :) That would very much be appreciated.
I've shifted my focus to the SE FPD Card as that's the only one I have in hand.. Magic Bus connectors have been said to be unobtanium, but not at all worried about that. My clone project is aimed at interfacing with a simplified Performer Plus extended to the rear implementing an updated Magic Bus connector interface. Such should make the setup compatible with both Plus and SE. I think that'll make a very nice new build expansion combo for both machines.
Forward compatibility of FPD/Plus or backward compatibility of FPD/SE would be ideal! Is there any chance you could test your FPD/Plus Card in an SE?
edit: that'd require disabling the 68000 on either card or mobo.
@Bolle have you had a chance to play with that amazing toy as yet? Testing it in the SE might prove very interesting indeed! ;)
ISTR you've got a socketed SE in the menagerie?
madcow
12
Not the best images, but what I could snag tonight quickly. I don't have the cable to connect to it, but I do have the display and it works with the nubus version of the card. I have been meaning to see if this card works and fix up a spare plus to try it out inside. I hear you have to do some logic board modifications and I don't want to mess with my prize Plus Platinum. Let me know if I can get any more details for you.
462
Very strange, that looks like the Killy Klip setup. If so it would clip onto the 68000 on the mobo? There were ceramic and plastic packaged CPUs, one of which was problematic for using a Killy Klip. I needed to solder header pins to the legs of the 68000 when I installed a NewLife board. Looks like this one might go either way as well, which makes me wonder why there's a 68000 on the card itself?
Thanks much for the pics! Pics of that connector from several angles to give me the chance to "see it in 3D" would be much appreciated.
edit: have you seen the installation directions or a list of the board modifications required? YouBoobTube video?
Very curious. Wondering if the 68000 on the board works in conjunction with the Plus' processor? I have a SCSI2 card with a 68000 controller on board on board. Plus was pre-DeclROM/Slot Manager setup. The presence of High/Low ROMs on the the FPD cards (only one on the SE/30 FPD) makes me curious.
