Is this portion of the chassis removable - a subframe?
Yes.
TOP
BOTTOM
Thank you, these photos clearly illustrate the hinge assembly.
One other person in this thread has the same exact problem. And @techknight has a recent video (mentioned earlier in this thread) showing a Portable with the same cracked hinge holder too. That means there are likely others out there.is this a common problem? I’ve not heard of it before.
Agree: without proper reinforcement it will never work for regular use. 3D printing something out of metal seems to be an interesting proposition, but I am afraid it would just offset the bonding issue somewhere else. Maybe waiting for a chassis to pop up on eBay is the most reasonable proposition, unfortunately many Portables are failing due to the LCD…The broken hinge cannot be repaired with glue, it will continue to break. I suspect that the existing structure can be reinforced economically (such as metal 3D printing).
I am envisioning a perfectly form fitting bracket which is both epoxied and bolted into place — ideally, this will spread the load over the entire upper chassis rather than just the upper segment of the hinge mounth.Agree: without proper reinforcement it will never work for regular use. 3D printing something out of metal seems to be an interesting proposition, but I am afraid it would just offset the bonding issue somewhere else. Maybe waiting for a chassis to pop up on eBay is the most reasonable proposition, unfortunately many Portables are failing due to the LCD…
Definitely! This could be a great place to add more support for a bolted on reinforcement bracket - or just plain old reinforcement!There appears to be some voids on the underside of the subframe assembly (shown in this image on the left side) that could be filled in with putty to add reinforcement?
I think it would look cleaner without the transparent plastic piece.It seems you are suggesting that I do NOT DCM-weld the transparent plastic piece over the backs of the ribs and instead use only JB Weld Original all across the back. Correct?
You would need to drill through the transparent piece and the plastic of the subframe?The only thing I've not yet decided is if I want to drill in order to add self-tapping screws BEFORE I apply any JB Weld. THAT is the question in my mind right now.
I appreciate you sharing your work. 3000 people have viewed the thread so I don't think you're just talking to yourself. I also have my popcorn outBy the way, I really appreciate your reply. Had you not replied, this thread would have been me talking to myself very the last few days! I suspect @Stephen , @phunguss , and a few others have their popcorn out, watching me work with interest.
