Custom 9.7" Display (iPad 1,2,3) for Apple //c with STL files and build guide [Draft: work in progress]
614
This is primarily based on the design by @ArjenCNX in this thread. I have made some modifications to the files to support any iPad 1, 2, or 3: 9.7" panel that you can rescue from a non-functional iPad. There are enough changes to warrant this as a separate thread, so I don't flood the thread and the great work already done by @ArjenCNX. I did not do any modifications to the driver board, so this will still take VGA (VGA card in //e) and HDMI (A2CDVI on //c). The board I chose does not have composite input, but as noted, there are many driver board options available for iPad displays.
Parts used:
- iPad 9.7" LCD panel (from iPad 1, 2, or 3)
- iPad driver board and control panel (various models available) and appropriate power supply
- STL 3D printed files (will attach when completed)
- 2x 3" 10-32 screws and nuts (M5-0.8x70mm or 75 are the metric equivalent and will work interchangeably)
- various small wood type screws (I rescue and repurpose, so I don't know the sizes)
STL files:
Attached below with instructional PDF.
Changes from @ArjenCNX model:
- No de-soldering components from the drive controller board
- Recessed back panel to make room for cable connections and power
- Back panel is now 2 pieces to save on support material during printing
- Base has a rise in it to accommodate thicker cables like VGA
- No USB-C power, you figure out your power cables on your own
- Thicker bezel for the LCD driver board
- Changed smooth knobs to grooved for better grip when tightening
- Changed internal screws so there is decoupling between the hinge so it never loosens on its own
- Modified knobs to accept a nut on a screw so no allen/hex wrench required
- optional base for //e usage
Exploded illustration:
Problems along the way.
I picked up a used Creality CR10 for cheap so I would have a larger print volume. It needed some love and adjustments, and I don't have it completely tuned yet, so I wasted a lot of precious Retro Platinum in the process. Elephant's Foot, bed plate adhesion, and other things plagued me. I also installed a 0.8mm nozzle for thicker layers and faster printing. I prefer to print face down to eliminate a lot of support material waste.
I was too focused on the design to test everything before I made my prints and I ended up putting the display mounts in upside down. I have to redesign and reprint.
The Elephant's Foot causes the first few layers to be larger and that caused some of the tight gaps to close in on themselves. I increased the space but still not enough to offset the EF issues, so I got creative with a knife tip on my soldering iron and cleaned it up with an Xacto knife. Super ugly, but you won't see it at all from the outside or front.
I was able to reprint the correct bezel orientation and install the iPad1 LCD. I haven't cleaned up the brim yet.
More to come, I will update this post as I complete it....
  • Appleiic-iPadLCD.odt.pdf
  • iPad Bezel 2026.zip
614
Still refining the iPad 2 and 3 adapters, but instructions and STL files have been added to the first post.
Reactions: ArjenCNX
ArjenCNX
102
133
Parts used:
STL files:
If you can get PETG material, the warping can be much reduced, the print bed needs to be at about 80C, but then the prints will not warp if you use good quality print materials
753
Awesome job! I recently started trying to print this for my IIc Plus. Unfortunately, I have a different version with the composite video on a smaller controller board. I modified it to work with mine, and made a sad attempt to create a new I/O cover. I also found when I imported the model into Bambu Studio, the stand-offs for the IO cover seems to be corrupted. I created new mounting points for the controller, the secondary board (not sure what its purpose is) seems to line up with yours, so I left those as is. The button board is quite a bit different on mine, so I also had to re-do that area to fit mine.
I also think a few of the screw holes are not the right size and had to manually enlarge a couple on the back plate.
Can you share the bolts and nuts you used for this? I'll may run to the hardware store in a bit to see if I can come up with the answer on my own.
Will post pictures when I get is close to fully assembled. And can share my files if it helps others.
614
For the hinge pin, 2x 3" 10-32 screws and nuts (M5-0.8x70mm or 75 are the metric equivalent and will work interchangeably), The rest of the assembly was mostly salvage screws and bolts. The iPad mounting were tiny m1 or m2 wood type screws.
Reactions: wottle
753
FYI, mine turned out pretty good. Had to make a new version to handle the much different button board and controller. The cutouts for the controller board ports aren't great, and I had to cut some a bit to make it work, but I'm not reprinting at this point, since it's essentially out of sight. Thanks for doing all the heavy lifting with this!
IMG_7018.jpegIMG_7019.jpegIMG_7020.jpegIMG_7021.jpegIMG_7022.jpegIMG_7023.jpegIMG_7024.jpegIMG_7025.jpeg
ArjenCNX
102
133
Wow looks smoooth! also just the right color, and i like the modified knobs allot, looks really neat!
meanwhile i have added the AVDVI mod as well, and now use HDMI for video input as it gives a higher quality image and uses more screen space for a larger image, i can recommend it!
Really nice to see the mods and improvements you made! Well done Sir Wottle!
Reactions: wottle
