PowerFox - new web browser for Leopard on PowerPC!
3lectr1c
684
350
the United States
www.macdat.net
I can't believe it, but it's true! It looks like browsing the modern web on PowerPC isn't dead quite yet.
PowerFox is an FF-based browser released earlier this month with a target platform of Snow Leopard. Just a couple days ago though, they released a beta build for Leopard which runs on PowerPC G4 or G5 hardware. JIT isn't implemented (yet?) so I don't know how well it will perform compared to TFF. Since it's got a newer browser engine, it should at least be able to render websites which no longer work on TFF or InterWebPPC.
I'd love to try this out myself, but unfortunately I'm away at college until March and I didn't bring any PowerPC hardware with me. Curious to see how well it performs for y'all.
scj312
85
It's a bit slow on my G5 without JIT, but it does work quite nicely!
562
Great find! It does work slowly, but it does WORK.
520
www.floodgap.com
Because UXP's widget layer is not too different from TenFourFox's, it should be possible to port the rest of the 10.4 changes (and there are quite a few), and it should "just work" without a lot of fuss on Tiger.
The JIT is a different story. The basis would still transfer, but it would require a fair bit of additional programming, and the JavaScript compiler has advanced quite a bit since Fx45. This also doesn't include Wasm, which is inherently little-endian (there is some hacking to make asm.js look little-endian to the PowerPC in TenFourFox but not everything has an asm.js equivalent).
Reactions: Jazzzny
Jazzzny
24
38
I want to ask, is there anything that needs major work for Tiger apart from widget code? I was hesitant to even attempt work on Tiger as some of your blog posts from ~10 years ago seemed to suggest major problems with a bunch of Mozilla's subsystems when building for Tiger.
520
www.floodgap.com
Good question. A large part of it was the compiler I was using, which was still gcc 4.8 (I was intentionally very conservative with the toolchain). You are using a much more advanced compiler, so you should have fewer problems.
Cursorily, if you wanted to do a Tiger build (from a Leopard toolchain), you'd need the following:
- For the front end, port the widget changes and some items in `gfx/`. If you're using Cairo all the way, which is simpler but slower, you won't need the CoreGraphics backend. You will need the font changes but I think you have most of those already.
- For the back end, port the `nspr/` changes. There are some functions that exist in 10.5 but not 10.4 and I rewrote these. You may also need some similar changes in `mfbt/` and `mozilla/` (I don't recall if UXP uses this).
- Provide `gcc` runtime libraries also built against the 10.4 SDK. People ran into problems building TenFourFox on Leopard with a `gcc` also built on Leopard, because even though the browser would be linked against the 10.4 SDK, `gcc` wasn't and its `libgcc`, `libatomic` and `libstdc++` were still linked against 10.5 -- and the browser wouldn't work. The simplest solution is to build on Tiger the whole way, though it is possible to build a cross-compiling `gcc` on Leopard and use that, and some people have done it. Alternatively, you could build just the compiler on Tiger, extract those libraries, and substitute them into the Tiger build when you package it up.
- Build against the 10.4 SDK.
I don't warrant that would be everything, and later incompatible bits may have snuck in, but getting it to 10.5 alone was most of the work. The above should get you nearly the rest of the way there.
Reactions: Jazzzny
Jazzzny
24
38
Would there be any fundamental blockers if I used the 10.5 SDK? Obviously it would hide any symbol problems that arise, but I’d like to not compromise the 10.5 experience too much, as we’re able to use CoreUI and have OMTC there. Would probably be wise to get the browser off the ground using the 10.4 SDK, but after that I’d like to rely on the 10.5 SDK with minimum versioning set to 10.4 and OnLeopardOrLater in any conditional code. I’d rather not build for 10.4, 10.5, and 10.6 separately, as the PPC builds take around 2 hours each, yet I still want to keep the benefits for each target.
I guess this would probably require weakly linking CoreUI and using undefined symbol lookup at the very minimum?
520
www.floodgap.com
I'm not sure I understand the question correctly, but you're likely going to end up linking against *$UNIX2003 symbols when you build against the 10.5 SDK, meaning the build plain won't run at all on 10.4 because those variants don't exist there (you'll get "symbol not found" errors from dyld).
If you want to make a PPC build that will take advantage of 10.5 features but can still run on 10.4, the way I'd do it - there may be other approaches - is to build against the 10.4 SDK but import the symbols for the 10.5 features you want to use like CoreUI, etc., e.g. with dlopen(). At runtime, in the modules affected check and cache the OS version in use, and if it's Leopard, instantiate the desired functions as part of initialization. This isn't a difficult thing to do and I believe there may be examples in the code already, just a bit tedious.
Reactions: Jazzzny
2,182
Please let me know when the Tiger (10.4.11) version is out. My 1.3GHz 7455 G4 Cube would love to use it!
2,182
Alas, it's not yet ready for Tiger.
On a G4 Cube running a fresh install of 10.4 Tiger, the disk image won't even mount...
When I update to 10.4.11, the disk image mounts and I can copy the app to my HDD, but when I launch it, it crashes.
Reporting it here on TD because I don't know how to contact "danupsher" on Github.
  • CrashLog.rtf.zip
scj312
85
Worked great here on 10.4.11 on my G5. Reading through some MacRumors posts it sounds like it unintentionally only works on G5s right now, unfortunately.
  • Sad
