PowerFox - new web browser for Leopard on PowerPC!
2,227
I just downloaded the new v3.1 under OS 10.4.11 on my G4 Cube (with 1.7GHz Sonnet CPU). Disk image mounted fine. But the MacFox v3.1 app launched and crashed right away...
Again, I don't know how to convey this info to the developer, but if anyone here does, please pass the word along. Thanks.
575
www.floodgap.com
How much video memory do you have in the system? ISTR that Action Retro tried the 10.5 build on a G4 and had to upgrade his graphics card or he'd get a similar startup crash. (I'm not sure how he determined that was the problem, but it worked after he did.)
Jazzzny
35
68
Just FYI, I fixed this several weeks ago - it seems like he was using my initial build.
The problem was related to these GPUs not supporting FBOs which caused the basic compositor to freak out.
Reactions: ClassicHasClass
2,227
The G4 Cube I am testing on has the stock ATI Radeon Rage 128 Pro installed. So I guess 16MB of VRAM? The machine is at the office and I’m home for the weekend so I can’t check right now.
Jazzzny
35
68
@ClassicHasClass I've ported down to 10.4 using your patches, all code written by hand.
Thanks again for TenFourFox and (especially keeping the if(0) defines)! Most of the patches I was able to copy-paste.
Reactions: Appleuser201
Jazzzny
35
68
Yes, I'll try to get something out soon.
Still a few blockers that I need to deal with though, mainly DrawTargetCG doesn't seem to like like certain draw requests for whatever reason, even pages like about:support cause it to fault in SVG code.
Speaking of DrawTargetCG, could I pick your brain about something? I was trying to add support for CSS's masking properties, which accept images (via mask and mask-image) and gradients. These were added after the CG backend was ripped out, so it doesn't work properly after CG was put back in. I believe this runs through https://repo.palemoon.org/Moonchild...1f6/layout/svg/nsSVGIntegrationUtils.cpp#L539 on either path.
After patching this to let CG handle the drawing instead of falling back on Skia and failing, it gets masking with images to work. However, masking with gradients is still broken, nothing gets rendered.
Do you happen to have any ideas as to why CG doesn't like to render the gradient + mask that its getting passed? This happens on 10.4 and 10.5.
Jazzzny
35
68
Okay, sorry, I lied - its 10.5-exclusive. I fixed the last major 10.4 issue, and gradient clipping works perfectly here! I'll see how to get whatever fixed it ported up to 10.5, but for now, this is working and looking great on 10.4.
575
www.floodgap.com
I seem to remember a problem with alpha blending and gradients but not failing to render entirely. You mentioned it only occurs on 10.5. Are your previous builds linked against the 10.5 SDK affected?
Jazzzny
35
68
Yeah, the 10.5 builds built with the 10.5 SDK suffered from the gradient clipping issue. I'll try again now that that the 10.4 changes are in DrawTargetCG, hopefully they'll do something.
575
www.floodgap.com
Hmm. My only other comment is that in TenFourFox, I used a third-party library called CTGradient to give me proper convenience functions. This library works on both 10.4 and 10.5. I don't know if that's worth looking at, but if you want to, it should be in gfx/2d/ in the TenFourFox source (CTGradient.*, which includes a couple bridge libraries I wrote as glue).
2,227
I confirmed just now that the 7450/7447 build of 26.2.2 works on a G4 Cube with Sonnet 1.7GHz 7447A running OS X Tiger 10.4.11. Great!
But the main problem I have is that if you use the Start Page and type Wikipedia into the Search field and hit return, you are given an "unusual traffic" error page with reCAPTCHA, and after clicking the "I'm not a robot" checkbox, the spinning wheel spins forever. Tried searching for Macintosh Garden and the result was the same.
I am able to access websites ONLY if I know their URL. These worked when I typed them into the address bar directly and hit return:
But search is blocked for me due to that reCAPCHA problem. And search is pretty important.
Performance is slower than other browsers like Safari that came with Tiger, but not unusually so, as it often is when trying to get a vintage browser to run on 68K Macs, for example.
cjsebes
I installed PowerFox on my 12-inch PowerBook G4. I'm stoked that I can hit some simple websites like my favorite streaming radio station, Radio Paradise. My next challenge is finding a Bluetooth USB dongle that will allow me to stream music to my BT speaker. So far, everything I see is designed for sending or receiving data, not audio. That would require A2DP functionality and I've not yet seen a way to incorporate that into a machine this old.
