PowerFox - new web browser for Leopard on PowerPC!
557
www.floodgap.com
My suspicion is that the user agent may "look suss" to Google. We didn't have this problem with TenFourFox because I suspect it had developed sufficient notoriety with developers, but this won't be true of UXP forks.
Someone else has done a 10.4 port, and they are working on a JIT. Looking at the code it is very different from TenFourFox's, so I suspect it is a ground-up rewrite. I haven't extensively tested it. https://github.com/danupsher/machfox-browser
Jazzzny
34
62
This JIT was done entirely by Claude AI. I am very hesitant to incorporate changes from such a thing, as it just sounds like a major problem waiting to happen.
Regarding any problems with Google, I have personally not experienced any suspicious activity checks, nor have my internal testing group reported any, though I am connected to a campus network that Google probably has laxer scrutiny towards. Google will probably flag your entire network if they do detect any suspicious activity, you may be able to get yourself "unblocked" on a different machine.
557
www.floodgap.com
Possibly, though if it passes the test suite (TenFourFox was aggressively tested on it), then it should at least behave correctly. Couldn't say anything about security issues, of course, but those tend to be a bigger problem in the front end rather than codegen.
Jazzzny
34
62
From what I can tell, the jsshell test suite was not run. In fact, the developer disabled ION because of what I assume to be crashes that the AI could not resolve.
2,187
@ClassicHasClass & @Jazzzny
When either of you use the latest version on a G4 and when you type MacintoshGarden into the search field, do you get reCAPCHA, and if so, does it hang for you like it does for me on my G4 Cube running 10.4.11 Tiger?
Jazzzny
34
62
Works perfectly fine here.
2,187
Great to hear that. And so... What is the technical reason I am not having the same great experience, being hit with reCAPCHA? Because I am located in Japan? As mention in my earlier post here, on the search results page, rather than see any search results, it tells me that there is "unusual traffic" from my computer and therefore it throws a reCAPCHA at me. Fine and well, but why doesn't the reCAPCHA work?
If you cannot answer these questions, maybe you could find a site that requires you to do a reCAPCHA and see you can successfully get past it? In other words, is there a bug in getting reCAPCHA to work?
Jazzzny
34
62
Unfortunately it looks like Google thinks the JavaScript engine is too slow to be legitimate, opening the browser console shows reCAPTCHA timing out. I have also been able to reproduce this in MachFox, so it seems like we will require a significantly optimized JavaScript JIT to have a chance at passing reCAPTCHA.
Jazzzny
34
62
Hello all, I'm happy to announce that I have finished preliminary work to port the IonPower JavaScript JIT to PowerFox!
This makes the browser much, much faster and usable.
I cannot provide a release date yet as I still need to make the fully engine pass JavaScript compliance tests without crashing, but I can guarantee at this point that PowerFox for PPC will receive a JIT.
557
www.floodgap.com
Yes, it was a lot easier debugging it when I could run automated tests. The command line shell was massively faster at that. It won't catch every bug but it catches a lot.
Be mindful of the fact that the JIT has monstrous stack requirements. There is specific code in the TenFourFox build system to request a large stack region for both the main browser executable and the JS shell.
Jazzzny
34
62
Thanks, I've located your changes in the appropriate moz.build files. Do you happen to remember the reason for the stack size increase? I didn't have this in for quite a while and it seemed to work okay, though I haven't gotten any benchmarks to run yet.
557
www.floodgap.com
If you don't do it, you'll get crashes in the browser trying to run any code of substance. The test suite will mostly run, but most of those are trivial. Because so many registers need to be saved in each stack frame and calls can be recursive, it's pretty much unavoidable.
Reactions: Jazzzny
Jazzzny
34
62
Did you have to do anything special to get the larger stack to function? When I pull in the linker argument, it creates a binary that instantly crashes with r1 zeroed out.
557
www.floodgap.com
That means the loader could not allocate that much stack space to your process, so you get a null pointer. If this is the browser, it's likely because your code in memory is much bigger than TenFourFox's was (you get about 2GB total which must be split between your code pages, data pages and the stack). You'll have to try backing it down until it sticks, though of course the less stack you have, the more likely you'll run into trouble at some point.
If you're getting that when trying to run the shell, however, then I'm not sure what's going on. There should be enough space for that.
Jazzzny
34
62
Yes, this is with the browser, I'll see how much I can get out, thanks.
Jazzzny
34
62
Luckily I was able to get the full gigabyte out, vmmap showed that the original address would indeed have caused a collision, but I was able to shift it up a bit and still stay in mappable memory.
Funnily enough the ld64 I am using is seemingly bugged and strips __UNIXSTACK when -dead_strip is used, I had to fix that in the source code, which I believe was the actual cause of the immediate crash.
Jazzzny
34
62
I have worked through all of the assertions, crashes, and conformance issues I could find, and I can now confirm that the browser is working correctly:
Still some room for optimization, but I really don't know how I would approach that. This is already around 21 times faster than JITless.
On another note, in a way, this is "TenFourFox 52" in spirit. Only 10 years in the making... :)
