Macintosh Mini - (yet another) Maclock conversion project
wells
Hi yall,
I was hoping to share during MARCHintosh but sharing now that I finally got things over the finish line.
Similar to others (notably Sideburn and Colin, and others I'm sure), I built my own mini Macintosh using one of those Maclock clocks from AliExpress. I decided to go the route of designing my own custom PCB that replaces the clock completely, and brings brightness control, buttons, sound, and power (both USB-C and battery).
I'm a novice with circuit design, so the implementation is basic and there's certainly a lot of room for improvement. Regardless, I wanted to share my project with you all to hopefully inspire you or help you build your own. I'm not selling the boards or any premade assembled Maclocks, but you can order your own boards from PCBway for a very reasonable price.
I posted a written guide on my GitHub, as well as a full assembly walkthrough video:
On the software side, I wanted to run a more modern Linux kernel and SheepShaver Basilisk II (see update below) rather than the Mini vMac guides I've seen posted online running on Bullseye. With some doing, I finally got it to run.
If you want to follow the same steps I did, I have my Macintosh Mini install guide, and it includes an automation script that installs the emulator, sets it up to run at boot, adds the button/brightness controls, and even a user-selectable boot chime—all in one shot. (Disclaimer: yes, I did use AI to turn my written guide into the automation script. If that's not your jam, the written guide is just as complete... it just takes longer!)
Let me know what you think, and thanks for checking it out.
PS: if there's enough interest, I'd be willing to organize a group buy for the PCBs and passive components on the board.
RetroViator
166
retroviator.com
The video showed up in my feed this morning. You did a great job, both with the project and the video. I was impressed with the thoroughness of the documentation. Very professional. I'd be interested in a group buy, if that takes off.
629
Fantastic work. I actually just went through this. I suspect I may have gotten a fake Pi Zero 2 W from Amazon, because I had quite the adventure trying to get it to work. First, I was not able to get the 64-bit version of Pi OS Lite to boot on the machine. I fell back to the 32-bit Lite image. I could get it to install, but I would get file system corruption every time I ran your scripts. I was able to fix the corruption manually on my Mac, but the compiler for Sheepshaver wouldn't work. I tried many different variations, but the best I could get was Sheepshaver to launch, load the ROM, and then crash once MacOS 8 tried to load. Ultimately, and more inline with the compact Mac, I ended up doing my own basilisk II install with a manual compile, and replicating your setup with the auto-launch, buttons, etc.
Really wish they would be able to make enough Pi zero 2 Ws to satisfy demand. A couple of notes for your documentation:
1. You say it in the installer as a warning if you don't have the 64-bit install, but I'd put it in the guide so people know if likely won't work with the 32-bit install.
2. I wasn't paying too much attention, but when I pulled the cable out to the USB charging board, I accidentally pulled the connectors off the wrong end, so when I plugged my connector in, the green and yellow were not connected to the 5v and ground pins. Not a problem, I was able to swap, but it initially gave me a panic when I had it plugged in and put the disk in and got no signs of life.
3. Some instructions for the speaker setup would be nice. I feel like I saw you mention it somewhere but I went back to the video and couldn't find it there or in your written instructions.
4. I see you setup the USB connector on the back. How did you set that up. Dremel out an opening and superglue the cable in place?
Will post photos once I get the speaker in and create an opening for the USB port. Thanks again for doing this. If anyone needs the PCB, the audio board, and caps, I have extras.
2,184
The use of Sheepshaver indicates this is a PPC emulated machine, and that would explain the use of OS 8.1 in the opening post video. Not an issue at all, just something I noted.
I’ve never been able to get Sheepshaver to work on my modern Macs, but I’m pretty sure it won’t boot into System 6 (just a note for those who even care) because not even Basilisk II (a 68K emulator) will let you boot System 6.
All that aside, I think this is a great conversion project!
wells
Small update: I finally found some time to experiment with Basilisk II + Performa 580 ROM and the performance is significantly better and more stable than my original SheepShaver implementation. Kudos to everyone who suggested I try this path.
Updated guide and install script here: https://github.com/wr/macintosh-mini
If you've run the install script before, you can run it again to cleanly upgrade from SheepShaver to Basilisk II. You'll need to provide a new ROM file (I used 064DC91D) and possibly a new disk image (if yours is PPC only), but the 8.1 image I was using works just fine.
If you're running it for the first time, Basilisk II will be the default, though SheepShaver is still an option if you need to run PPC apps for whatever reason.
Mike's Future Retro
I’m on my way to doing this project. I ordered 5 of your adapter boards from pc way. I just need to find some one who can 3d print a bezel adapter to mount for the screen/lcd … any one ? Anyone out there who can 3d print a few for me ???
wells
DM me your address and I'll send you a few.
2,184
@wells
Have you put your STL files through the JLC3DP website to see if the size is large enough for them to do a PLA print? They have some pretty silly minimum size requirements that can be frustrating. If they refuse to print your files in PLA, they may allow it in Nylon. So I suggest exploring that.
The reason I suggest doing that is because when more people start doing this project, you’re not going to want to send them all the required 3-D prints. If people can use JLC to print your STLs, then that problem is solved. I don’t have a 3-D printer myself, so I always use JLC.
Also, I recently purchased a Maclock and a Pico Mac Nano, and I’m thinking about my next video showcasing both of those products. Even though I’m not going to do your Maclock conversion project right now, I do want to mention it in my video, and in the text description I will put a link to this thread. That will hopefully generate more interest in your excellent project and more people will of course be in need of the required 3-D prints.
wells
It looks like PCBway will print the STL for this project in PLA (or any other FDM filament) whereas JLCPCB has a 30x30mm minimum.
629
I should have posted this sooner. I have 4 extra boards if anyone needs one. However, I'm about to be away from home for 3 weeks, so it will be a while before I can ship. I could also print the mounting frame for those who need it.
