Froggy814
Squaw Valley, CA
Hello everyone! My portable came to me and I was able to get it fixed. (It has a nice lcd but when it fails I want to be ready, I also want to help the community) But when doing my research so many of them have been turned to parts because of the lcd, it gets worse and worse but cant get better because of little transistors or vinegar syndrome. Well I am trying to modify a design created by Rezafouladian to fit inside of the Portable. It would fit in the battery case or, if best comes to best inside of the display bezel itself.
I have a couple of stages for this project:
Stage 1: Adapter FPC to connect to standard connectors for ease of use connecting to the lcd plug on the motherboard and then putting it to a more standard cable 2x13 2.54 header. Done!
Photos:
Stage 2: Modifying Rezafouladian's design to connect to the 2.54 header. In Progress
Stage 3: Buy it when I have the money and test it.
Extra parts to go with it. An Pi-Zero, and a lcd (that is the right size) with HDMI or av output controller board, cable to connect everything together. (Exhaustive, I know.)
I hope it works and I can share it with all of you when the time comes. I will update progress when things happen. Please share your thoughts and ideas too. Thanks!
-Froggy
Froggy814
Squaw Valley, CA
Got all the traces coming from the plug run! They were a pain because they all have to be the same length. I hope they function...
Edit......... I have to reroute them all. The plug is on the wrong side...
Froggy814
Squaw Valley, CA
NICE! Hopefully the fix won't be too bad.
Though at the frequencies involved in the Portable, do traces really need to be equal for video?
Thanks! I hope the fix isn't too bad.
I am not really certain if the traces have to be equal length but just to lean on the safe side I am trying to make them as close to each other as possible. It's quite hard to find anything off the interwebs these days that's useful. (Unfortunant use of AI slop and hard to understand technical pages if you know what I mean)
Froggy814
Squaw Valley, CA
Does anyone know why there are grounds and vcc connected to A pins but nothing connected to B pins on the top IC for the A pins? Can I remove one of the grounds to move a D0 to the top IC?
Froggy814
Squaw Valley, CA
Hmm, I guess you're right. I found a trace length difference calculator. The traces can supposedly be off by a little less then 1500mm...
Thank you for making me double check!
445
I have a hunch toat trace lengths became an issue when, or just before alternating ground lines between signals became a thing? Sometime around VLB development on the PC side?
Nope, haven't even played with AI outside of the assistant on Amazon listings. Besides, I have enough trouble understanding deeply technical things on my considerable collection wood pulp based storage media. ;)
