Froggy814
96
24
Squaw Valley, CA
Hello everyone! My portable came to me and I was able to get it fixed. (It has a nice lcd but when it fails I want to be ready, I also want to help the community) But when doing my research so many of them have been turned to parts because of the lcd, it gets worse and worse but cant get better because of little transistors or vinegar syndrome. Well I am trying to modify a design created by Rezafouladian to fit inside of the Portable. It would fit in the battery case or, if best comes to best inside of the display bezel itself.
I have a couple of stages for this project:
Stage 1: Adapter FPC to connect to standard connectors for ease of use connecting to the lcd plug on the motherboard and then putting it to a more standard cable 2x13 2.54 header. Done!
Photos:
Stage 2: Modifying Rezafouladian's design to connect to the 2.54 header. In Progress
Stage 3: Buy it when I have the money and test it.
Extra parts to go with it. An Pi-Zero, and a lcd (that is the right size) with HDMI or av output controller board, cable to connect everything together. (Exhaustive, I know.)
I hope it works and I can share it with all of you when the time comes. I will update progress when things happen. Please share your thoughts and ideas too. Thanks!
-Froggy
Froggy814
96
24
Squaw Valley, CA
Got all the traces coming from the plug run! They were a pain because they all have to be the same length. I hope they function...
Edit......... I have to reroute them all. The plug is on the wrong side...
Froggy814
96
24
Squaw Valley, CA
NICE! Hopefully the fix won't be too bad.
Though at the frequencies involved in the Portable, do traces really need to be equal for video?
Thanks! I hope the fix isn't too bad.
I am not really certain if the traces have to be equal length but just to lean on the safe side I am trying to make them as close to each other as possible. It's quite hard to find anything off the interwebs these days that's useful. (Unfortunant use of AI slop and hard to understand technical pages if you know what I mean)
Froggy814
96
24
Squaw Valley, CA
Does anyone know why there are grounds and vcc connected to A pins but nothing connected to B pins on the top IC for the A pins? Can I remove one of the grounds to move a D0 to the top IC?
Froggy814
96
24
Squaw Valley, CA
Hmm, I guess you're right. I found a trace length difference calculator. The traces can supposedly be off by a little less then 1500mm...
Thank you for making me double check!
462
I have a hunch toat trace lengths became an issue when, or just before alternating ground lines between signals became a thing? Sometime around VLB development on the PC side?
Nope, haven't even played with AI outside of the assistant on Amazon listings. Besides, I have enough trouble understanding deeply technical things on my considerable collection wood pulp based storage media. ;)
Froggy814
96
24
Squaw Valley, CA
Now that I have a rough sketch of the pcb I get into the nitty gritty... WAITING for the Waveshare RP2350 PiZero to show up so that I can take measurements. In the meantime, I will be making the schematic for the Waveshare RP2350 PiZero and (crossing my fingers) hoping I can incorporate it into the final design to make things smaller.
462
Wondering about your choice of CPU here? The most obvious difference seems to be rechargeable battery power support and then these?
264KB SRAM - as opposed to 512KB SDRAM on Pi Zero, but much faster?
16MB of onboard Flash memory - no memory onboard Pi Zero, MicroSD only there?
reserved solder pads for PSRAM chip expansion - so memory upgrade to Pi Zero's level or more is possible?
Am I reading the spec. sheets correctly. Did I miss anything? Very interesting stuff.
Would these differences make the Waveshare more suitable or less so for Mac Emulation than vanilla Pi Zero?
Does it lack WiiFi support, didn't see that mentioned, that's required for my use case?
Froggy814
96
24
Squaw Valley, CA
Look!
It all FITS!!!!!! :LOL: Thats that, we'll just print the pcb and viola!... (JOKINGLY TONE)
No suriously, that is the max pcb size that can fit in the portable's lcd bezel! Now all I have to do is figure out where and how to route traces...
Froggy814
96
24
Squaw Valley, CA
520KB of SRAM - as opposed to SDRAM on Pi Zero?
reserved solder pads for PSRAM chip expansion - so memory upgrade is possible?
Am I reading the spec. sheets correctly? Very interesting stuff,.
Would these differences make the Waveshare more suitable for Mac Emulation than vanilla Pi Zero?
I was just using the waveshare because Rezafouladian's design, (AND CODE, I DON'T WANT TO WRITE CODE IF I CAN HELP IT) Use's that Pi instead of any of the other's. It also seems like a logical choice since it has HDMI out and doesn't have a quad core CPU and it's already really small. It won't have the ram upgrade on my board if it runs fast enough on the output plug though.
Yes you are reading them correctly. I am receiving one hopefully in the week.
Froggy814
96
24
Squaw Valley, CA
Unfortunately, I know nothing of coding and ran into a little bit of a snag. If anybody could help me that would be heavenly!
I have the HDMI plug on the top of the PCB with everything else but the pinout of the lcd doesn't line up with the pinout of the library that comes with the Waveshare pi. If anyone knows how to change the pinout of this library: common_dvi_pin_configs.h
that would be greatly appreciated!
I have already made a thread on the raspberry pi forums too.
Froggy814
96
24
Squaw Valley, CA
Do these HDMI traces look like they are run good? I think they will be okay. The Maximum length difference between traces is 66mils and it should have 100ohm of differential impedance.
Froggy814
96
24
Squaw Valley, CA
Alright, I found a display that will fit kind of well, I don't need the display so I am not ordering it but for those that need it, it fits with the dimensions at least. Display I couldn't find any closer ones.
I am asking this, I would like 4 volunteer's for once the boards arrive, I would mail them to you. But they wouldn't come with almost any parts, maybe like 4, it might not work, considering the above post. But it's on it's way. Who would like to try it out? Pls PM.
